allenhuffman
Joined: 17 Jun 2019 Posts: 652 Location: Des Moines, Iowa, USA
| [Solved] Disable "May be missing a break" warnings |
Posted: Fri Jan 31, 2020 2:01 pm |
| Code: | | >>> Warning 242 "C:\Program Files (x86)\PICC\Drivers\math.h" Line 1799(10,11): May be missing a break |
On some compilers, there is an extension to tell the compiler it's okay to do things like this:
| Code: | switch (i)
case 1:
case 2:
case 4:
// do something
case 5:
// then do this
default:
CCS has warnings in the math.h file, and under GCC and other compilers you can add a special comment or keyword to tell the compiler it's intentional.
case 1: // Depending on GCC version, one of these used to work:
//fall through
//no break
case 2:
// stuff
In an effort to clean up some of our code, I want to eliminate compiler warnings, but since I get some in the CCS-provided header files, I'm not sure what to do there. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
Last edited by allenhuffman on Tue Feb 04, 2020 8:36 am; edited 4 times in total |
Posted: Fri Jan 31, 2020 2:20 pm |
| Quote: | #ignore_warnings
Syntax:
#ignore_warnings ALL
#IGNORE_WARNINGS NONE
#IGNORE_WARNINGS warnings
Elements:
warnings is one or more warning numbers separated by commas.
Description:
This function will suppress warning messages from the compiler.
ALL indicates no warnings will be generated.
NONE indicates all warnings will be generated. If numbers are listed then
those warnings are suppressed.
Examples:
#ignore_warnings 203
while(TRUE) {
#ignore_warnings NONE
allenhuffman
Posted: Mon Feb 03, 2020 11:06 am |
| PCM programmer wrote: | #ignore_warnings 203
while(TRUE) {
Fantastic - being able to selectively toggle it around certain code is exactly what I was after. Thank you.
EDIT: Odd. The same test code I built last week that showed warnings in math.h is showing none today. I must have imagined it. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Last edited by allenhuffman on Mon Feb 03, 2020 11:32 am; edited 1 time in total |
allenhuffman
Posted: Mon Feb 03, 2020 11:27 am |
In my case, we had some code where multiple cases would run the same code -- and this took care of those warnings:
| Code: | #ignore_warnings 242
case 'X':
case 'x':
#ignore_warnings none |
I got the 242 warning value from the error display (the help file didn't list numbers, just text/descriptions):
| Code: | | >>> Warning 242 "(path)\main.c" Line 657(21,22): May be missing a break |
(I did ask the programmer why not do 'switch(toupper(key))' and just check uppercase, but he had some situations where lower and upper did different things, and some where they did the same.
But nice to now have less warnings. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002. |
Posted: Mon Feb 03, 2020 1:06 pm |
| Honestly, 'toupper' uses a lot more code than the second switch... |
allenhuffman
Posted: Tue Feb 04, 2020 8:37 am |
| Ttelmah wrote: | | Honestly, 'toupper' uses a lot more code than the second switch... |
I think it's more of a "Clean Code" approach, removing extra code a human has to deal with. Being exposed to that at my last job was quite enlightening, though it can't apply in every embedded situation (where CPU cycles might be more critical, or RAM/ROM space is limited). _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
