colesha
| Failure to come out of the loop from a sub menu |
Posted: Fri Feb 14, 2020 5:57 am |
am trying to make a menu function, it is working well but once i select the main menu to enter the sub menu, once in there, i can not go back to the main menu. I tried the tutorial on http://www.magusporta.com/tips/menu_lcd/menu_lcd.html but it is using an encoder which kind of gave me had time to replace the encoder switch with push buttons and internal interrupt.
Here is the entire code. Kindly help. Thanks
#include <16f887.h>
#device adc=10
#device *=16
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOBROWNOUT //Reset when brownout detected
#use fast_io(A)
#include <flex_lcd4201.c> //you can use your 4x20 lcd driver
//************************ Varriables Declaration ***************************//
int menu;
int Screen ;
//************************ Cursor ***************************//
void graphics() { //User defined graphics: cursor and arrows
// Cursor: 0 //
lcd_send_byte(0,0b01000000);
lcd_send_byte(1,0b00010000);
lcd_send_byte(1,0b00011000);
lcd_send_byte(1,0b00011100);
lcd_send_byte(1,0b00011110);
lcd_send_byte(1,0b00000000);
//************************ Satellite Sub Menus/Functions ***************************//
void Function_A(void) {
lcd_putc("\fScn A (Function A)\n");
lcd_putc("Push tO RTn to menu");
if(input(Pin_D7)==1)
void Function_B() {
lcd_putc("\fScreen B (Function B)\n");
lcd_putc("Push to rtn to menu");
void Function_C() {
lcd_putc("\fScrn C (Function C)\n");
//************************ Navigate menu(Display Curssor) ***************************//
menu_screen(int8 navigate){ //menu_extensions
switch(navigate){
case 0:
lcd_gotoxy(1, 1); //go to raw 1 and
lcd_putc(0); //display curssor
lcd_gotoxy(1,4); // go to raw 4
lcd_putc(" "); //remove curssor from raw 4
menu=0; // First menu
case 1:
lcd_gotoxy(1, 2); //go to raw 2 and
lcd_gotoxy(1,1); //go to raw 1 and
lcd_putc(" "); //remove curssor from raw 1
menu=1; // Second menu
case 2:
lcd_gotoxy(1, 3); //go to raw 3 and
lcd_gotoxy(1,2); //go to raw 2 and
lcd_putc(" "); //remove curssor from raw 2
menu=2; // Third menu
case 3:
lcd_gotoxy(1, 4); //go to raw 4 and
lcd_gotoxy(1,3); //go to raw 3 and
lcd_putc(" "); //remove curssor from raw 3
menu=3; // Fouth menu
//-------Test prgram to flash led---------//
void status()
output_high(PIN_D1);;
output_low(PIN_D1);
//************************ Main program ***************************//
void main(){
//setup_psp(psp_disabled);
setup_spi(spi_ss_disabled);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(t1_disabled);
setup_timer_2(t2_disabled,0,1);
setup_adc(adc_clock_internal);
setup_ccp1(ccp_off);
setup_ccp2(ccp_off);
set_adc_channel( 0 );
delay_us(20);
float actual_temp, setpoint_temp, temp;
setup_adc(ADC_CLOCK_DIV_8 );
setup_adc_ports(sAN4);
graphics();
delay_ms(1250);
menu=0;
//-------Screen Panes---------//
screen:
lcd_gotoxy(1, 2);
printf(lcd_putc, "Main Screen");
printf(lcd_putc, "\nFor our Menu");
printf(lcd_putc, "\nImplemetation");
printf(lcd_putc, "\n.....................");
set_adc_channel(4);
delay_us(20);
actual_temp = read_adc();
temp = actual_temp*0.488281; // Calc. temperature
delay_ms(10);
lcd_gotoxy(1, 1);
printf(lcd_putc,"Tmp:%3.1f\x01C Set:%3.0f\x01C",temp, setpoint_temp);
//status();
//---------------------Main Menu----------------------------------------------------//
screen=0; //screen
if(input(PIN_B0)==1) // Menu key
lcd_putc("\f"); // clear lcd;
lcd_gotoxy(2,1);
lcd_putc("Push to view scn A ");
lcd_gotoxy(2,2);
lcd_putc("Push to view scn B ");
lcd_gotoxy(2,3);
