Help on CLC1 example on PIC16F15325
Momboz
PostPosted: Wed Jul 24, 2019 9:39 am     Reply with quote
Trying to understand, but no success, i.e. no signal on RA5 when trying combinations of buttons RC3 and RC4.
Could someone help?
Here is my code:
#include <16F15325.h>
#device ADC=10
#use delay(internal=32MHz)
#define LED PIN_A1
#define DELAY 1
#byte CLC1GLS0 = getenv("SFR:CLC1GLS0")
#byte CLC1GLS1 = getenv("SFR:CLC1GLS1")
#byte CLC1GLS2 = getenv("SFR:CLC1GLS2")
#byte CLC1GLS3 = getenv("SFR:CLC1GLS3")
#byte CLC1SEL0 = getenv("SFR:CLC1SEL0")
#byte CLC1SEL1 = getenv("SFR:CLC1SEL1")
#byte CLC1SEL2 = getenv("SFR:CLC1SEL2")
#byte CLC1SEL3 = getenv("SFR:CLC1SEL3")
#byte CLC1POL  = getenv("SFR:CLC1POL")
#byte CLC1CON  = getenv("SFR:CLC1CON")
#byte CLCDATA  = getenv("SFR:CLCDATA")
#byte CLCIN0PPS = getenv("SFR:CLCIN0PPS")
#byte CLCIN1PPS = getenv("SFR:CLCIN1PPS")
#byte CLCIN2PPS = getenv("SFR:CLCIN2PPS")
#byte CLCIN3PPS = getenv("SFR:CLCIN3PPS")
#pin_select CLC1OUT=PIN_A5
#pin_select CLCIN0=PIN_C3
#pin_select CLCIN1=PIN_C4
  SET_TRIS_C( 0b011000 );
  CLC1CON  = 0x82;
  CLCIN0PPS = 0x13;
  CLCIN1PPS = 0x14;
  CLCIN2PPS = 0x10;
  CLCIN3PPS = 0x10;
  CLC1GLS0 = 0x0A;
  CLC1GLS1 = 0x00;
  CLC1GLS2 = 0x00;
  CLC1GLS3 = 0x00;
  CLC1SEL0 = 0x00;
  CLC1SEL1 = 0x01;
  CLC1SEL2 = 0x1B;
  CLC1SEL3 = 0x1E;
  CLC1POL  = 0x8E;
  while(TRUE) {
    output_toggle(LED);
    delay_ms(DELAY);
PostPosted: Wed Jul 24, 2019 10:41 am     Reply with quote
Glaring thing is you can't just write to the PPS registers.
The chip has to have a very specific 'unlock' sequence before it'll
accept changes to the PPS.
Use the CCS #PIN_SELECT to setup the PPS.
Momboz
PostPosted: Wed Jul 24, 2019 3:00 pm     Reply with quote
I thought this is what I have been doing in using the following code for PPS remapping.
I am directly writing just to the CLC1 registers, not to PPS registers.
Did I misunderstand things?
PostPosted: Wed Jul 24, 2019 3:46 pm     Reply with quote
Look at your posted code:
CLCIN0PPS = 0x13;
CLCIN1PPS = 0x14;
CLCIN2PPS = 0x10;
CLCIN3PPS = 0x10;
Yes, you are writing directly to the PPS registers without doing the
unlocking sequence.
Momboz
PostPosted: Thu Aug 01, 2019 8:09 am     Reply with quote
Yes, you're right. I've missed those code lines.
I did review my code and now everything works fine. I did it in an easier way:
  setup_clc1(CLC_ENABLED | CLC_MODE_AND);
  clc1_setup_input(1, CLC_INPUT_CLCIN0);
  clc1_setup_input(2, CLC_INPUT_CLCIN1);
  clc1_setup_gate(1, CLC_GATE_OR);
  clc1_setup_gate(2, CLC_GATE_SET);
  clc1_setup_gate(3, CLC_GATE_SET);
  clc1_setup_gate(4, CLC_GATE_SET);
However, I have noticed that, the coding in CCS C Compiler differs from that in MPLAB XC8. The difference is in the inputs selection register.
MPLAB takes account that inputs are not connected, e.g. in my case it says
CLC1GLS0=0x0A and CCS C Compiler says CLC1GLS0=0xAA.
In my case, this makes no difference, because I am not using any other signal outside these 2.
Maybe there is a way to tell the gate that the other 2 inputs are disconnected.
