library for pic16f676
kondra
PostPosted: Sat Feb 07, 2004 5:03 am     Reply with quote
The ccs i use doesn't have a 16f676.h in his device directory . I tried using the picc database editor and creating a file .h of me own but i'm not sure i did it right. I managed to make the timre0 work but the adc module(which I need) I think it needes more work .
Any sugestions?
the next guy has always a better life
PostPosted: Sun Feb 08, 2004 3:26 pm     Reply with quote
I have posted the ADC #define statements for the 16F676, and
some sample compiled code, with the .LST file below. You can
use this to write your own functions for the ADC. Compare the
ASM code from your functions to the ASM code below, to make
sure that your functions are written corrrectly. (This code was
generated by PCM vs. 3.184, so hopefully it is correct).
You will have to look up the correct addresses for the registers,
(such as ADRESH, etc.) from the data sheet and use #byte
statements to define their addresses.
// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
//                SET_ADC_CHANNEL(), READ_ADC()
// Constants used in SETUP_ADC_PORTS() are:
//     or together any combination
//     of the sANx constants with one
//     of the others.
#define sAN0                   1         //| A0
#define sAN1                   2         //| A1
#define sAN2                   4         //| A2
#define sAN3                   8         //| A4
#define sAN4                  16         //| C0
#define sAN5                  32         //| C1
#define sAN6                  64         //| C2
#define sAN7                  128        //| C3
#define NO_ANALOGS             0         // None
// The following may be OR'ed in with the above using |
#define VSS_VDD               0x8000          // Range 0-Vdd
#define VREF_VREF             0x9000          // Range VrefL-VrefH
#define VRL_VRH               0xA000          // Range Vrl-Vrh
#define VSS_VREF              0xB000          // Range 0-VrefH
#define VSS_VRH               0xC000          // Range 0-Vrl
#define VREF_VDD              0xD000          // Range VrefL-Vdd
#define VRL_VDD               0xE000          // Range Vrl-Vdd
#define VSS_VRL               0xF000          // Range 0-Vrl
// Constants used for SETUP_ADC() are:
#define ADC_OFF                0              // ADC Off
#define ADC_CLOCK_DIV_2        1
#define ADC_CLOCK_DIV_4     0x41
#define ADC_CLOCK_DIV_8     0x11
#define ADC_CLOCK_DIV_32    0x21
#define ADC_CLOCK_DIV_16    0x51
#define ADC_CLOCK_DIV_64    0x61
#define ADC_CLOCK_INTERNAL  0x31              // Internal 2-6us
// Constants used in READ_ADC() are:
#define ADC_START_AND_READ     7   // This is the default if nothing is specified
#define ADC_START_ONLY         1
#define ADC_READ_ONLY          6
.................... void main()
0004:  CLRF   FSR
0005:  MOVLW  1F
0006:  ANDWF  STATUS,F
0007:  BSF    STATUS.5
0008:  CLRF   ANSEL
0009:  MOVLW  07
000A:  BCF    STATUS.5
000B:  MOVWF  ADCON0
.................... int16 result;
.................... setup_comparator(NC_NC_NC_NC);
000C:  MOVLW  07
000D:  MOVWF  TXREG
000E:  BSF    STATUS.5
000F:  MOVF   TRISA,W
0010:  MOVLW  03
0011:  BCF    STATUS.5
0012:  MOVWF  @57
0013:  DECFSZ @57,F
0014:  GOTO   013
0015:  MOVF   TXREG,W
0016:  BCF    PIR1.3
.................... setup_adc_ports(sAN0 | VSS_VDD);
0017:  MOVLW  01
0018:  BSF    STATUS.5
0019:  MOVWF  ANSEL
.................... setup_adc(ADC_CLOCK_INTERNAL);
001A:  BCF    STATUS.5
001B:  BSF    ADCON0.0
001C:  BCF    ADCON0.7
001D:  BSF    STATUS.5
001E:  MOVF   ADCON1,W
001F:  ANDLW  8F
0020:  IORLW  30
0021:  MOVWF  ADCON1
.................... set_adc_channel(0);
0022:  MOVLW  00
0023:  BCF    STATUS.5
0024:  MOVWF  @58
0025:  MOVF   ADCON0,W
0026:  ANDLW  C3
0027:  IORWF  @58,W
0028:  MOVWF  ADCON0
.................... result = read_adc();
0029:  BSF    ADCON0.1
002A:  BTFSC  ADCON0.1
002B:  GOTO   02A
002C:  MOVF   ADRESH,W
002D:  CLRF   result+1
002E:  MOVWF  result
.................... while(1);
002F:  GOTO   02F
Edited: The compiler was wrongly putting in the symbol name SSPCON2
when it should have used ANSEL. I changed it to use the correct symbol.
I also added the setup_comparator() function.
kondra
PostPosted: Tue Feb 10, 2004 7:03 am     Reply with quote
thx a lot
I managed to deal with the AD module by uing directly the registers ... but I'll try it your way soon
