PICDEM 2 Plus LCD
tobyboreham
PICDEM 2 Plus LCD
PostPosted: Sat Oct 11, 2003 7:35 am     Reply with quote
Has anyone had any luck getting the lcd.c driver working with the PICDEM 2 LCD controller?
The control/data lines are split over two ports - A1, A2, A3 are the control lines and D0, D1, D2, and D3 are data lines.
Toby
Mark
PostPosted: Sat Oct 11, 2003 10:00 am     Reply with quote
All you need to do is redefine their definitions a bit. I can't post their file but I made a few changes to the definitions and tested it on a 18F452. All I did was print "Hello World" and it seemed to work. I included the definitions for the 16F877 but didn't test them. I won't post their code but you should be able to figure it out by what I post. Just replace the top portion of the file with this (everything but the actual code). Enjoy Smile
// This structure is overlayed onto the data ports so that you may use
// whatever ports you desire
struct lcd_pin_map
  boolean dummy;      // PinA0 is not used
  boolean enable;     // PinA1
  boolean rw;         // PinA2
  boolean rs;         // PinA3
  int unusedA  : 4;   // The rest of portA
  int unusedB;        // portB is not used
  int unusedC;        // portC is not used
  int     data : 4;   // lower nibble of portD is used for data lines
  int unusedD  : 4;   // The rest of portD
} lcd;
#if defined(__PCH__)
  #locate lcd = 0xF80
#else
  #locate lcd = 5
#endif
struct lcd_tris_map
  int control  : 3;
} lcdtris;
  #locate lcdtris = 0xF92
#else
  #locate lcdtris = 0x85
#endif
#define set_tris_lcd(x) lcdtris.data = (x); lcdtris.control = 0;
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
#define LCD_WRITE    0       // For write mode all pins are out
#define LCD_READ     15      // For read mode data pins are in
//--------------- Start of code ---------------------------------
tobyboreham
It works!
PostPosted: Mon Oct 13, 2003 2:25 pm     Reply with quote
Hi Mark,
You're a star! Smile Thanks so much for the info on the LCD module. It now works perfectly!!!!!
Toby
PostPosted: Mon Oct 13, 2003 2:40 pm     Reply with quote
Mark,
This has been an issue with the CCS lcd driver for a long time.
(The difficulty of changing it to use two or more ports).
You should email your method to CCS and ask them to incorporate
it in the LCD.C file.
Mark
PostPosted: Mon Oct 13, 2003 5:04 pm     Reply with quote
Okay, I'll do that.
Mark
Remo
LCD Driver PICDEM
PostPosted: Tue Feb 03, 2004 4:58 pm     Reply with quote
Hi Mark
1000 Thanks for this Driver !
it is absolutely importantly that only the new version of lcd.c (22,05,2003/5763) be modified can. with the old version of PCM (16fxxx) functions it not. Idea
chava
here is another one, a complete function set
PostPosted: Tue Feb 03, 2004 5:16 pm     Reply with quote
here is a complete function set (It works!)
////////////////////   LCD   //////////////////////////////
// As defined in the following structure the pin connection is as follows:
//     A1  enable
//     A2  rw
//     A3  rs
//     D0  D4
//     D1  D5
//     D2  D6
//     D3  D7
//   LCD pins D0-D3 are not used and PIC D3 is not used.
   #byte lcd = 0xF83      // This puts the entire structure
#else
   #byte lcd = 8          // on to port D (at address 8)
#endif
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                            // to start it up.
