[Partially SOLVED] debug printf via the ICD-U80 debugger
Goto page Previous  1, 2
allenhuffman
PostPosted: Tue Jun 18, 2019 8:34 am     Reply with quote
PCM programmer wrote:
1. What is your PIC ?
2. What PIM module are you using for the Explorer 16 ?
PIC24FJ256GA110 is what I have plugged in to the Explorer 16 at the moment. We have several modules, but this was the closest match to the module I will be developing for.
I am using the ICD-U80 debugger.
jeremiah
PostPosted: Tue Jun 18, 2019 10:41 am     Reply with quote
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
Various feedback here and other places claims this is "sometimes buggy," so maybe that is what I am running into.
The #fuses line I have is whatever default the PIC24 Wizard created. I did try using the:
#use rs232(ICD, DISABLE_INTS, stream=DBG)
…example that you and Jerimiah suggested, but I got no output on my PIC24FJ256GA110 board. I also checked that #fuses line, but NOPBADEN doesn't exist for me (or that header file, for my hardware config).
But, I now am fairly confident I am doing it correctly -- it's just not working for me. Maybe some Debug option I have misconfigured (the only thing I have done is toggle the Monitor one to true, so maybe I need to do others).
Thanks, much!
Note that this is not related to debug at all. I run this purely in release with NODEBUG fuse set.
Are you running it from PCWHD? Just cycling power may not work
Also you need to tell the compiler which programming port you are using
#device ICSP=2
For example. Choose the number that your dev kit uses
allenhuffman
PostPosted: Tue Jun 18, 2019 11:11 am     Reply with quote
#device ICSP=2
Thanks. I am able to debug just fine (breakpoints, etc.) -- ICSP=2 for me.
The compiler we use is the PCDIDE Compiler.
allenhuffman
PostPosted: Fri Jul 05, 2019 12:22 pm     Reply with quote
From another topic:
CCS Data Streaming Video Tutorial:
https://www.youtube.com/watch?v=EnSazS39MeA
Just using
#use rs232(ICD)
...then doing normal printf() in the code, then "BUILD AND RUN" will launch a serial terminal that works.
I have yet to figure out how to get that output when in the Debugger, though, but this is at least something.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
allenhuffman
PostPosted: Fri Jul 05, 2019 2:08 pm     Reply with quote
The remaining issue now is how to get this same thing to work when debugging -- not just running.
PostPosted: Fri Jul 05, 2019 7:01 pm     Reply with quote
It defaults to using the ICSP pins for serial communication.
A typical example of ICSP pins would be B6 and B7.
But in Debug mode, the ICD will be using those pins to
communicate with the Debug hardware module in the PIC.
So that's probably why it doesn't work.
There used to be a method of using Pin B3 to send printf
messages to the console in the CCS IDE. This would seem
like the ideal method to use in Debug mode. I don't have
the CCS IDE or their ICD-Uxx debugger, so I can't test it.
jeremiah
PostPosted: Fri Jul 05, 2019 7:39 pm     Reply with quote
allenhuffman wrote:
From another topic:
Just using
#use rs232(ICD)
If you have any interrupts, you want
#use rs232(ICD,DISABLE_INTS)
at a minimum. It's a software serial port, so interrupts can mess with it.
PostPosted: Fri Jul 05, 2019 10:52 pm     Reply with quote
Here is a website that has an example of using the built-in monitor of
the CCS IDE to view printf messages. He is using CCS vs. 5.051:
https://simple-circuit.com/pic16f887-mmc-sd-interfacing-ccs-c/
Scroll down to the bottom. You'll see a screenshot of a black screen
with messages on it. Look at the top message. It says:
*** Interfacing PIC16F887 MCU with SD card ***
Then, look at his source code, in the screenshot above that.
He has a printf statement:
  printf("*** Interfacing PIC16F887 MCU with SD card ***");
Then above that line, he defines a software UART.
#use rs232(xmit = PIN_D2, rcv = PIN_D1, baud = 9600)
If you're using interrupts, you need to add DISABLE_INTS to that.
If you used a hardware UART, you wouldn't have to disable interrupts.
His schematic shows he's really only using the Xmit on pin D2.
It goes to a MAX232 chip and then to the PC's serial port connector.
This presumably comes in on COM1 or COM2 to the PC. Or some other
COM port if you're using a USB-COMport adapter.
He has has video here, which shows how to setup the CCS serial monitor
inside the IDE:
https://www.youtube.com/watch?v=ldN8GiTAgS8
allenhuffman
PostPosted: Tue Jul 09, 2019 8:59 am     Reply with quote
Our custom hardware doesn't provide a connection for that pin on the debugger.
From looking at schematics to the Explorer 16, it did, but I never got it working. Various responses say it is flaky, so I've given up for now. When I get a PIC setup to play with at home, I'll revisit.
Page 2 of 2
