rs232 in header
Goto page 1, 2  Next
sebalitter
rs232 in header
PostPosted: Thu Jan 23, 2020 10:35 pm     Reply with quote
Hello
This code shows me those errors:
Error#7 Invalid Pre-Processor directive Invalid Pin
Error#12 Undefined identifier SERIAL_GPS
What I'm doing wrong?
fases.c
// Voltimetro trifasico
#include "fases_header.h"
//#define VSS_VREF
//#define VREF_ADC_1v024
#INT_RDA
void  RDA_isr(void)
   int8 d;
   d=0;
   d=getchar(SERIAL_GSM);
   clear_interrupt(INT_RDA);
void main (void)
    inicializacion();
    //int8 posicion=0;
        setup_adc_ports(sAN0|sAN2|sAN3);
        setup_adc(ADC_CLOCK_DIV_2);
        voltajes[0] = medir_voltaje(0);
        voltajes[1] = medir_voltaje(2);
        voltajes[2] = medir_voltaje(3);
        lcd_gotoxy(0,1);
        printf(lcd_putc," Vr    Vs    Vt");
        lcd_gotoxy(0,2);
        printf(lcd_putc,"%3.0lu    %3.0lu   %3.0lu",voltajes[0], voltajes[1], voltajes[2]);
#include <16F1823.h>
#device adc=10
//#device PASS_STRINGS = IN_RAM
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                   //Master Clear pin enabled
#use delay(clock=16M)            //Configuracion reloj interno
#PIN_SELECT U1TX=PIN_C4
#PIN_SELECT U1RX=PIN_C3
#use rs232(UART, BAUD=9600, PARITY=N, BITS=8, stream=SERIAL_GSM , errors)
#use i2c(Master,Fast=100000, sda=PIN_C1, scl=PIN_C2,force_sw)
#include <i2c_Flex_LCD.c>
#define PROM 1500
#define TELEFONO "1565404122"
int16 voltajes[3];
void inicializacionSIM800L(void)
    int cont;
    puts("A",SERIAL_GSM);  //para sincronizar el baudrate del SIM 900
    delay_ms(300);
    putchar(0x0d,SERIAL_GSM);
    delay_ms(3000);
    for(cont=0;cont<5;cont++)   // mando varios AT para el autobauding
        puts("AT",SERIAL_GSM);
        delay_ms(300);
        delay_ms(200);
    puts("AT+CMGF=1\r",SERIAL_GSM);  // configuro para que trabaje en modo texto
    puts("AT\r",SERIAL_GPS);
    puts("AT+CGPSPWR=1\r",SERIAL_GPS);
    delay_ms(300);
    puts("AT+CGPSRST=0\r",SERIAL_GPS);
    delay_ms(3000);
    return;
void inicializacion(){
    lcd_init();
    lcd_backlight_led(ON); //Enciende la luz de Fondo
    inicializacionSIM800L();
    lcd_clear();  //Limpia el LCD
    printf(lcd_putc, "\f");
    enable_interrupts(INT_RDA);
void mandar_SMS(char *numero , char *mensaje)
    //char *serial_gsm;
    //sprintf( serial_gsm ,"\n\r LDR Analog Value: %.0f \n\r PANIC Status: %d \n\r TEMP Analog Value: %.0f \n\r X/Y/Z Accelerometer  %.0f : %.0f : %.0f \n\r",ADC1, input(PANIC),grados,i,a,w);
    //PIN_ON(LED);
    //delay_ms(300);
    //printf(usb_cdc_putc, "\r\nAT+CMGS=\"%s\"\r", numero);
    fprintf(SERIAL_GSM, "AT+CMGS=\"%s\"\r", TELEFONO);
    delay_ms(300);
    //fputs(serial_gsm,SERIAL_GSM);
    fprintf(SERIAL_GSM,"\n\r Vr: %3.0lu  \n\r Vs :%3.0lu \n\r Vt: %3.0lu",voltajes[0], voltajes[1], voltajes[2]);
    //fprintf(SERIAL_GSM, "AT+CMGS=\"%s\"\r", numero);
    fprintf(SERIAL_GSM,"%c",0x1a);
    //PIN_OFF(LED);
int16 medir_voltaje(int8 channel){
    int32 acum=0;
    int16 Vmedio=0, i=0;  //, Voltaje=0;
    for(i=0;i<PROM;i++)
         set_adc_channel(channel);
         delay_us(100);
         acum+=read_adc();
    Vmedio=acum/PROM;
    //Voltaje=;
    //lcd_gotoxy(1,1);
    //printf(lcd_putc,"Vr= %lu V",Voltaje);
    return (Vmedio*3.594);
Thanks!
