Driver for a 128x64 graphic lcd with the ST7920 chip
Post new topic   Reply to topic    CCS Forum Index -> Code Library
rolf_edmundo_guse
PostPosted: Sat Apr 27, 2019 6:30 am     Reply with quote
rolf_edmundo_guse wrote:
I'm new to this forum and I apologize if you're posting something wrong.
I'm struggling to find library glcd 128x64 drive st7920 someone would use pic18f87k22
After much work the library is working very well I am sharing mode 8bit mode 4 bit pin
ST7920.h
*                DRIVE PARA LCD GRAFICO 128X64 CHIP ST7920                 *
*   COMANDOS                                                               *
*   #define mode_8_bit user lcd mode 8 bit
*   #define mode_4_bit user lcd mode 4 bit
*   glcd_readByte()//LER DADOS DO LCD                                      *
*   glcd_check_busy()//VERIFICA SE LCD ESTA OCUPADO                        *                              *
*   glcd_instruction(instruções)//SETA INTRUÇÕES                           *
*   glcd_data(dados)//ENVIA DADOS PARA LCD                                 *
*   glcd_init_basic()//INICIA LCD  COMO MODO BASICO                        *
*   glcd_update()//ATUALIZA LCD                                            *
*   glcd_init_graph()//INICIA LCD MODO GRAFICO                             *
*   glcd_pixel( x,  y, color)//CONTROLE DE PIXEL                           *
*   glcd_fillScreen(on)//ENVIO NIVEL 1 PARA TODOS OS PIXEL DO LCD          *
*   glcd_fillScreen(off)//ENVIA NIVEL 0 PARA TODOS OS PIXEL DO LCD         *
*   glcd_plot_image(imagem,largura,altura,coluna,linha,cor) carrega imagem *
*   PINAGEM DO LCD                                                         *
*   Pin 1 ------------> Gnd                                                *
*   Pin 2 ------------> +5volts                                            *
*   Pin 3 ------------> Contrast                                           *
*   Pin 4 ------------> Register Select                                    *
*   Pin 5 ------------> Read/Write                                         *
*   Pin 6 ------------> Enable                                             *
*   Pin 7-14 ---------> Data bits                                          *
*   Pin 15 -----------> PSB (parallel=high & serial=low)                   *
*   Pin 16 -----------> NoConnection                                       *
*   Pin 17 -----------> Reset                                              *
*   Pin 18 -----------> Vout                                               *
*   Pin 19 -----------> +5volts                                            *
*   Pin 20 -----------> Gnd                                                *
//DEFINIÇÃO DE PINOS
//PIN DEFINITION
#define  RS        PIN_B2                    //COMMNAD/DATA SELECT
#define  RW        PIN_B3                    //READ/WRITE SELECT
#define  E         PIN_B4                    //ENABLE SIGNAL
#define  RST       PIN_B5                    //RESET SIGNAL
#if defined(mode_8_bit)// define pin lcd 8 bit
#define  D0        PIN_D0
#define  D1        PIN_D1
#define  D2        PIN_D2
#define  D3        PIN_D3
#define  D4        PIN_D4
#define  D5        PIN_D5
#define  D6        PIN_D6
#define  D7        PIN_D7
#define mode       0x10
#if defined(mode_4_bit)// define pin lcd 4 bit
#define  D4        PIN_D4
#define  D5        PIN_D5
#define  D6        PIN_D6
#define  D7        PIN_D7
#define mode       0x00
#define  set_lcd_bit  0x20 | (mode) //mode 4 bit
#define  ext_instru   0x24 | (mode) //Select extended instruction set
#define  graphic_on   0x26 | (mode) // Graphic display ON.
#define  set_lcd_on   0x0C //display on cursor off and char blink off
#define  set_mode_lcd 0x06 //entry mode set
#define  clear_lcd    0x01 //display clear
#define  DADOS_IN  INPUT_D()
#define  BUSY_IN   PIN_D7
#define  ON   1
#define  OFF   0
//LCD GRAPHICO 128X64
#define  YVAL 64 // DEFINE 64 LINHAS
#define  XVAL 8 // DEFINE COLUNAS 8X16=128 COLUNAS
#define GLCD_WIDTH   128 //DEFINE 128 COLUNAS
typedef union
  int16 word;
  int8 nbyte[2];
} Dots;
typedef struct
  int1 refresh;
  Dots pix[YVAL][XVAL];   // Max dimensions for display (x,y) = (128,32)
  } GD_RAM;             //  (0,0) corresponds to upper lefthand corner.
