need pic16f676 based voltmeter code
Goto page Previous  1, 2
Jackma
Pic16f676 voltmeter
PostPosted: Mon Aug 26, 2019 11:21 am     Reply with quote
Hi to all. I am new here.
I am also working on this project.
My main problem is voltmeter reading. Its not stable.
HERE is my code:
#include <16f676.h>
#FUSES INTRC                 //Internal RC Osc, no CLKOUT
#FUSES PUT
#device ADC=10
#use delay(INT=4Mhz)
#define aon    output_LOW(PIN_C0);
#define aof    output_HIGH (PIN_C0);
#define bon    output_LOW(PIN_C1);
#define bof    output_HIGH (PIN_C1);
#define con    output_LOW(PIN_C2);
#define cof    output_HIGH (PIN_C2);
#define don    output_LOW(PIN_C3);
#define dof    output_HIGH (PIN_C3);
#define eon    output_LOW(PIN_C4);
#define eof    output_HIGH (PIN_C4);
#define fon    output_LOW(PIN_C5);
#define fof    output_HIGH (PIN_C5);
#define gon    output_LOW(PIN_A2);
#define gof    output_HIGH (PIN_A2);
#define d1_of    output_LOW(PIN_A1);
#define d1_on    output_HIGH (PIN_A1);
#define d2_of    output_LOW(PIN_A0);
#define d2_on    output_HIGH (PIN_A0);
#define d3_of    output_LOW(PIN_A5);
#define d3_on    output_HIGH (PIN_A5);
int32  value=0,val2,ind=0,ind2=0,cnt5=0,d1;
void off();
int thu,ten,unit,digit;
void zero(){
 aon;
 bon;
 con;
 don;
 eon;
 fon;
 gof;
void one(){
 aof;
 bon;
 con;
 dof;
 eof;
 fof;
 gof;
void two(){
 aon;
 bon;
 cof;
 don;
 eon;
 fof;
 gon;
void three(){
 aon;
 bon;
 con;
 don;
 eof;
 fof;
 gon;
void four(){
 aof;
 bon;
 con;
 dof;
 eof;
 fon;
 gon;
void five(){
 aon;
 bof;
 con;
 don;
 eof;
 fon;
 gon;
void six(){
 aon;
 bof;
 con;
 don;
 eon;
 fon;
 gon;
void seven(){
 aon;
 bon;
 con;
 dof;
 eof;
 fof;
 gof;
void eight(){
 aon;
 bon;
 con;
 don;
 eon;
 fon;
 gon;
void nine(){
 aon;
 bon;
 con;
 don;
 eof;
 fon;
 gon;
void comp1(){
if(digit==0)zero();
if(digit==1)one();
if(digit==2)two();
if(digit==3)three();
if(digit==4)four();
if(digit==5)five();
if(digit==6)six();
if(digit==7)seven();
if(digit==8)eight();
if(digit==9)nine();
 DELAY_MS(1);
void mux(){
d1_on;digit=thu;comp1();d1_of;
d2_on;digit=ten;comp1();d2_of;
d3_on;digit=unit;comp1();d3_of;
//d3_on;digit=unit;comp1();d3_of;
void mdelay()
mux();mux();//mux();mux();
mux();mux();mux();mux();
//mux();mux();mux();mux();
void getad(){
      int32   result=0;int8 i;
     SET_ADC_CHANNEL(3);
//       for(i=0;i<2;i++)
  //   delay_ms(1);
 mux(); mux();mux();mux(); mux();mux();
 result=read_adc();
   val2=result;
  //   value = (int8) (read_adc() * 500)/1023;
//val2 = read_adc ();
  value =   (val2* 5000)/1023;
 thu = (value/1000); mux(); mux();mux();mux(); mux();mux();
 ten = (value/100)%10; mux(); mux();mux();mux(); mux();mux();
 unit = (value/10)%10; mux(); mux();mux();mux(); mux();mux();
putc(thu+48);
putc(ten+48);
putc(unit+48);
 unit = value%10;
putc(unit+48);
putc(10);putc(13);
void main ()
 DELAY_MS(1);
 //SETUP_ADC_PORTS(NO_ANALOGS);
//   set_tris_a(0);
   set_tris_c(0x00);
   setup_adc_ports(sAN0 | VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL );
 set_tris_c(0x00);
     set_tris_a(0xff);
     set_tris_a(0b00011001);
  setup_comparator(NC_NC_NC_NC);   // not use comparator module
   setup_adc_ports( sAN3 | VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
zero();
//DELAY_MS(1000);
// DELAY_MS(10);
//pwmd();
getad();
mdelay();
drolleman
PostPosted: Mon Aug 26, 2019 12:26 pm     Reply with quote
I think he and his project will win a Darwin award.
PostPosted: Mon Aug 26, 2019 1:39 pm     Reply with quote
OK, he's trying to get the PIC to read ADC and then display on 3-7 segment displays. Quite do-able, BTDT 2 decades ago....
Stability problem could very well be the ADC_clock selection.
