i2c Speed Setting
Goto page 1, 2  Next
emaxxenon
i2c Speed Setting
PostPosted: Wed Feb 26, 2020 8:36 am     Reply with quote
3 speeds are mentioned for i2c.
Standard
100 KHz / 5kΩ – 10kΩ
Fast Mode
400 KHz / 2kΩ – 5kΩ
High Fast Mode
3.4 MHz / 1kΩ
These are the resistors to be connected to hardware.
So what should I do in software?
I couldn't understand this topic.
PostPosted: Wed Feb 26, 2020 8:59 am     Reply with quote
We need to know which PIC and what I2C device you're using !! Add a 'link' to the 'device',either the chip or module. It's important as 'modules' tend to have 'other' parts on them, like pullup resistors or logic level conversions.
Jay
edit: I was first thinking the resistances were related to the speeds, bus loading ? BUT maybe some I2C 'device' or 'module' uses resistors to select the speed for that device, somewhat like USB devices have.....
Re: i2c Speed Setting
PostPosted: Wed Feb 26, 2020 11:07 am     Reply with quote
Download the CCS manual.
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Go to the #use i2c section. Look at these parameters for #use i2c():
FAST - Use the fast I2C specification.
FAST=nnnnnn - Sets the speed to nnnnnn hz
SLOW - Use the slow I2C specification
emaxxenon
PostPosted: Wed Feb 26, 2020 11:38 pm     Reply with quote
Jay
Thanks for your answer.
PIC18F25K22 - 20MHz oscillator.
I use SCL and SDA pins.
But what I want to know is whether I will add software for speed.
Thank you. I really couldn't see this file.
I'm looking at.
Edit:
I work with 1 master and 16 slaves.
#use i2C (.................FAST=3400000)
Will it run at 3.4mhz with this setting?
1kΩ -> Do I need to add this resistance?
and am I going to set this only to the master pic?
gjs_rsdi
PostPosted: Thu Feb 27, 2020 12:05 am     Reply with quote
Hi emaxxenon
I am using PIC18F26K22, same like you are using but with larger memory.
I am using:
#use I2C(MASTER, FAST=400000, I2C1, STREAM=I2CPORT)//I2C1 hardware used
Never used faster than 400000.
You should think using higher speed for the PIC with FAST=3400000 in my opinion.
Regarding pull-up resistors. You need the resistors on the SCL and SDA line to the VDD. One resistor per line.
Take in consideration also that in I2C the lines between the Master and Slave have to be short. All the 16 slave will be on the same board as the Master?
Best wishes
Joe
PostPosted: Thu Feb 27, 2020 12:19 am     Reply with quote
Going over 400KHz, requires active pull-ups, not just pull up resistors.
Look at the LTC1694 for a typical device.
Problem is that to have a low enough resistance to give fast rise times
takes more current than the I2C devices support driving.
The active pullups dynamically switch on the edges to give faster edges
without needing higher currents at the high/low states.
HS mode (never seen it called 'High Fast mode'), requires active pullups as
part of it's specification.
emaxxenon
PostPosted: Thu Feb 27, 2020 2:14 am     Reply with quote
gjs_rsdi wrote:
Hi emaxxenon
I am using:
Best wishes
Joe
I am using P82b715.
16 slave pic will not be in the same place. I did my tests working.
The resistors I am using now are 4.7K.
I think it is used with 400Khz in this way.
#use I2C(MASTER, FAST=400000, ....)
Am I going to set this only to the master pic?
Would it be a problem if I lower my resistance value and run it at higher speeds?
gjs_rsdi
PostPosted: Thu Feb 27, 2020 2:58 am     Reply with quote
Hi emaxxenon
For FAST=400000 I am using, 5V VDD I have 2K7 on both SCL and SDA.
It works perfect on the same board, a few centimeters distance.
The P82b715 is an I2C buffer for longer distance, still you will need pull-ups close to the PIC on ech side before the buffers in my opinion.
Page 9 Figure 4 don't show pull-ups but I think you still need them.
As Ttelmah wrote, at higher speeds you need the LTC1694 as active pull-ups.
The speed is set for the Master as he provides the clock to the slave. the slave will be like:
#use i2c(Slave,Address=0xB0,I2C1)//I2C1 module, automatically hardware
I use the address 0xB0 but you can chose any address as you wish, one for each slave.
Best wishes
Joe
emaxxenon
PostPosted: Thu Feb 27, 2020 3:10 am     Reply with quote
gjs_rsdi wrote:
Hi emaxxenon
Best wishes
Joe
Hi, thanks for your answer.
