Can not read analog input
yusufselimkaratas
PostPosted: Thu Oct 24, 2019 2:42 pm     Reply with quote
Hello, I am using PIC16F887 on Proteus and can not read analog voltage. It always returns 0. Any help will be appreciated.
Thanks.
#INT_AD
void  AD_isr(void)
#INT_RDA
void  RDA_isr(void)
   int deger;
   setup_adc_ports(AN0);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1|RTCC_8_bit);      //128 us overflow
   setup_adc(ADC_CLOCK_DIV_8);
   enable_interrupts(INT_AD);
   enable_interrupts(INT_RDA);
   //Example blinking LED program
   while(true)
     set_adc_channel(0);
  delay_us(20);
  deger = read_adc();
      output_low(LED);
      delay_ms(DELAY);
      fprintf(PORT1,"%d",deger);
      output_high(LED);
      delay_ms(DELAY);
PostPosted: Thu Oct 24, 2019 3:36 pm     Reply with quote
Please read PIC101 sticky....
Quick answer.. Proteus is busted, flawed, corrupt,defective.....
Jay
PostPosted: Thu Oct 24, 2019 6:35 pm     Reply with quote
Besides the Proteus problems, you have these flaws in your program:
1. #INT_AD is not needed to read the ADC. Remove the routine.
2. #INT_RDA has no code in it to read the UART. Remove the routine.
3. The following 3 lines are not needed, because interrupts are not
needed in a test program to read the ADC. Remove these lines:
4. You did not post your #fuses, #use delay(), #use rs232(), and
#device lines. Something could be wrong in those lines that we can't see.
Post them.
E_Blue
PostPosted: Fri Oct 25, 2019 7:36 am     Reply with quote
DELAY is not defined also PORT1.
The program is very simple, use real hardware, that PIC have inside debugger and you are paying for it.
Electric Blue
