cvargcal
| Translate code MQTT Arduino |
Posted: Mon Apr 20, 2020 4:07 pm |
Hi, I try to translate this code from Arduino, but i don't know how use the printf.
The idea is make a ConnectPacket first and after send the PublishPacket of course once again make the connection TCP, but no print fine the buffer, maybe because the printf is bad write.
int led = 13;
unsigned int Counter = 0;
unsigned long datalength, CheckSum, RLength;
unsigned short topiclength;
unsigned char topic[30];
char str[250];
unsigned char encodedByte;
int X;
unsigned short MQTTProtocolNameLength;
unsigned short MQTTClientIDLength;
unsigned short MQTTUsernameLength;
unsigned short MQTTPasswordLength;
char MQTTHost[30] = "io.adafruit.com";
char MQTTPort[10] = "1883";
char MQTTClientID[20] = "ABCDEF";
char MQTTTopic[30] = "cvargcal/feeds/testv";
char MQTTProtocolName[10] = "MQTT";
char MQTTLVL = 0x03;
char MQTTFlags = 0xC2;
unsigned int MQTTKeepAlive = 60;
char MQTTUsername[30] = "cvargcal";
char MQTTPassword[35] = "aio_xJeb83eGnlYAEDVgxlfyqsuKMttk";
char MQTTQOS = 0x00;
char MQTTPacketID = 0x0001;
//!void setup() {
//! pinMode(led, OUTPUT);
//! Serial.begin(9600);
//! Serial.println("Arduino MQTT Tutorial, Valetron Systems @www.raviyp.com ");
//! delay(3000);
void SendConnectPacket() {
fprintf(uart2,0x10); // Serial.write(0x10);
MQTTProtocolNameLength = strlen(MQTTProtocolName);
MQTTClientIDLength = strlen(MQTTClientID);
MQTTUsernameLength = strlen(MQTTUsername);
MQTTPasswordLength = strlen(MQTTPassword);
datalength = MQTTProtocolNameLength + 2 + 4 + MQTTClientIDLength + 2 + MQTTUsernameLength + 2 + MQTTPasswordLength + 2;
X = datalength;
do {
encodedByte = X % 128;
X = X / 128;
if (X > 0) {
encodedByte |= 128;
fprintf(uart2,encodedByte); //Serial.write(encodedByte);
while (X > 0);
fprintf(uart2,(MQTTProtocolNameLength >> 8)); //! Serial.write(MQTTProtocolNameLength >> 8);
fprintf(uart2,(MQTTProtocolNameLength & 0xFF)); //! Serial.write(MQTTProtocolNameLength & 0xFF);
fprintf(uart2,(MQTTProtocolName)); //! Serial.print(MQTTProtocolName);
fprintf(uart2,(MQTTLVL)); //! Serial.write(MQTTLVL); // LVL
fprintf(uart2,(MQTTFlags)); //! Serial.write(MQTTFlags); // Flags
fprintf(uart2,(MQTTKeepAlive >> 8)); //! Serial.write(MQTTKeepAlive >> 8);
fprintf(uart2,(MQTTKeepAlive & 0xFF)); //! Serial.write(MQTTKeepAlive & 0xFF);
fprintf(uart2,(MQTTClientIDLength >> 8)); //! Serial.write(MQTTClientIDLength >> 8);
fprintf(uart2,(MQTTClientIDLength & 0xFF)); //! Serial.write(MQTTClientIDLength & 0xFF);
fprintf(uart2,(MQTTClientID)); //! Serial.print(MQTTClientID);
fprintf(uart2,(MQTTUsernameLength >> 8)); //! Serial.write(MQTTUsernameLength >> 8);
fprintf(uart2,(MQTTUsernameLength & 0xFF)); //! Serial.write(MQTTUsernameLength & 0xFF);
fprintf(uart2,(MQTTUsername)); //! Serial.print(MQTTUsername);
fprintf(uart2,(MQTTPasswordLength >> 8)); //! Serial.write(MQTTPasswordLength >> 8);
fprintf(uart2,(MQTTPasswordLength & 0xFF)); //! Serial.write(MQTTPasswordLength & 0xFF);
fprintf(uart2,(MQTTPassword)); //! Serial.print(MQTTPassword);
void SendPublishPacket() {
memset(str, 0, 250);
str="57";
topiclength = sprintf((char * ) topic, MQTTTopic);
datalength = sprintf((char * ) str, "%s%u", topic, Counter);
fprintf(uart2,0x30); //Serial.write(0x30);
X = datalength + 2;
