voltage divider for pic 16f88
josepic
PostPosted: Tue Feb 18, 2020 10:03 am     Reply with quote
Hello friends best regards.
I have made the following code for pic 16f88, it is a voltmeter from 0 to 51Vdc, but I need to make a voltage divider to visualize the voltage on the 16x2 lcd and that this voltage is the same as the voltmeter of the main source.
I hope you can help me thanks.
#include <16f88.h>
#device adc=10//Resolucion del ADC
#use delay (clock=4M)
#fuses NOWDT,INTRC,NOMCLR,NOLVP,CPD,WRT,PROTECT
#define LCD_ENABLE_PIN    PIN_B2
#define LCD_RS_PIN        PIN_B0
#define LCD_RW_PIN        PIN_B1
#define LCD_DATA_4        PIN_B4
#define LCD_DATA_5        PIN_B5
#define LCD_DATA_6        PIN_B6
#define LCD_DATA_7        PIN_B7
#include <lcd.c>
    //Programa Principal//
  unsigned long valor=0;//Declaracion de variables
  float voltaje;                        //Variable que contendra el resultado
    //Se habilita el A/D y se declara el PORT a usar//
  setup_adc( ADC_CLOCK_INTERNAL );
  setup_adc_ports(sAN0);
  set_adc_channel(0);
      //Se inicia la LCD//
lcd_gotoxy(1,1);
lcd_putc("Iniciando.....");
delay_ms(2000);
lcd_putc("\f" ) ;
lcd_gotoxy(4,1);
lcd_putc("VOLTIMETRO");
  do//Bucle
      valor = read_adc();
      voltaje = (float)valor*0.004882812*10.44 ;
    lcd_gotoxy(5,2);
    printf(lcd_putc,"%g V",voltaje);
  }while(true);
Question
jose
PostPosted: Tue Feb 18, 2020 10:17 am     Reply with quote
I'd try a 9K---1K voltage divider, using 1% resistors. Be sure to test BEFORE attaching to PIC though.
Also your selection of adc_clock_internal is wrong. See Table 12-1 of the datasheet, NOTE 2.
josepic
PostPosted: Tue Feb 18, 2020 10:42 am     Reply with quote
also your selection of adc_clock_internal is wrong. See Table 12-1 of the datasheet, NOTE 2.
Tell me why the adc_clock_internal instruction is incorrect?
Question Question
PostPosted: Tue Feb 18, 2020 10:45 am     Reply with quote
Please See and read Table 12-1 of the datasheet, NOTE 2.
josepic
PostPosted: Tue Feb 18, 2020 10:49 am     Reply with quote
On which datasheet page?
Question Question
PostPosted: Tue Feb 18, 2020 11:18 am     Reply with quote
Page 118 of my copy of the datasheet. It's chapter 12, ADC, section 12-2, selecting the ADC clock.
josepic
PostPosted: Tue Feb 18, 2020 12:08 pm     Reply with quote
I just read page 118 and Note 2, I go back and insist if the instruction had an error, would the code not compile me or not?
Question Question
PostPosted: Tue Feb 18, 2020 4:58 pm     Reply with quote
Please post your program so we can see what you did.
PostPosted: Wed Feb 19, 2020 3:27 am     Reply with quote
For your clock frequency, the correct ADC setup line is:
setup_adc( ADC_CLOCK_DIV_8 );
This should not give an error.
The code will compile with the wrong setting. The compiler only checks
for C syntax errors, not chip functional errors. You can select a wrong
clock, or perform output to a pin wired as an input, and the compiler
will not complain. These faults need you to find them....
The internal ADC clock, will actually 'work', but the ADC accuracy will
be badly degraded.
josepic
PostPosted: Wed Feb 19, 2020 8:48 pm     Reply with quote
I have published the code and I have corrected the correct instruction, I have also solved the voltage divider.
Thanks for the help
Wink