I quote, from the datasheet...
4: When the device frequency is greater than 1 MHz, the A/D RC clock source is only recommended if the
conversion will be performed during SLEEP.
You need to change the ADC clock, based upon the PIC clock frequency
(4MHz in your case). Have a look at the ADC section.
Also you'll need to have a small cap on the ADC input, maybe a Voltage Follower OPAMP, shielded wiring, stable Vref, etc..... Using VDD as the Vref AND muxing LEDs is a bad design choice.
Jay
dluu13
PostPosted: Mon Aug 26, 2019 2:01 pm     Reply with quote
It's an old thread, but now I am curious to see what the circuit was...
PostPosted: Mon Aug 26, 2019 2:33 pm     Reply with quote
If you've got 2 decade old Microchip application books, it's in there, with ASM for 'real' prorammers..... Smile
Probably available as a download 'ap note'...
Might be one for the 16C1671 as well...
Jay
Jackma
i am using 4mhz
PostPosted: Sat Oct 12, 2019 6:20 am     Reply with quote
I am using 4 mhz internal clock and adc=10
but adc not stable reading.
What can i change Surprised
PostPosted: Sat Oct 12, 2019 7:56 am     Reply with quote
The reference voltage.
The ADC depends on the quality of it's reference. Using the supply as a
reference you are unlikely to actually be able to get better than perhaps
1% actual accuracy/noise. For an accurate ADC, you need a stable/accurate
reference voltage. Vref, and feed it from a bandgap diode reference.
Jackma
pic16f676 adc voltage
PostPosted: Sun Oct 13, 2019 2:14 am     Reply with quote
How to set pic adc voltage ?
I am using default settings.
and what you mean about bandgap ?
I am not set or study about bandgap.
Jackma
full details of microcontroller voltmeter
PostPosted: Sun Oct 13, 2019 2:25 am     Reply with quote
I think i can't explain you.
I'm making a 1 meter whose value Its value is 1 milliliter resolution.
I give a link to the code I pasted above I have taken the code from this website and after seeing it, tell me Thankshttps://projectiot123.com/2019/08/03/pic-16f676-microcontroller-voltmeter/
Jackma
Diagram hardware
PostPosted: Sun Oct 13, 2019 2:27 am     Reply with quote
If you say, then I also send the diagram as well.
PostPosted: Sun Oct 13, 2019 5:04 am     Reply with quote
OK, I looked at the source code and the major problem.
Trying to use the ADC in 10 bit mode.
#1 is that you're using VDD as the ADC's Vref AND assuming it is 5.000 volts. Odds are real good VDD is NOT 5.000 volts AND it will vary everytime the LEDs are used.
If you must use VDD as Vref, I suggest having at least a 4700mfd cap in the power supply to help minimize 'fluctuations' in VDD. A DVM will not show them( 3Hz sample rate) but the PIC WILL see them ! Also wire as PSU-->4700mfd---->LEDS--->1000mfdcap--->PIC. This configuration should reduce VDD from wide variations in voltage.
Honestly even with great PSU filtering, you'll never get stable,repeatable readings. I do suggest adding say a .68 or 1mfd cap to the analog input, that should help.
Also, 'over sample'. Take 8 readings, then average them. Olympic average is a good method. The more readings, teh smoother the result, just be sure to use 8,16,32 readings as the math is fast and simple for the PIC.
Jay
PostPosted: Sun Oct 13, 2019 5:19 am     Reply with quote
Understand, the PIC ADC, does not magically measure voltages. It makes
it's measurements as a 'ratiometric' figure, relative to what is being fed
as it's reference. Now the default _low accuracy_ option, is to use
the chip's supply as this reference. However this is _low accuracy_. The
'best' you will get this way is perhaps 1%, and this only with a really
good supply and a lot of care in the layout. On most systems you are
more likely to get perhaps 5% accuracy. In your case, this is made
worse, since your supply is likely to change as different digits are lit
on the LED. Result you are very likely to see a situation where as
digits change, the value read from the ADC also changes....
To get better accuracy, you have to tell the code to use Vref instead of
Vdd, and feed and accuirate voltage into the Vref pin.
A bandgap reference, is the standard way of getting a more accurate
reference voltage. So:
<https://www.mouser.co.uk/Semiconductors/Power-Management-ICs/Voltage-References/_/N-10vu2?P=1z0wa1tZ1yzt45d>
Understand also, that a voltage that reads as (say) 2v on a DVM, may
well give fluctuation when read using the PIC ADC. The reason is that
the standard DVM, won't resolve high frequency noise. Stick a scope
on this 2v signal, and you may well see many mV of noise.
Jackma
Ok i try it
PostPosted: Sun Oct 13, 2019 5:22 am     Reply with quote
Jay
Mike Walne
PostPosted: Sun Oct 13, 2019 7:43 am     Reply with quote
What is the order of magnitude of the variation in your ADC readings?
Using a 'scope how does it compare with the ADC reference noise and the noise at your ADC input?
Mike
Page 2 of 2