The distance between the pic I use and p82b715 is close.
But the 4.7Ks are next to the p82b715.
I guess it doesn't cause much trouble.
A similar card is 2 meters away and communicates.
I can't add a new component to the circuit, but I can replace the 4.7K with a smaller resistor. But this is not a solution, as far as I understand.
PostPosted: Thu Feb 27, 2020 4:19 am     Reply with quote
4K7 will only work at 400KHz, if the capacitance of the bus is very low (<50pF).
For a 100pF bus the maximum value is 2K5.
So 2K7 will handle perhaps 90pF OK.
I think the term you use is a result of confusing two different parts of the
I2C spec. There are four different I2C speed 'specs'.
Standard (up to 100Kb/sec)
Fast (up tp 400Kb/sec)
Fast plus (up to 1Mb/sec)
High speed (up to 3.4Mb/sec)
Fast plus can be done with resistive pull ups (though active is recommended)
High speed requires active pull ups.
For a 2m distance, you will run into capacitance problems unless you use
lower speeds or much more aggressive pull ups.
emaxxenon
PostPosted: Thu Feb 27, 2020 4:49 am     Reply with quote
I will consider your suggestions.
Will the P82B715 I use for communication not provide this?
https://www.nxp.com/docs/en/data-sheet/P82B715.pdf
I adjusted it according to this scheme.
Should I change the resistance value to <2K5 ?
PostPosted: Thu Feb 27, 2020 5:06 am     Reply with quote
On what you show here the pull ups on the long part of the I2C bus are only
470R. This is a much more capable value for this.
However you need to look at what the quoted capacitance of the
wire is, and then add all the capacitances of all the connected transceivers.
Assuming this is OK.
Then the only problem will be if the capacitance of the short sections between
the transceivers and the devices are too much. The chip pins themselves
will give something like 5pF at each end of the section. Even a couple of
inches of track will probably have perhaps 10pF capacitance, so the 4K7's
don't give a lot of margin.
Remember also capacitances can start to shoot up if the units get damp....
emaxxenon
PostPosted: Thu Feb 27, 2020 5:24 am     Reply with quote
Thank you for the information.
PostPosted: Thu Feb 27, 2020 5:27 am     Reply with quote
I have to ask do you really NEED the very,very high speed ? Do you have a LOT of data that must be transferred all the time, or just a few bytes? Is the data from say sensors(on/off switches) or remote ADC units ? What is the physical layout of the 'slaves'( how close ? on same PCB ??)
Can you split the 16 slaves into 2 or 4 groups ?
I2C may not be the ideal or best choice for the communications.
emaxxenon
PostPosted: Thu Feb 27, 2020 6:13 am     Reply with quote
I don't need a very, very high speed.
But if there is a possibility, I would like to try it.
//CARD1
for(int i=0; i<16; i++)
//Receiver IR
i2c_start();
i2c_write(R_SLAVE1_W);
i2c_write(i);
i2c_stop();
//Transmitter IR
i2c_start();
i2c_write(T_SLAVE1_W);
i2c_write(i);
i2c_stop();
delay_us(10);
i2c_start();
i2c_write(R_SLAVE1_R);
R1_1 = i2c_read();
R1_2 = i2c_read(0);
i2c_stop();
//CARD2
//Receiver IR
i2c_start();
i2c_write(R_SLAVE2_W);
i2c_write(i);
i2c_stop();
//Transmitter IR
i2c_start();
i2c_write(T_SLAVE2_W);
i2c_write(i);
i2c_stop();
delay_us(10);
i2c_start();
i2c_write(R_SLAVE2_R);
R2_1 = i2c_read();
R2_2 = i2c_read(0);
i2c_stop();
//CARD3
I have such a literacy process.
There are 16 slaves. 8 receiver IR - 8 transmitter IR cards.
There are 16 IR leds on each card. Toplamda 2x128 adet led bulunur.
I scan them by opening and closing them respectively.
1.CARD -> Receiver & Transmitter 1.IR on...off, 2.IR on...off, .... 16.IR on...off
1.CARD send to Master "1.Card 16 IR LED status"
2.CARD -> Receiver & Transmitter 1.IR on...off, 2.IR on...off, .... 16.IR on...off
2.CARD send to Master "2.Card 16 IR LED status"
The master only tells you which led to burn.
And it learns the status of IR led from the receiver.
I have to use I2C because the circuit is prepared.
The change I can make is resistance values or minor software changes.
Goto page 1, 2  Next
Page 1 of 2
