320x240 graphic lcd (IC - ra8835)
ertansuluagac
PostPosted: Wed Jan 29, 2020 2:52 am     Reply with quote
Hi
I want to turn off the flashing cursor of 320x240 graphic lcd.
(IC- ra8835). I couldn't find a note about him in Datasheet? Would you appreciate if you could help?
Es
PostPosted: Wed Jan 29, 2020 3:24 am     Reply with quote
Don't know what driver you are using, so what commands you will need to
use, but the FC bits in the display control register handle this. These set
the flashing rate, and the four settings give cursor off, cursor on (not
flashing), and two flash rates. Obviously you need to select the first of
these options to disable the cursor.
ertansuluagac
PostPosted: Wed Jan 29, 2020 4:09 am     Reply with quote
the driver file I use.
#define GLCD_RST PIN_A5
#define GLCD_RD PIN_A1
#define GLCD_WR PIN_A0
#define GLCD_CS PIN_A2
#define GLCD_A0 PIN_A3
#DEFINE GLCD_DB0 PIN_B5
#DEFINE GLCD_DB1 PIN_B4
#DEFINE GLCD_DB2 PIN_B3
#DEFINE GLCD_DB3 PIN_B2
#DEFINE GLCD_DB4 PIN_B1
#DEFINE GLCD_DB5 PIN_B0
#DEFINE GLCD_DB6 PIN_C4
#DEFINE GLCD_DB7 PIN_C3
#define GLCD_WIDTH         320
#define GLCD_HEIGHT        240
#define GLCD_CHAR_WIDTH    8
#define GLCD_CHAR_HEIGHT   8
#define ON                 1
#define OFF                0
#define COMMAND_MODE   output_high(GLCD_A0);
#define DATA_MODE       output_low(GLCD_A0);
#DEFINE RA8835_GRAPHICSTART 0x2580
void GlcdPutData(INT8 data);
int8 TakeData(void);
void GLCD_WriteCommand(int8 commandToWrite);
void GLCD_WriteData(int8 dataToWrite);
int8 GLCD_ReadData(void);
void setCursorAddress(int16 addr);
void GlcdGotoTextXY(int16 x, int16 y);
void GlcdPutC(char c);
void FillText(char cara);
void FillGraphic(int1 parameter);
void glcd_RAinit(void);
int8 GLCD_ReadStatus(void);
void GlcdPutData(int8 data)
   output_bit(GLCD_DB0, bit_test(data,0));
   output_bit(GLCD_DB1, bit_test(data,1));
   output_bit(GLCD_DB2, bit_test(data,2));
   output_bit(GLCD_DB3, bit_test(data,3));
   output_bit(GLCD_DB4, bit_test(data,4));
   output_bit(GLCD_DB5, bit_test(data,5));
   output_bit(GLCD_DB6, bit_test(data,6));
   output_bit(GLCD_DB7, bit_test(data,7));
int8 TakeData(VOID)
   INT8 data = 0;
   data += input (GLCD_DB0);
   data += input (GLCD_DB1) * 2;
   data += input (GLCD_DB2) * 4;
   data += input (GLCD_DB3) * 8;
   data += input (GLCD_DB4) * 16;
   data += input (GLCD_DB5) * 32;
   data += input (GLCD_DB6) * 64;
   data += input (GLCD_DB7) * 128;
   RETURN data;
GlcdPutData(commandToWrite);
COMMAND_MODE
output_low(GLCD_WR);
output_low(GLCD_CS);
delay_cycles(1);
output_high(GLCD_WR);
output_high(GLCD_CS);
GlcdPutData(dataToWrite);
DATA_MODE
delay_cycles(1);
int8 tmp;
output_low(GLCD_RD);
delay_cycles(4);
tmp = TakeData();
output_high(GLCD_RD);
return tmp;
   output_high(GLCD_RST);
   //system set
   GLCD_WriteCommand(0x40);
   GLCD_WriteData(0x30);
   GLCD_WriteData(0x87);
   GLCD_WriteData(0x07);
   GLCD_WriteData(0x27);
   GLCD_WriteData(0x2F);
   GLCD_WriteData(0xEF);
   GLCD_WriteData(0x28);
   GLCD_WriteData(0x00);
   //scroll
   GLCD_WriteCommand(0x44);
   GLCD_WriteData(0xF0);
   GLCD_WriteData(0x80);
   GLCD_WriteData(0x25);
   GLCD_WriteData(0x4B);
   //HDOT SCR
   GLCD_WriteCommand(0x5A);
   //OVLAY
   GLCD_WriteCommand(0x5B);
   GLCD_WriteData(0x01);
   //erase all screen
   FillGraphic(OFF);
   FillText(' ');
   //DISP ON
   GLCD_WriteCommand(0x58);
   GLCD_WriteData(0x56);
   //CSRFORM
   GLCD_WriteCommand(0x5D);
   GLCD_WriteData(0x04);
   GLCD_WriteData(0x86);
   //DISP ON
   GLCD_WriteCommand(0x59);
   //CSDIR
   GLCD_WriteCommand(0x4C);
   //CSRW
   setCursorAddress(0x0000);
   long count;
   //set cursor to 2580h
   setCursorAddress(0x2580);
