Nevillestone
| USE RS232 |
Posted: Fri Jul 26, 2019 1:34 am |
HI
I'm using a serial port for a 485 bus and using USE RS232 built-in function.
It works however I'm having to control the enable bit manually back to receive mode after transmitting.
Is there a setting to set it to RX Mode as default ? I can't find anything in the manual.
Using
| Code: | #USE RS232 (baud=1200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1,enable=PIN_B2)
#define RS485_USE_EXT_INT TRUE |
Neville _________________ Neville |
dluu13
| Re: USE RS232 |
Posted: Fri Jul 26, 2019 3:31 am |
| Nevillestone wrote: | HI
Using
Neville |
I know that the included modbus.c library will handle all that stuff automatically. There's also a rs485.c in the drivers folder, which I have never used. |
Joined: 01 Jul 2010 Posts: 9657 Location: Greensville,Ontario
Posted: Fri Jul 26, 2019 4:32 am |
I've always tied _RE and DE of the RS485 device together so that both pins were controlled as the 'ENABLE' pin in the USE RS232(....options...). Can't recall ever having a problem.
If you physically tie _RE low (to gnd), the RS485 receiver 1/2 will always be active, which means the PIC will see it's own transmitted data.
You need to cut a small program/compile and dump the listing to see what CCS does with the 'ENABLE' pin. I suspect it goes high, send data, goes low.
I'd do it but my manure spreader needs new beater bearings....
Jay |
