georpo
Joined: 18 Nov 2008 Posts: 281 Location: Athens, Greece.
| PIC24F16KA102 RTC alarm ignores week day [Solved] |
Posted: Wed Sep 04, 2019 1:06 am |
Hello friends!
I am using the PIC24F16KA102 RTC module and I want to have week day based alarms which does not seem to work.
Everything works OK, I set the date, week day and time, read it back, I set the alarm and read it back and the alarm works as far as it concerns date and time but it ignores the week day.
For example if I set the RTC week day to 0 (Sunday) and the alarm week day to Monday the alarm will occur ignoring the week day.
CCS:5.049
rtc_time_t write_clock, read_clock;
void SetupRTC(){
setup_rtc(RTC_ENABLE , 0);
void WriteTime(){
write_clock.tm_year=19;
write_clock.tm_mon=9;
write_clock.tm_mday=6;
write_clock.tm_wday=4;
write_clock.tm_hour=14;
write_clock.tm_min=30;
write_clock.tm_sec=0;
rtc_write(&write_clock);
void WriteAlarm(){
write_clock.tm_wday=5;
write_clock.tm_sec=6;
setup_rtc_alarm(RTC_ALARM_ENABLE | RTC_CHIME_DISABLE, RTC_ALARM_YEAR, 0x00);
rtc_alarm_write(&write_clock);
#INT_RTC
void RTCISR(){
Led=1;
#include "24F16KA102.h"
#device ADC=10
#FUSES FRC_PLL //Internal osc + PLL
#FUSES NOPR //Pimary oscillator disabled
#FUSES OSCIO //OSC2 is general purpose output
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES PUT //Power Up Timer
#FUSES RTCCK_SOSC //Use secondary oscillator for RTCC
#use delay(int=32M)
Any help appreciated. _________________ George. |
georpo
Posted: Wed Sep 04, 2019 1:21 am |
In reply to myself, you have to set the alarm interval to WEEK
setup_rtc_alarm(RTC_ALARM_ENABLE | RTC_CHIME_DISABLE, RTC_ALARM_WEEK, 0x00);