GD_RAM gdram;
unsigned int8 glcd_readByte (unsigned int1 address)//LER BYTE DO LCD
  unsigned int8 data;   // Stores the data read from the LCD
  if(address==1)
     output_high(rs);
  if(address==0)
     output_low(rs);
  output_high(rw);//GLCD_RW = RW_READ;      // Set for reading
  output_high(e);//GLCD_E = 1;      // Pulse the enable pin
  delay_us(1);
  data=DADOS_IN;      // Get the data from the display's output register
  output_low(e);//GLCD_E = 0;
  return (data);
void glcd_check_busy()//VERIFICA SE LCD ESTA OCUPADO
   int1 busy=1;
   output_low(rs);      // LOW RS and High RW will put the lcd to
   output_high(rw);      // read busy flag and address counter
   while(busy)
   {         // will cycle until busy flag is 0
      output_high(e);
      if(!input(BUSY_IN))
         busy=0;
      output_low(e);
void glcd_instruction(unsigned char x)//ENVIA INSTRUÇÕES PARA LCD
  #if defined(mode_8_bit)// 8 bit mode
   glcd_check_busy();      //must be satisfied before sending instruction
   output_low(rs);      // LOW RS and LOW RW will put the lcd to
   output_low(rw);      // Write instruction mode
   Delay_us(5);  //Delay
   output_bit(D7,bit_test(x,7)); //send data bit 7 pin D7
   output_bit(D6,bit_test(x,6)); //send data bit 6 pin D6
   output_bit(D5,bit_test(x,5)); //send data bit 5 pin D5
   output_bit(D4,bit_test(x,4)); //send data bit 4 pin D4
   output_bit(D3,bit_test(x,3)); //send data bit 3 pin D3
   output_bit(D2,bit_test(x,2)); //send data bit 2 pin D2
   output_bit(D1,bit_test(x,1)); //send data bit 1 pin D1
   output_bit(D0,bit_test(x,0)); //send data bit 0 pin D0
   Delay_us(10);
   output_high(e);//anable
   Delay_us(20);
   output_low(e);// disable
 #if defined(mode_4_bit) // 4 bit mode
   Delay_us(5);//Delay
   Delay_us(5);
   output_high(e); //enable
   Delay_us(5);
   output_low(e); //disable
   Delay_us(5);
   output_bit(D7,bit_test(x,3));//send data low bit 3 pin D7
   output_bit(D6,bit_test(x,2));//send data low bit 2 pin D6
   output_bit(D5,bit_test(x,1));//send data low bit 1 pin D5
   output_bit(D4,bit_test(x,0));//send data low bit 0 pin D4
   Delay_us(5);
   output_high(e);
   Delay_us(5);
   output_low(e); // disable
void glcd_data(unsigned char x)//ENVIA DADOS PARA LCD
  #if defined(mode_8_bit) // 8 bit mode
   glcd_check_busy();
   output_high(rs);      // HIGH RS and LOW RW will put the lcd to
   output_low(rw);      // Write data register mode
   Delay_us(5);
   Delay_us(10);
   output_high(e);
   Delay_us(20);
   glcd_check_busy();
   Delay_us(5);
   output_bit(D7,bit_test(x,7));//send data high bit 7 pin D7
   output_bit(D6,bit_test(x,6));//send data high bit 6 pin D6
   output_bit(D5,bit_test(x,5));//send data high bit 5 pin D5
   output_bit(D4,bit_test(x,4));//send data high bit 4 pin D4
   Delay_us(5);
   output_high(e);
   Delay_us(5);
   Delay_us(5);
   Delay_us(5);
   output_high(e);
   Delay_us(5);
void glcd_fillScreen (unsigned int1 color)//GRAVA 1 OU 0 EM TODOS OS PIXEL
  int8 v, h;
  int16 d;
  d = (color == ON ? 0xFFFF : 0x0000);
 // d = (color == ON ? 0x0000 : 0xFFFF );
  for (v=0; v < YVAL; v++)//32
    for (h=0; h < XVAL; h++)//16
      gdram.pix[v][h].word = d;
  gdram.refresh = TRUE;
void glcd_update ()//ATUALIZA LCD
  int8 v, h;
  if (gdram.refresh)//verifica se foi atualizado
    for (v=0; v <YVAL; v++) //64 linhas
      if(v<32)
         glcd_instruction( 0x80 | v);   // Set Vertical Address.