                     // for 2 lines lcd: {0x0a,0xc,1,6}
                     // for 5x10 lcd:   {0x06,0xc,1,6}
                     // for 5x7 lcd:      {0x20,0xc,1,6}
//***** lcd command port  *******************************************************************
struct lcd_command{
   char none:1;
   char enable:1;
   char read_write:1;//rw
   char data_command:1;//rs
struct lcd_command lcd_command_port;
#locate lcd_command_port=5
struct lcd_data{
   char data:4;
struct lcd_data lcd_data_port;
#locate lcd_data_port=8
//************  "COMMAND / DATA definition  ************************************************************
#define COMMAND0 0
#define DATA1 1
//************  "READ / WRITE definition  ************************************************************
#define WRITE0 0   //LCD <- MPU
#define READ1 1  //LCD -> MPU
//************  "E_UP / E_DOWN definition  ************************************************************
#define E_DOWN 0
#define E_UP 1
//**********eeprom or flash******************************************************************************
#define EEPROM0 0   ;eeprom - not the program  memory
#define FLASH1 1   ;program memory
//*********  set tris d  *********************************************************************
#define set_tris_lcd_read(){\
   set_tris_a(TRISA & 0xf1/*0b11110001*/);\
   set_tris_d(TRISD | 0x0f/*0b00001111*/);\
#define set_tris_lcd_write(){\
   set_tris_d(TRISD & 0xf0/*0b11110000*/);\
//***********   clear LCD  ************************************
#define clear_lcd   lcd_send_byte(0x1,COMMAND0);//clear lcd display
char lcd_read_byte(void){
      char low,high;
      set_tris_lcd_read();
      lcd_command_port.read_write = READ1;
      delay_cycles(1);
      lcd_command_port.enable = E_UP;
      delay_cycles(1);
      high = lcd_data_port.data & 0x0f;
      lcd_command_port.enable = E_DOWN;
      delay_cycles(1);
      delay_us(1);
      low = lcd_data_port.data & 0x0f;
      set_tris_lcd_write();
      return( (high << 4) | low);
void lcd_write_nibble(char temp_wr){
//Purpose:
      lcd_data_port.data = temp_wr;
      delay_cycles(1);
      lcd_command_port.enable = 1;
      delay_us(2);
      lcd_command_port.enable = 0;
void lcd_send_byte(char data , char data_or_command ) {
      lcd_command_port.data_command = COMMAND0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd_command_port.data_command = data_or_command;
      delay_cycles(1);
      lcd_command_port.read_write = WRITE0;
      delay_cycles(1);
      lcd_write_nibble(data >> 4);
      lcd_write_nibble(data & 0xf);
void lcd_gotoxy( char location, char line) {//location 0...
   char address;
   if(line!=1)
     address=40;//was80
     address=0;
   address+=location;
   lcd_send_byte(0x80|address,COMMAND0);
//********** -  1 - **************************************************
void lcd_init(void){
//Purpose: initiate the lcd
   //turnning PORTA0=analog, PORTA1-7=digital
   ADCON1=0x0e;
   //turnning command pin of lcd to output
   //delay 15msec
   delay_ms(15);
   lcd_command_port.enable=0;
   lcd_command_port.data_command=0;
   lcd_command_port.read_write=0;
   lcd_data_port.data=0;
   delay_ms(2);
   lcd_write_nibble(0x03);//was 30  ddram address: 1:1bit,line:1bit,address:4bit
   delay_ms(10);//more then 4.1msec
   delay_us(150);//more then 100usec
   delay_us(100);
   lcd_write_nibble(0x02);//was 20
   while(bit_test(lcd_read_byte(),7));
   lcd_send_byte(0x28,COMMAND0);//was 0x28 portd[3:0]=x2 then portd[3:0]=x8
