Debugger: possible to attach to a "locked up" PIC?
allenhuffman
PostPosted: Mon Aug 19, 2019 9:22 am     Reply with quote
On many debuggers I have worked with, it is possible to attach to a running system and see where it is. This is useful when a system is (or appears to be) locking up.
I do not see anything I recognize as an "attach to" option in the debugger, so I thought I'd ask here.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
PostPosted: Mon Aug 19, 2019 9:53 am     Reply with quote
Not possible.
The debuggers on the PIC, rely on having a microcode debug executive
loaded into the chip. So the code has to be programmed with this present
and loaded.
You were probably using a hardware debugger that stopped the primary chip
and took over the bus, and monitored the registers.
allenhuffman
PostPosted: Mon Aug 19, 2019 10:30 am     Reply with quote
Ttelmah wrote:
Not possible.
and loaded.
Good to know. Thank you.
PostPosted: Mon Aug 19, 2019 10:53 am     Reply with quote
As a comment, I assumed by 'debugger', you meant ICD?. I do actually have
a full hardware debugger for quite a few PIC's and this does support hot
connection, but is a very expensive system and 'not common'. Assumed you
didn't have such a system. I don't think they are made anymore.
allenhuffman
PostPosted: Mon Aug 19, 2019 11:22 am     Reply with quote
We use the ICD-U80s and some PICKIT thing, but I haven't worked with it yet.
PostPosted: Mon Aug 19, 2019 12:25 pm     Reply with quote
Yes, so standard ICD's. Smile