do {
X = X / 128;
if (X > 0) {
encodedByte |= 128;
while (X > 0);
fprintf(uart2,(topiclength >> 8)); //! Serial.write(topiclength >> 8);
fprintf(uart2,(topiclength & 0xFF)); //! Serial.write(topiclength & 0xFF);
fprintf(uart2,(str)); //! Serial.print(str);
void SendSubscribePacket() {
topiclength = strlen(MQTTTopic);
datalength = 2 + 2 + topiclength + 1;
fprintf(uart2,0x82); //Serial.write(0x82);
X = datalength;
do {
X = X / 128;
if (X > 0) {
encodedByte |= 128;
while (X > 0);
fprintf(uart2,(MQTTPacketID >> 8)); //! Serial.write(MQTTPacketID >> 8);
fprintf(uart2,(MQTTPacketID & 0xFF)); //! Serial.write(MQTTPacketID & 0xFF);
fprintf(uart2,(MQTTTopic)); //! Serial.print(MQTTTopic);
fprintf(uart2,(MQTTQOS)); //! Serial.write(MQTTQOS);
Here is the original:
http://www.raviyp.com/arduino-mqtt-library-with-publish-and-subscribe-example/ |
Posted: Mon Apr 20, 2020 4:44 pm |
Here is my opinion of how the SendConnectPacket() routine should be
translated to CCS, with test program:
#include <18F46K22.h>
#device PASS_STRINGS=IN_RAM
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#include <string.h>
#define LED PIN_B0
unsigned int16 Counter = 0;
unsigned int32 datalength, CheckSum, RLength;
unsigned int16 topiclength;
signed char str[250];
signed int16 X;
unsigned int16 MQTTProtocolNameLength;
unsigned int16 MQTTClientIDLength;
unsigned int16 MQTTUsernameLength;
unsigned int16 MQTTPasswordLength;
const char MQTTHost[30] = "m10.cloudmqtt.com";
const char MQTTPort[10] = "17434";
const char MQTTClientID[20] = "ABCDEF";
const char MQTTTopic[30] = "valetron";
const char MQTTProtocolName[10] = "MQIsdp";
const char MQTTLVL = 0x03;
const char MQTTFlags = 0xC2;
const unsigned int16 MQTTKeepAlive = 60;
const char MQTTUsername[30] = "dxxkgkpp";
const char MQTTPassword[35] = "qAUZBdaSIULx";
const char MQTTQOS = 0x00;
const char MQTTPacketID = 0x0001;
void SendConnectPacket(void)
printf("\r\nAT+CIPSEND\r\n");
delay_ms(3000);
putc(0x10);
X = datalength;
do{
X = X / 128;
if(X > 0) {
encodedByte |= 128;
putc(encodedByte);
}while (X > 0);
putc(MQTTProtocolNameLength >> 8);
putc(MQTTProtocolNameLength & 0xFF);
printf(MQTTProtocolName);
putc(MQTTLVL); // LVL
putc(MQTTFlags); // Flags
putc(MQTTKeepAlive >> 8);
putc(MQTTKeepAlive & 0xFF);
putc(MQTTClientIDLength >> 8);
putc(MQTTClientIDLength & 0xFF);
printf(MQTTClientID);
putc(MQTTUsernameLength >> 8);
putc(MQTTUsernameLength & 0xFF);
printf(MQTTUsername);
putc(MQTTPasswordLength >> 8);
putc(MQTTPasswordLength & 0xFF);
printf(MQTTPassword);
putc(0x1A);
SendConnectPacket();
while(TRUE);
cvargcal
Posted: Mon Apr 20, 2020 5:24 pm |
| PCM programmer wrote: | Here is my opinion of how the SendConnectPacket() routine should be
while(TRUE);
Ohh now the data look so good..... I did the connection and can send data across mqtt:
10 2C 00 06 4D 51 49 73 64 70 03 C2 00 3C 00 06
41 42 43 44 45 46 00 08 64 78 78 6B 67 6B 70 70
Thank you |
microjack64
| Arduino printf or putc in pic ccs |
Posted: Mon Apr 20, 2020 11:32 pm |
I was doing the next Arduino Nano but it has many issues. Now i am using PIC,
but i have same issues. Your code really helped me. Please more code or examples. Add for mqtt and how to send data using esp. _________________ mini engineer at https://projectiot123.com |
