sx1278 driver
acel
sx1278 driver
PostPosted: Fri Jun 21, 2019 4:57 am     Reply with quote
Is there a driver for sx1278?
PostPosted: Fri Jun 21, 2019 10:21 am     Reply with quote
You need to post a link to the device datasheet !
As well WHICH 'SA1278' are you using ??
Also is this JUST the chip or a premade 'module' ?
Which PIC as 5 volt PICs tend to destroy 3 volt devices!
acel
PostPosted: Fri Jun 21, 2019 11:39 am     Reply with quote
https://www.semtech.com/uploads/documents/DS_SX1276-7-8-9_W_APP_V6.pdf
newguy
PostPosted: Fri Jun 21, 2019 11:58 am     Reply with quote
I can't share any code as it's paid for and owned by my employer, but I can suggest this:
- the Semtech code available on github which is written for a linux environment can be quite easily ported to CCS C.
- I strongly recommend that you purchase a pre-built module, for example the RAK831 (or equivalent) and a raspberry pi; install and configure any one of the many prebuilt projects available on github.
- use a logic analyzer to sniff the SPI traffic, rasp pi <=> RAK831 (or equivalent).
Do this and you'll be up and running quite quickly.
PostPosted: Fri Jun 21, 2019 3:13 pm     Reply with quote
Ok, so step one is to decide on a 3 volt PIC.
I'l assume you're going to get a premade 'module' and not try to solder something together ??
Jay
acel
PostPosted: Sat Jun 22, 2019 1:26 am     Reply with quote
Assume that a ready-made module will be used.
For example, this module:
https://www.likecircuit.com/433mhz-lora-ra-02-pinout-eagle-pcb-library/
PostPosted: Sat Jun 22, 2019 4:30 am     Reply with quote
Well, one easy way is to take the 'driver' from another micro series and convert into CCS style C. You're not the first one to use that device.
Also use Google to locate possible drivers for you. Not everyone using PICs comes to the CCS forum.
Usually the manufacturer will have a forum or apnotes (application notes) on how to use theri products.
That device, like most (all ?) wireless xcvrs, draws a LOT of power during xmt, about 120ma. Be SURE to use a high quality power supply good for at least 2 amps AND follow any layout/PCB design details the manfacturer lists in the datasheet.
Jay