                     //  4 bit low nibble, ddram address=0 first line
   lcd_send_byte(0x0c,COMMAND0);//disp on
   clear_lcd;
   lcd_send_byte(0x6,COMMAND0);//entry inc
   lcd_gotoxy(1,1);
void lcd_putc( char c) {//this function works good
   switch (c) {
     case '\f'   : lcd_send_byte(1,COMMAND0);   delay_ms(2);   break;   //Clear display
     case '\n'   : lcd_gotoxy(1,2);                        break;   //Go to start of second line
     case '\b'   : lcd_send_byte(0x10,COMMAND0);               break;   //Move back one position
     default     : lcd_send_byte(c,DATA1);                  break;   //send the actual character
char lcd_getc( char location, char line) {
      char value;
    lcd_gotoxy(location,line);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd_command_port.data_command=1;
    value = lcd_read_byte();
    return(value);
      return 1;
void lcd_put_string(char *string){
//put string, starting  from the curren cursor position
//assume that string not excides from lcd displayed RAM
   char index=0;
   while(string[index]!=0){
      lcd_putc(string[index++]);
void lcd_put_string_xy(char *string, char pos, char line){
   lcd_gotoxy(pos,line);
   lcd_put_string(string);
void stan_char(long *ptr,char line,char eeprom_or_flash){
//Purpose: write 16 chars, given in ptr location(eeprom or flash)
//to line of lcd, from the begining of the line
   char c,i;
   lcd_gotoxy(1,line);
/*OR:   switch(line==1) {
      case 1:lcd_send_byte(0x80,COMMAND);   //initiate lcd to write to line 1
      case 2:lcd_send_byte(0xc0,COMMAND);   //initiate lcd to write to line 2
   for (i=0;i<16;i++){
      if (eeprom_or_flash)
         c=read_program_eeprom(ptr+1);
         c=read_eeprom((char)ptr+1);
      lcd_putc(c);ptr++;
LCD_INIT
MOVLW DISP_ON ; Display On, Cursor On               = 0x0C
CALL SEND_CMD ; Send This command to the Display Module
MOVLW CLR_DISP ; Clear the Display                  =0x01
MOVLW ENTRY_INC ; Set Entry Mode Inc., No shift         =0x06
SEND_CHAR
   MOVWF CHAR ; Character to be sent is in W
   CALL BUSY_CHECK ; Wait for LCD to be ready
   SWAPF CHAR, W
   ANDLW 0x0F ; Get upper nibble
   MOVWF LCD_DATA ; Send data to LCD
   BCF LCD_CNTL, RW ; Set LCD to read
   BSF LCD_CNTL, RS ; Set LCD to data mode
   BSF LCD_CNTL, E ; toggle E for LCD
   BCF LCD_CNTL, E
   MOVF CHAR, W
   ANDLW 0x0F ; Get lower nibble
   BCF LCD_CNTL, E*/
SEND_CMD
   MOVF CHAR,w
   ANDLW 0xF0 ; Get upper nibble
   BCF LCD_CNTL,RW ; Set LCD to read
   BCF LCD_CNTL,RS ; Set LCD to command mode
   BSF LCD_CNTL,E ; toggle E for LCD
   BCF LCD_CNTL,E
   SWAPF CHAR,w
   ANDLW 0xF0 ; Get lower nibble
   BCF LCD_CNTL,E
BUSY_CHECK
   BSF STATUS, RP0 ; Select Register Bank1
   MOVLW 0xFF ; Set Port_D for input
   MOVWF LCD_DATA_TRIS
   BCF STATUS, RP0 ; Select Register Bank0
   BCF LCD_CNTL, RS ; Set LCD for Command mode
   BSF LCD_CNTL, RW ; Setup to read busy flag
   BSF LCD_CNTL, E ; Set E high
   BCF LCD_CNTL, E ; Set E low
   MOVF LCD_DATA, W ; Read upper nibble busy flag, DDRam address
   ANDLW 0xF0 ; Mask out lower nibble
   MOVWF TEMP
   BSF LCD_CNTL, E ; Toggle E to get lower nibble
   BCF LCD_CNTL, E
   SWAPF LCD_DATA, w ; Read lower nibble busy flag, DDRam address
   ANDLW 0x0F ; Mask out upper nibble
   IORWF TEMP ; Combine nibbles
   BTFSC TEMP, 7 ; Check busy flag, high = busy
   GOTO BUSY_CHECK ; If busy, check again
   BCF LCD_CNTL, RW
   MOVLW 0x0F
   MOVWF LCD_DATA_TRIS ; Set Port_D for output
