Controller Area Networks
maj81uk
PostPosted: Mon Feb 09, 2004 9:23 am     Reply with quote
I'm attempting a project using a PIC16F84A and a MCP2515 microcontroller and wondered if anyone could help with any suggestions as to how to program my PIC to communicate, in this situation.
I have seen that there use to be an Ex_can.c file that was supplied with the CCS C compiler, which no longers exists. Does anyone have a copy I could have a look at?
Any help on this subject would be greatfully appreciated.
PostPosted: Tue Feb 10, 2004 7:06 pm     Reply with quote
It does exist. As a test, I just did a fresh install of PCM 3.184 after
wiping the Examples and Drivers directories. It's there, after the install.
If you have EX_CAN.C, that's only part of it. It calls CAN routines
in other CCS files. You'd need those files too, to do any good:
can-18xxx8.c
can-18xxx8.h
can-mcp2510.c
can-mcp2510.h
If you have the compiler, you should email CCS and see if they
will send them to you.