lcd_putc("Push to view scn C ");
lcd_gotoxy(2,4);
lcd_putc("Push Escape ");
//---------------------Navigate Main Menu----------------------------------------------------//
if(screen==0){
menu_screen(0);
if(input(PIN_D5)==1){ //Up button pressed actually does nothing
if(menu==4){
menu=0;
menu=menu;
menu_screen(menu);
if(input(PIN_D6)==1){ //Down button pressed to select next menu
if(menu==4){ // if at fouth raw
menu=0; // go back to first raw
menu=menu-1;
menu=menu+1;
menu_screen(menu);
screen=1;
delay_ms(200);
//---------------------SUB MENU Selection----------------------------------------------------//
if(input(PIN_a0)==1) //Enter to view sub Menu
switch(menu){
case 0: //Menu 1
while(1){
if(input(PIN_a0)==1){ //Press enter to view sub menu
//screen=0;
function_A();
case 1: // Menu 2
while(1){
if((input(PIN_a0)==1)&& (menu==1)){ //Press enter to view sub menu
function_B();
case 2: //Menu 3
while(1){
if((input(PIN_a0)==1)&& (menu==2)){ //Press enter to view sub menu
function_C();
//---------------------Exit MENU----------------------------------------------------//
case 3: //Exit Main menu
while(1){
if((input(PIN_a0)==1)&& (menu==3)){
lcd_putc("\f"); //clear lcd
goto screen;
default: break;
gjs_rsdi
Posted: Fri Feb 14, 2020 6:33 am |
Hi colesha
Your program as posted does not compile.
It gives | Quote: | Error 128 "PR887.c" Line 0(0,0): A #DEVICE required before this line
After removing "[" it gives 57 errors. the first:
| Quote: | *** Error 18 "PR887.c" Line 13(10,26): File can not be opened
Not in "C:\Program Files (x86)\PICC\devices\flex_lcd4201.c"
Not in "C:\Program Files (x86)\PICC\drivers\flex_lcd4201.c"
Not in source "flex_lcd4201.c"
Not in local "flex_lcd4201.c"
Tried to find flex_lcd4201.c on my PC, didn't find.
I have CCS PCM C Compiler, Version 5.062
Best wishes
Joe |
Posted: Fri Feb 14, 2020 7:49 am |
Colesha, please learn how to do code blocks.
You do it like this, except with no spaces before and after the word 'code':
[ code ]
#include <16f887.h>
#device adc=10
#device *=16
#FUSES NOPROTECT
[ /code ]
Edit your post and fix the code blocks.
Use the preview button to check if you did it correctly, before submitting it. |
colesha
Posted: Fri Feb 14, 2020 8:14 am |
| gjs_rsdi wrote: | Hi colesha
Best wishes
Joe |
hello i have reproduced the error and found that i posted wrongly, when you copied the code, you included the '[' before the #include <16f887.h>, sorry about that.
The flex_lcd4201.c is a customized version of the flex_lcd420 driver which i found on this blog, i just renamed it so that it can match my development board, however you can use any 4x20 lcd driver you have.
let me re-post the code |
colesha
Posted: Fri Feb 14, 2020 8:24 am |
| PCM programmer wrote: | Colesha, please learn how to do code blocks.
[ code ]
#include <16f887.h>
#device adc=10
#device *=16
#FUSES NOPROTECT
[ /code ]
Thanks for the direction, i have edited the post. Am new here. |
colesha
Posted: Fri Feb 14, 2020 8:27 am |
Best wishes
Joe |
Sir , i have edited the post, please try again.
Thanks |
Posted: Fri Feb 14, 2020 9:19 am |
Your problem is this (and the other similar bits).
switch(menu){
case 0: //Menu 1
while(1){
//This instruction means 'loop for ever'
//screen=0;
function_A();
//Function A exits, but you are still 'stuck' in the 'for ever' loop.....
//Consider instead:
int1 loop_flag; //global variable
switch(menu){
case 0: //Menu 1
loop_flag=TRUE;
while(loop_flag){
//screen=0;
function_A();
//Now if in function_A, when it exits, you set 'loop_flag=FALSE;' when
//it exits, it'll drop out of the loop.
