Can't configure PIC24FJ internal oscillator [Solved]
E_Blue
PostPosted: Fri Sep 13, 2019 12:14 pm     Reply with quote
Can't configure PIC24FJ internal oscillator.
Device: PIC24FJ1024GB606
CCS: v5.078
MPLAB X IDE: v5.15
I want to use the internal oscillator(FRC) to drive the PLL for USB(96MHz) and MCU core(32MHz).
I tried with this
#include <24FJ1024GB606.h>
#fuses FRC_PLL,PLL_FROM_FRC,NOJTAG
With no luck.
Also tried
#use delay(internal=32MHz, USB_FULL)
Doesn't work either; the device gets programmed but didn't start.(debug halted)
I check the configuration bits and says PLL_PRI -> PLL is fed by the primary oscillator.
It's like the configuration is not being applied, I don't understand why
I'm new on PIC24 devices, so probably I'm making a very silly mistake.
Could you guide me please?
Electric Blue
PostPosted: Fri Sep 13, 2019 12:28 pm     Reply with quote
Read Ttelmah's comment about how you have to set a fuse to specify
the PIC pins to be used for the debugger:
http://www.ccsinfo.com/forum/viewtopic.php?t=58110
E_Blue
PostPosted: Fri Sep 13, 2019 12:54 pm     Reply with quote
I don't understand where are you going with this but I'm using this code to set the ICD pins
#device ICD=1
And I have the ICD3 connected to PIN15 and PIN16.
That's why I think that the problem is that the oscillator FRC is not driving the core.
Electric Blue
PostPosted: Fri Sep 13, 2019 1:04 pm     Reply with quote
Can you blink an LED ? Remove the USB_FULL and see if you can even
blink an LED.
E_Blue
PostPosted: Fri Sep 13, 2019 1:36 pm     Reply with quote
I tried this and get the same result, device halted.
//#fuses FRC_PLL,PLL_FROM_FRC,NOJTAG
#device ICD=1
#DEVICE ADC=10
#ZERO_RAM
#use delay(internal=32MHz)
int main(int argc, char** argv)
        output_toggle(PIN_D6);
Electric Blue
PostPosted: Fri Sep 13, 2019 2:28 pm     Reply with quote
hmm.. is this CCS legal ??
just curious
Jay
newguy
PostPosted: Fri Sep 13, 2019 2:29 pm     Reply with quote
just curious
Jay
Nein.
E_Blue
PostPosted: Fri Sep 13, 2019 2:31 pm     Reply with quote
I don't know but CCS doesn't complain about.
Also I tried this with same results.
#device ICD=1
#ZERO_RAM
int main()
Electric Blue
newguy
PostPosted: Fri Sep 13, 2019 2:49 pm     Reply with quote
The structure of your main() is that of a windows terminal program which is expecting user input when it runs.
void main(void) {
is standard for any embedded application.
E_Blue
PostPosted: Fri Sep 13, 2019 3:45 pm     Reply with quote
Ok, I changed the function to void main() and is running ok.
Now I will try with the full program.
Electric Blue