         glcd_instruction( 0x80);   // Set Horizontal Address.
         glcd_instruction( 0x80 | (v - 32));   // Set Vertical Address.
         glcd_instruction( 0x88);   // Set Horizontal Address.
      for (h=0; h <XVAL; h++) //8x16=128 colunas
        glcd_data( gdram.pix[v][h].nbyte[1]);   // Write High Byte.
        glcd_data( gdram.pix[v][h].nbyte[0]);   // Write Low Byte.
    gdram.refresh = FALSE;
void glcd_init_graph()//INICIA EM MODO GRAPHICO
   delay_ms(40);
   output_low(rst);  //reset LCD
   delay_us(1);
   output_high(rst);  //LCD normal operation
   glcd_instruction(set_lcd_bit);  //set 4 and 8  bit operation and basic instruction set
   delay_us(144);
   glcd_instruction(0x0C);  //display on cursor off and char blink off
   delay_us(100);
   glcd_instruction(clear_lcd);  //display clear
   delay_ms(10);
   glcd_instruction(set_mode_lcd);  //entry mode set
   delay_us(72);
   glcd_instruction(ext_instru);  // Select extended instruction set.
   delay_us (72);
   glcd_instruction(graphic_on);  // Graphic display ON.
   delay_us (72);
   glcd_fillScreen (OFF); // clear all pixel
   glcd_update (); // update display
void glcd_init_basic()//INICIA EM MODO BASICO
   delay_ms(40);
   delay_us(1);
   glcd_instruction(set_lcd_bit);   //set 4 bit operation and basic instruction set
   delay_us(144);
   delay_us(100);
   delay_ms(10);
   delay_us(72);
//              0     0        0
void glcd_pixel(int8 x, int8 y, int1 color)//GRAVA NOVO VALOR DOS PIXEL
  int8 v, h, b;
  v = y;
  h = x/16;
  b = 15 - (x%16);
  if (color == ON)
   bit_set (gdram.pix[v][h].word, b);
   bit_clear (gdram.pix[v][h].word, b);
void glcd_plot_image(ROM char *img,int width,int height,int x,int y,int inverse)//CARREGA IMAGEM
   unsigned int i=0, j=0, k=0;
   unsigned int16 count=0;
   //glcd_fillScreen(OFF);                        //Clears the screen (opt.)
   for(j=0;j<height;j++)//linhas
         for(;i<width;)//colunas
           for(k=0;k<8;k++)//bite
               if(inverse)
               {//           0  ,0  ,
                 glcd_pixel(i+x,j+y,~bit_test(img[count],(k)));
                  glcd_pixel(i+x,j+y,bit_test(img[count],(k)));
               i++;
            count++;
      i=0;
Last edited by rolf_edmundo_guse on Sun May 19, 2019 3:47 pm; edited 1 time in total
rolf_edmundo_guse
Re: Help for GLCD 128X64 driver ST7920
PostPosted: Sat Apr 27, 2019 6:49 am     Reply with quote
link to display GLCD running
https://uploaddeimagens.com.br/images/002/069/872/original/WhatsApp_Image_2019-04-27_at_09.33.20.jpeg?1556368610
klebaum
Very good !!
PostPosted: Thu May 02, 2019 8:52 am     Reply with quote
Congratulations for your work.
Can you also use this display in serial mode?
See you.
rolf_edmundo_guse
Re: Very good !!
PostPosted: Sun May 19, 2019 3:34 pm     Reply with quote
See you.
Hello, at the moment I did not realize a library in serial mode, only in 8-bit and 4-bit.
MarkchchPIC
Great Work
PostPosted: Mon May 20, 2019 2:44 pm     Reply with quote
Hi there,
Driver looks very good.
Can you provide an example to show the setup you have used.