PostPosted: Thu Jan 23, 2020 11:52 pm     Reply with quote
Hint:
UART != UART1
#USE RS232 needs a UART number.
sebalitter
PostPosted: Fri Jan 24, 2020 3:06 am     Reply with quote
Ttelmah wrote:
Hint:
UART != UART1
i changed to UART1 using the conventional ports
Tx: Pin C4
Rx: Pin C5
#use rs232(UART1, BAUD=9600, PARITY=N, BITS=8, stream=SERIAL_GSM , errors)
do you know if i need something else to send a message in sim800L because its not sending anything.
PostPosted: Fri Jan 24, 2020 5:37 am     Reply with quote
Always best to start with the hardware
1) what is the VDD of the PIC ?
2) what is the VDD of the SIM800L?
3) is the SIM800L a 'chip' or a 'module' ?
4) What is the rating of the power supply in amps ?
sebalitter
PostPosted: Fri Jan 24, 2020 5:56 am     Reply with quote
Hello , thanks for the quick answer .
PIC16F1823 and SIM800L are connected to the same power ( 5v , 1.25A)
Module GSM SIN800L (Rohs)
[img]
http://g03.a.alicdn.com/kf/HTB1duFfKVXXXXXGaXXXq6xXFXXXq/High-Quality-SIM800L-font-b-GPRS-b-font-GSM-Board-Quadband-QUAD-BAND-L-shape-font.jpg
[/img]
i did something like this
#INT_RDA
void  RDA_isr(void)
   int8 d;
   d=0;
   dato_recibido[con_recepcion] = d;
   con_recepcion++;
   if(con_recepcion>19)
       con_recepcion=0;
   //lcd_gotoxy(0,1);
  // printf(lcd_putc, "%c",d);
and show it in main..
if(con_recepcion>18){
            lcd_gotoxy(0,1);
            printf(lcd_putc,"%s",dato_recibido);
            delay_ms(5000);
but it didnt show anything.
PostPosted: Fri Jan 24, 2020 5:59 am     Reply with quote
Is that module designed to be operated at 5 volts ?
Most peripheral devices are 3 volts and need 'logic level converters' to properly connect to 5 volt PICs.
If you have a 'link' to the module we can check.
hmm, my 'guy instinct' is that you should have at least a 2.5 amp power supply. most of these 'wireless' module need a LOT of current to transmit. whatever the datasheet says DOUBLE it ! You need a good reservoir of electrons !
As for software, check with the mfrs website / dtasheet. there should be some basic 'write to a register, read to confirm' code. Assuming you didn't write the 'driver' code, ask that programmer or check the website/forum for Q&A about it or use Google for THAT device, version of PCB may be a problem ? Code written for V1.2 versus PCB is V2.4.
Jay
sebalitter
PostPosted: Fri Jan 24, 2020 6:08 am     Reply with quote
Jay
it has a VCC input , it says 5v on the board.
[url]
https://irishelectronics.ie/SIM800L-V20-5V-Wireless-GSM-GPRS-MODULE
[/url]
PostPosted: Fri Jan 24, 2020 6:39 am     Reply with quote
hmm I saw this. about 1/2 way down that webpage....
•Embedded AT (optional)
That to me says 'AT command set is an OPTION' though it could mean something totally without the actual datasheet I can't tell.
You should try a simple 'loopback' test to confirm the PIC is running and sending/reciving serial data.
There's 2 possible problems
1) The PIC is not running properly
or
2) The SIM is not running properly
silly question... you have PIC XMT -> SIM RCV ?
PostPosted: Fri Jan 24, 2020 8:24 am     Reply with quote
You have a voltage problem.
The SIM800, is a 3.3v device (actually supports 4.4v maximum).
The boards supplied for things like the Arduino, have a regulator to give
the 3.3v, but they don't have a signal amplifier to raise the output voltage
to the levels required by the PIC. The reason is that the PIC serial input
is a Schmitt input but the Arduino one is TTL. So one is not needed when
attached to an Arduino, but is for the PIC,
You need a level shifter on the output from the modem to work.
I've used a lot of these units over the years, and this is required unless
you use a 3.3v PIC.
sebalitter
PostPosted: Fri Jan 24, 2020 8:32 am     Reply with quote
you use a 3.3v PIC.
