Modbus holding registers map
Goto page Previous  1, 2
greenbridge
PostPosted: Thu Aug 08, 2019 7:51 am     Reply with quote
I have up to date compiler 5.087
////                                modbus_phy_layer.h                                ////
////      Physical layer of the MODBUS protocol driver for serial communications.     ////
////  Refer to documentation at http://www.modbus.org for more information on MODBUS. ////
//// Revision history:        ////
////  July 20, 2011       Seperated Physical Layer functions definitions into this    ////
////                      file from modbus.c                                          ////
////                (C) Copyright 1996, 2013 Custom Computer Services                 ////
////        This source code may only be used by licensed users of the CCS            ////
////        C compiler.  This source code may only be distributed to other            ////
////        licensed users of the CCS C compiler.  No other use,                      ////
////        reproduction or distribution is permitted without written                 ////
////        permission.  Derivative programs created using this software              ////
////        in object code form are not restricted in any way.                        ////
Our receive struct.  This is used when receiving data as a master or
slave.  Once a message is sent to you with your address, you should
begin processing that message.  Refer to ex_modbus_slave.c to see
how to properly use this structure.
struct
   unsigned int8 address;
   unsigned int8 len;                       //number of bytes in the message received
   function func;                           //the function of the message received
   exception error;                         //error recieved, if any
   unsigned int8 data[MODBUS_SERIAL_RX_BUFFER_SIZE]; //data of the message received
} modbus_rx;
PostPosted: Thu Aug 08, 2019 8:03 am     Reply with quote
As written, the CCS slave example, only uses the low byte of the register
number. So max register allowed is 256. To support 300, you will have to take
modbus.rx_data[4]*256+modbus.rx_data[3] as the register address number.
greenbridge
PostPosted: Fri Aug 09, 2019 7:44 am     Reply with quote
It worked fine. Thanks a lot!
PostPosted: Fri Aug 09, 2019 7:50 am     Reply with quote
Well done. Nice to see movement forwards!. Smile
Page 2 of 2
