[solved] PIC18F66J94 #PIN_SELECT U1RX / U1TX issue
spilz
PostPosted: Tue May 19, 2020 6:44 am     Reply with quote
hello,
I'm trying to use a new PIC for me, the PIC18F66J94.
but there is something I don't understand in mapping pin :
this is OK with compiler :
#pin_select U1TX = PIN_G0
#pin_select U1RX = PIN_G1
#use rs232(baud=9600,parity=N,xmit=PIN_G0,rcv=PIN_G1,bits=8,stream=PORT1)
but when I switch PINs :
#pin_select U1TX = PIN_G1
#pin_select U1RX = PIN_G0
#use rs232(baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G0,bits=8,stream=PORT1)
I got this error :
Invalid Pre-Processor directive Invalid Pin: PIN_G1 can not be assigned to U1TX
Invalid Pre-Processor directive Invalid Pin: PIN_G0 can not be assigned to U1RX
Can someone explain me if it's normal or not ? and why ?
thanks for your help[/quote]
PostPosted: Tue May 19, 2020 7:36 am     Reply with quote
I'd have to download the datasheet but it seems like that PIC will not allow those pins to be connected to those peripherals according to the message.
You need to understand that not all pins can connect to all peripherals of all PICS with 'pin selectable' options.
Somewhere in the 600-800 pages of boring yet need to know information will be a very good description of pin 'options'.
PostPosted: Tue May 19, 2020 8:47 am     Reply with quote
That chip has what they call 'PPS-Lite', which is restricted on
what can go where.
PPS-Lite is similar to PPS (available on
PIC18F products), but limits the user to interconnections
within four sets of pin/peripheral groups.
Tables 11-13, and 11-14 describe what can map where.
So (for example), U1TX, can only go to RP2,3, 6,7, 10,11,1 4,15,
18.19, 22,23, 26,27, 30,31, 34, 35, 38,39, and 46,
Similar restrictions apply for U1RX.
PostPosted: Tue May 19, 2020 10:08 am     Reply with quote
Just checked and it is the U1RX that is the problem. Only allows 11 locations
that it can go to.
spilz
PostPosted: Fri May 22, 2020 12:36 am     Reply with quote
Thanks for your quick reply.
I start to understand better now how this pic works Smile