It's working properly now, I wasn't showing the message in the correct position.
The thing is that I can't send SMS yet. I think I have a problem with AT commands.
Also this PIC has a limited memory ram and rom for this program.
main.c
//#define VSS_VREF
#INT_RDA
void  RDA_isr(void)
   dato_recibido[con_recepcion] = getchar(SERIAL_GSM);
   con_recepcion++;
   if(con_recepcion>30)
       con_recepcion=0;
void main (void)
    inicializacion();
        lcd_gotoxy(0,1);
        printf(lcd_putc,"%s",&(dato_recibido[0]));
        //printf(lcd_putc," Vr    Vs    Vt");
        lcd_gotoxy(0,2);
        printf(lcd_putc,"%s",&(dato_recibido[15]));
        delay_ms(3000);
        //printf(lcd_putc,"%3.0lu    %3.0lu   %3.0lu",voltajes[0], voltajes[1], voltajes[2]);
        mandar_SMS();
        delay_ms(3000);
        //ejecucion();
.h
 UART1 -> modulo GSM
    Tx: Pin C4
    Rx: Pin C5
 * I2C display -> sda=PIN_C1 -  scl=PIN_C2
#device adc=10
#define PROM 1500
int16 voltajes[3];
char dato_recibido[30]; // Buffer de recepción
int con_recepcion=0;
    int cont;
    delay_ms(300);
    delay_ms(3000);
        delay_ms(300);
        delay_ms(200);
    delay_ms(3000);
    return;
    lcd_init();
    //printf(lcd_putc, "\f");
    lcd_gotoxy(0,1);
    printf(lcd_putc," INICIANDO..");
void mandar_SMS()
    //fprintf(SERIAL_GSM, "AT+CMGS=\"%s\"\r", TELEFONO);
    printf(SERIAL_GSM, "AT+CMGS=\"1565404122\"\r");
    delay_ms(300);
    //printf(SERIAL_GSM, "SEBA!!!");
    //putchar(0x1a,SERIAL_GSM);
    int32 acum=0;
    int16 i=0;
    for(i=0;i<PROM;i++)
         delay_us(100);
         acum+=read_adc();
    //Vmedio=;
    return ((acum/PROM)*3.594);
PostPosted: Fri Jan 24, 2020 8:54 am     Reply with quote
OK. Looking at the picture of your board, the two transistors between
the modem, and the connector may be used for level translation. Very Happy
You don't need the clear_interrupt line in your interrupt handler. The
compiler already does this for you.
Little bit puzzled. You refer to SIM900, but the board you show is a
SIM800?.
The telephone number fed to the modem for a SMS, needs to be in
E123 format. They like not to respond unless this is right.
You are also mixing using printf, and fprintf. You need to only use
fprintf.
I know you are limited on space, but normally you need to perform a
AT+CREG to verify the modem has actually registered on the network
before sending.
You also normally need AT+CMGF=1 to set the modem to send SMS's
in text mode. It defaults to working in PDU mode.
sebalitter
PostPosted: Tue Jan 28, 2020 12:35 pm     Reply with quote
I could see the messages in the PC via RS232.
The problem is +CREG: 1,3 (registration denied).
PrinceNai
PostPosted: Tue Jan 28, 2020 2:11 pm     Reply with quote
I did a quick search on the net and saw there are a lot of people out there having that problem with SIM800 modules. One of the reasons they mention is a duplicate IMEI number and network operators having a list of those. Do you by chance have another module to test with?
As a side note, Chinese modules, both SIM800 and SIM900, gave me nothing but trouble. Not connecting, disconnecting, one day it works and the next day not... So one day I threw all of them into trash bin and got myself some A6 modules. Zero problems, only the ones I created via bad code :-)
asmallri
PostPosted: Tue Jan 28, 2020 3:22 pm     Reply with quote
What country are you in?
The SIM800 is a 2G module. 2G technology is old, and no longer operational in a lot of countries.
Regards, Andrew
sebalitter
PostPosted: Sat Feb 15, 2020 11:19 am     Reply with quote
Thank you. With A6 module works perfect. it a bit more expensive but it saves me lots of time.
I have other issue...
i didn found #pin_select directive in <16F1823.h>
why does it happend?
why i cant change U1RX pin port?
#pin_select U1RX = PIN_C3
Another question with sleep mode.
do i need to connect special external interrupt ports in this device? or i can use whatever port i want ?
Goto page 1, 2  Next
Page 1 of 2