Cheers
Mark
rolf_edmundo_guse
Re: Great Work
PostPosted: Mon May 20, 2019 7:46 pm     Reply with quote
MarkchchPIC wrote:
Hi there,
Cheers
Mark
exemple code user main.c
#include <18F87K22.h>
#device ADC=16
#define  mode_4_bit //define glcd 4 bit mode
#use delay(CLOCK=64M, CRYSTAL=16M)
#include "imagem.h"
#include "st7920.h"
#include "graphics.c"
#include <math.h>
int16 adc;
float media_adc;
const unsigned char TAB[]={'T','E','S','T','E','-','O','K'};
void Voltage()
   set_adc_channel(0);
   adc = read_adc();
   media_adc = ((adc*.07554945)/1000);
   char voltage[9];
   sprintf(voltage, "%.2f", (float)media_adc); // Converts adc to text
   //sprintf(voltage, "%Lu",(int16)read_adc());
   voltage[5] = '\0';                              // Limit shown digits to 5
   voltage[4] = 'V';
   glcd_rect(11, 0, 50, 8, yes, on);
   glcd_text57(12, 1, voltage, 1, off);//printf
void mode_basic()//glcd mode basic
    glcd_init_basic(); //init glcd basic
    glcd_instruction(clear_lcd);// clear glcd
   for(int i=0;i<8;i++)
      glcd_data(TAB[i]);//printf glcd mode text
   Delay_ms(500);
void mode_graphic()
   glcd_init_graph();//glcd modo graphico
   glcd_fillScreen(OFF);//clear glcd
   for(int cont=0; cont<200; cont++)
      glcd_plot_image(antena,11,9,0,0,1);//imagem, comprimento, altura, coluna, linha, cor
      glcd_plot_image(trator,11,9,0,18,0);//imagem, comprimento, altura, coluna, linha, cor
      glcd_plot_image(bico_on,11,9,64,0,0);//imagem, comprimento, altura, coluna, linha, cor
      glcd_plot_image(fluxometro,11,9,64,18,0);//imagem, comprimento, altura, coluna, linha, cor
      glcd_plot_image(barra,128,5,0,49,0);//imagem, comprimento, altura, coluna, linha, co
      glcd_plot_image(bico_off,11,9,0,54,1);//imagem, comprimento, altura, coluna, linha, cor
      glcd_plot_image(bico_on,11,9,59,54,0);//imagem, comprimento, altura, coluna, linha, cor
      glcd_plot_image(bico_on,11,9,115,54,0);//imagem, comprimento, altura, coluna, linha, cor
      voltage();//read ad chanel 0
      glcd_update();//update glcd
     // Delay_ms(5);
void main ()
   setup_adc_ports(sAN0);
   setup_adc(ADC_CLOCK_DIV_32|ADC_TAD_MUL_4);
   set_adc_channel(0);
   glcd_fillScreen(off);// glcd clear full pixel 0
   glcd_update();// glcd update
   glcd_plot_image(logo_inicio,128,64,0,0,0);//imagem,width,height,columm,line,color pixel
   Delay_ms(2000);//Delay
      mode_basic();
      mode_graphic();
imagem.h
//imagem 11x9 antena
ROM  char antena[]={
0x00, 0x00, 0xFC, 0x01, 0x02, 0x02, 0xF9, 0x04,
0x04, 0x01, 0x72, 0x02, 0x88, 0x00, 0x20, 0x00,
0x00, 0x00
//imagem 11x9 bateria
ROM  char bateria[]={
0x04, 0x00, 0x8E, 0x03, 0x04, 0x00, 0xFE, 0x03,
0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02,
0xFE, 0x03};
//imagem 11x9 bico ligado
ROM  char bico_on[]={
0xF8, 0x00, 0xF8, 0x00, 0x70, 0x00, 0x20, 0x00,
0x50, 0x00, 0xA8, 0x00, 0x54, 0x01, 0xAA, 0x02,
0x55, 0x05};
//imagem 11x9 bico desligado
ROM  char bico_off[]={
0x88, 0x00, 0x50, 0x00, 0x20, 0x00, 0x50, 0x00,
0x88, 0x00};
//imagem 128x5 barra
ROM  char barra[]={
0x00, 0xFE, 0xBF, 0xFF, 0xFF, 0xFB, 0xFF, 0xFF,