Obviously you can use the same flag for all the functions and just add
the line to set this 'FALSE' when you want to drop out of the loop. |
colesha
Posted: Fri Feb 14, 2020 2:20 pm |
| Ttelmah wrote: | Your problem is this (and the other similar bits).
switch(menu){
case 0: //Menu 1
while(1){
//screen=0;
function_A();
//Consider instead:
switch(menu){
case 0: //Menu 1
loop_flag=TRUE;
while(loop_flag){
//screen=0;
function_A();
Thanks sir, it has really worked. Here is the final code:
#include <16f887.h>
#device adc=10
#device *=16
#use fast_io(A)
//************************ Variables Declaration ***************************//
int menu;
int Screen ;
// Cursor: 0 //
void Function_A() {
while(input(Pin_D7)==0)
loop_flag==False;
void Function_B() {
loop_flag==FALSE;
void Function_C() {
loop_flag=FALSE;
//************************ Navigate menu(Display Cursor) ***************************//
switch(navigate){
case 0:
lcd_putc(0); //display cursor
lcd_putc(" "); //remove cursor from raw 4
case 1:
lcd_putc(" "); //remove cursor from raw 1
case 2:
lcd_putc(" "); //remove cursor from raw 2
case 3:
lcd_putc(" "); //remove cursor from raw 3
menu=3; // Fourth menu
//-------Test program to flash led---------//
void status()
output_low(PIN_D1);
void main(){
delay_us(20);
graphics();
delay_ms(1250);
menu=0;
screen:
lcd_gotoxy(1, 2);
printf(lcd_putc, "\n Main Screen");
printf(lcd_putc, "\nimplementation");
set_adc_channel(4);
delay_us(20);
delay_ms(10);
lcd_gotoxy(1, 1);
//status();
screen=0; //screen
screen1:
lcd_gotoxy(2,1);
lcd_gotoxy(2,2);
lcd_gotoxy(2,3);
lcd_gotoxy(2,4);
if(screen==0){
menu_screen(0);
{ //ADD this line if you want to move back and forth in the name
/*if(input(PIN_D5)==1){ //Up button pressed actually does nothing
if(menu==4){
menu=0;
menu=menu;
menu_screen(menu);
if(menu==4){ // if at fourth raw
menu=menu-1;
menu=menu+1;
menu_screen(menu);
screen=1;
delay_ms(200);
switch(menu){
case 0: //Menu 1
loop_flag=TRUE;
while(loop_flag)
screen=0;
function_A();
case 1: // Menu 2
loop_flag=TRUE;
while(loop_flag){
screen=0;
function_B();
case 2: //Menu 3
loop_flag=TRUE;
while(loop_flag){
screen=0;
function_C();
while(1){
goto screen;
default: break;
goto screen1; //go back to the main menu
I added this line so that it can go back to the main menu so that it can act as a back key. But if removed the and left as before, it will go back to the home screen, so it can act as an escape key.
and this is how i managed to set the flag to get out of the sub menu:
void Function_A() {
loop_flag==False;
Once again thanks all. |
colesha
Posted: Tue Feb 18, 2020 4:06 pm |
switch(menu){
case 0: //Menu 1
while(1){
//screen=0;
function_A();
//Consider instead:
switch(menu){
case 0: //Menu 1
loop_flag=TRUE;
while(loop_flag){
//screen=0;
function_A();
Hi once again Ttelmah, i need some additional assistance. I want to make another sub menu in a selected menu similar to the main menu. For example, when i press the menu button, it brings the main menu. Now at the main menu, say i select function B. When function B is opened, i can scroll through its sub menu, maybe function B1, etc just like the main menu. How do you go about it ? Do i need to copy the entire menu code into function B ? |
Posted: Wed Feb 19, 2020 3:20 am |
Ideally write the 'menu' into a function. Make it be called with an array
of the text, and return the selection number made. Then you can just
have a basic switch selecting the required function with the result of this.
Then you can just call this in each place you need a 'menu'.  |
colesha
Posted: Wed Feb 19, 2020 10:45 am |
| Ttelmah wrote: | Ideally write the 'menu' into a function. Make it be called with an array
Hello, i just cant figure out this, kindly assist with some more guidance. |
