Interrupt Priority PIC18F67K22
GusA
PostPosted: Wed Apr 29, 2020 11:12 am     Reply with quote
How do I configure interrupt priorities (IPEN = 1) for the pic18f67k22 microcontroller? I am using the PCWH compiler.
I do not see it on the IDE project wizard, or find it on the CCS C compiler manual.
Also, my code includes use of the modbus rtu driver. It is factory configured to interrupt on RDA from the uart. Can it be re-configured to use hi/lo interrupt priority and set as low priority?
Thanks!
PostPosted: Wed Apr 29, 2020 11:27 am     Reply with quote
It is in the manual.
Add the line:
#device HIGH_INTS=TRUE
near the start of your code (just after the include for the processor).
This turns on IPEN.
Then declare your INT_RDA with:
#INT_RDA HIGH
This will then be a high priority interrupt, with separate locations used
to store the regsiters.
One caveat. INT_EXT does not have a priority control bit, and if this
is used it will always be a high priority interrupt.