   //put 00h in all graphic space
   count = 9600;
   GLCD_WriteCommand(0x42);
   while(count != 0)
       GLCD_WriteData(0xFF * parameter);
      count--;
   long count;
   //set cursor to 0000h
   //put 00h in all text space
   count = 1200;
   while(count != 0)
       GLCD_WriteData(cara);
      count--;
   GLCD_WriteData(c);
//x and y : 1 to max
   int16 adress = 0;
   adress = (y-1)*40;
   adress = adress+ x-1;
   setCursorAddress(adress);
   int8 adress;
   GLCD_WriteCommand(0x46);
   adress = addr & 0xFF;
   GLCD_WriteData(adress);
   adress = addr >> 8;
void GLCD_Pixel(int16 x,int16 y, int1 color)
int8 tmp = 0;
int16 address = 0;
address = RA8835_GRAPHICSTART + (40 * y) + (x/8);
setCursorAddress(address);
GLCD_WriteCommand(0x43);
tmp = GLCD_ReadData();
if(color == ON)
  tmp |= (1 << (7 - (x % 8)));
  tmp &= ~(1 << (7 - (x % 8)));
GLCD_WriteData(tmp);
void GLCD_GraphicGoTo(int16 x,int16 y)
setCursorAddress(RA8835_GRAPHICSTART + (y * 40) + x/8);
int8 tmp;
delay_cycles(1);
tmp = takedata();
return tmp;
Es
PostPosted: Wed Jan 29, 2020 4:22 am     Reply with quote
OK:
   GLCD_WriteData(0x87); //Change this to 0x84
I think that is right.
ertansuluagac
PostPosted: Wed Jan 29, 2020 4:37 am     Reply with quote
I've tried. It not happened and the cursor is still blinking. Writings on the screen are broken.
Es
PostPosted: Wed Jan 29, 2020 5:05 am     Reply with quote
OK. I must have got the wrong setting. You are going to have to work through
the driver and work out which register each part is setting, and find the FC
bits. I know these are what do the change (have used the display on
another processor), but not how your driver works.
PostPosted: Wed Jan 29, 2020 6:05 am     Reply with quote
this code....
//CSRFORM
Controls the 'blinking' BUT it doesn't agree with a datasheet I downloaded ! I don't use that GLCD but I'd change the 0x86 to 0x87 and see what happens.
I don't KNOW if this driver was actually written FOR this GLCD device.
PostPosted: Wed Jan 29, 2020 8:18 am     Reply with quote
Have to disagree.
The CSRFORM setting controls the size of the cursor, not it's visibility.
You can change the number of pixels and the number of lines, but '0' for
the number of pixels is illegal,so you can't make it disappear.
I remember playing with this.
The only one I found to make it disappear was the FC setting.
It should be the display on/off command last two bits.
Just checked the code again, and this is the right part:
//DISP ON
GLCD_WriteData(0x56); //Change to 0x54
Currently '2' is being put into these bits, which is flash at about 2HZ.
I must admit I always prefer to use #defines for all the register name
constants, since this avoids me finding the wrong register... Smile
ertansuluagac
PostPosted: Wed Jan 29, 2020 8:27 am     Reply with quote
Yes, it happened. Thank you very much.
Es
PostPosted: Wed Jan 29, 2020 9:26 am     Reply with quote
arrrgh....
I 'assumed' CRSFORM of the driver was the SAME as CRSFORM in the datasheet, silly me..... chapter 6-3, table 9 is what I was looking at
DISP ON should only turn the entire display on or off...
It seems there's 2 bytes that are used, 1st for 'display control', the 2nd for 'cursor' control
What's missing from the datasheet I downloaded is a nice CHART of 'registers' and their bits.... It'd also be nice if they included a 'typical' example...
sigh, I'm getting too old for this ..... Smile
Jay
PostPosted: Wed Jan 29, 2020 12:56 pm     Reply with quote
It's funny when you look at the quality of some datasheets in the past,
then look at the current offerings.
Whimpering becomes compulsory in some cases.... Very Happy
I had fun getting this controller to work.
