Getenv("PROGRAM_MEMORY") value
allenhuffman
PostPosted: Sat Dec 07, 2019 2:05 pm     Reply with quote
And the quest for knowledge continues.
The manual says that PROGRAM_MEMORY returns "size of memory for code (in words)".
On my PIC24, it returns 175096. If I multiply that by two to get the size, I get 350,192... but this is supposedly a 256K part.
Someone elsewhere mentioned needing to subtract something to get the actual flash size, but I can’t seem to figure out search terms to get me back to where I saw it.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
allenhuffman
PostPosted: Sat Dec 07, 2019 2:14 pm     Reply with quote
If I take this value, divide it by 2 (words to bytes), then multiply that by 3 (Three bytes per instruction?) I get 262,664... 256K.
I expect this means something.
I am trying to find the last two bytes of flash memory to store a CRC there.
PostPosted: Sat Dec 07, 2019 2:21 pm     Reply with quote
Yes, some of these things are designed to confuse. It is the total memory
size of the chip in 16bit words (not instruction words). Since there are
two 16bit words per instruction, the instruction size is 1/2 this. The number
of actual bytes is then 3 per instruction.
Remember that physical write addresses are based on the 16bit word
address, which is why it is in this format.
allenhuffman
PostPosted: Sat Dec 07, 2019 2:38 pm     Reply with quote
So if I use the value returned by PROGRAM_MEMORY, should that word address be the end of my program memory I’d use for read/write_program_memory()? I seem to be able to write past it, clear the buffer, read it back and get what I expect.
jeremiah
PostPosted: Sat Dec 07, 2019 4:42 pm     Reply with quote
I'm pretty sure the value returned by PROGRAM_MEMORY is actually related to the location of the fuses stored on the last page. If you look up what address they start at, it should either be that number or a proportional to that number. It should be returning the amount of program memory available to you which is everything up to the FUSES
And yes, you can write past this, but you really really don't want to right over the FUSES section
For example in the PIC24FJ256GA106, the FUSES start at 0x2ABFA according to section 25.1 of the data sheet.
0x2ABFA => 175098 in decimal
Which is 2 off, but it might be a device table error in CCS (EDIT: yep, the device table says the config words start at 0x2BF8 instead of 0x2ABFA like the datasheet)
If you look at the PIC24fj64GA004, the FUSES are at 0xABFC, which is exactly the value returned by PROGRAM_MEMORY for that chip.
Side note: Since you are looking at write_program_memory() in a few other threads, I'll say be careful NOT to write data to the last page of FLASH as the FUSES reside at the end of it, so if you happen to call write_program_memory() on the start of that page, it will erase it and along with it the fuses, meaning the next time you boot, you can have "interesting" results
allenhuffman
PostPosted: Sat Dec 07, 2019 6:13 pm     Reply with quote
Ah, I was thinking these config bytes were somewhere else and not part of the flash. How do I determine where the end of flash is, before the fuses? Fixed size for them, and just subtract?
From what you say, this means the read and write routines can write to the fuse config. Why do they seem to have special functions for reading config memory? Or is that something else?
jeremiah
PostPosted: Sat Dec 07, 2019 6:34 pm     Reply with quote
FUSES reside in 2 locations on a PIC24:
1. Top of Program Memory
2. Configuration Memory
When the PIC boots up at power on, it copies the values in #1 to #2. That's why if you write over them in #1 it doesn't affect anything until your next boot.
When you do getenv("PROGRAM_MEMORY") it returns the "start" of the configuration words, so your usable FLASH is 0x000000 to that value minus 1
So if it returns 0x2ABF8, you can use 0x00000-0x2BF7, but keep in mind that if your page size is 1024 words (number pulled from my butt, check your data sheet), then you need to do the following math:
getenv("PROGRAM_MEMORY")/page_size
175096/1024= 170.99 pages
Then page 170 (indexed 0 to 170) should be left alone because the FUSES from #1 are there.
SIDE NOTE: if your page math doesn't end in a decimal around .98/.99 you are probably dividing a byte size instead of a word size. The fuses only take up 5-10 words at the end of a page.
allenhuffman
PostPosted: Sat Dec 07, 2019 6:38 pm     Reply with quote
Ah, that helps a lot! Thank you.
Page size, meaning the erase size of the flash?
jeremiah
PostPosted: Sat Dec 07, 2019 6:40 pm     Reply with quote
Yes. I also added a note to read in the previous post.
most PIC24s erase in "pages" and write in "rows", with there being some N number of rows per page