0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xFD, 0x7F, 0x00,
0x80, 0x11, 0xF1, 0x11, 0x11, 0x1F, 0x86, 0x61,
0x86, 0x61, 0xF8, 0x88, 0x88, 0x8F, 0x88, 0x01,
0x60, 0xAA, 0xAA, 0xAA, 0xAA, 0x2A, 0x49, 0x92,
0x49, 0x92, 0x54, 0x55, 0x55, 0x55, 0x55, 0x06,
0x18, 0x44, 0xE4, 0x44, 0x44, 0xCE, 0x30, 0x8C,
0x31, 0x0C, 0x73, 0x22, 0x22, 0x27, 0x22, 0x18,
0xFC, 0xFF, 0xBF, 0xFF, 0xFF, 0xFB, 0xFF, 0xFF,
0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xFD, 0xFF, 0x3F};
//imagem 11x9 trator
ROM  char trator[]={
0x00, 0x00, 0x1E, 0x00, 0x92, 0x00, 0x92, 0x00,
0xFE, 0x03, 0xFB, 0x07, 0xF1, 0x03, 0x9B, 0x02,
0x8E, 0x03};
//imegem 11x9 fluxometro
ROM  char fluxometro[]={
0xF8, 0x00, 0x24, 0x01, 0xAA, 0x02, 0x72, 0x02,
0xDE, 0x03, 0x72, 0x02, 0xAA, 0x02, 0x24, 0x01,
0xF8, 0x00};
ROM  char logo_inicio[]={
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0,
0x0F, 0x00, 0xFC, 0xFF, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
0x10, 0x00, 0xFE, 0xFF, 0x03, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xF8,
0x3F, 0x00, 0xFE, 0xFF, 0x03, 0x00, 0x00, 0x00,
0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0xC5, 0x07,
0x40, 0x00, 0x1E, 0x80, 0x03, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04,
0x40, 0x00, 0x1E, 0x80, 0x83, 0x00, 0x00, 0x00,
0xC0, 0x00, 0x1E, 0x80, 0x83, 0x00, 0x00, 0x00,
0x40, 0x01, 0x1E, 0x80, 0x83, 0x00, 0x00, 0x00,
0x40, 0x02, 0x1E, 0x80, 0x83, 0x00, 0x00, 0x00,
0x40, 0x04, 0xFE, 0xFF, 0xFF, 0xFF, 0x07, 0x00,
0x40, 0x08, 0xFE, 0xFF, 0xFF, 0xFF, 0x0F, 0x00,
0x40, 0x10, 0xFE, 0xFF, 0x07, 0x80, 0x0F, 0x00,
0x40, 0x20, 0x1E, 0xFC, 0xFF, 0xFF, 0x0F, 0x00,
0xC0, 0xFF, 0x07, 0xF0, 0xFF, 0xFF, 0x0F, 0x00,
0x40, 0x20, 0x01, 0xC0, 0xFF, 0xFF, 0xFF, 0x03,
0x40, 0x10, 0x01, 0xC0, 0xFF, 0xFF, 0xFF, 0x07,
0x40, 0x88, 0x00, 0x80, 0xFF, 0xFF, 0xFF, 0x07,
0x40, 0x84, 0xC0, 0x81, 0xFF, 0xFF, 0x83, 0x00,
0x40, 0x42, 0x20, 0x02, 0xFF, 0xFF, 0x01, 0x01,
0x40, 0x41, 0x90, 0x04, 0xFF, 0xFF, 0x38, 0x02,
0xC0, 0x40, 0x50, 0x05, 0xFF, 0x7F, 0x44, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC4,
0x43, 0x40, 0x90, 0x04, 0x01, 0x40, 0x82, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x24,
0x44, 0x40, 0x20, 0x02, 0x01, 0x40, 0x92, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x14,
0x48, 0x80, 0xC0, 0x81, 0x00, 0x40, 0x82, 0x04,
0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0xC5, 0x8F,
0x51, 0x00, 0x01, 0x40, 0x00, 0x40, 0x44, 0x04,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x4C,
0x32, 0x00, 0x01, 0x40, 0x00, 0x80, 0x38, 0x02,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x48,
0x12, 0x00, 0x06, 0x30, 0x00, 0x00, 0x01, 0x01,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x88,
0x11, 0x00, 0x18, 0x0C, 0x00, 0x00, 0x82, 0x00,
0x08, 0x00, 0xE0, 0x03, 0x00, 0x00, 0x7C, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20,
0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0,
0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
graphic.c
////                          graphics.c                             ////
////   This file contains functions to draw lines, rectangles, bars, ////
////   circles and text to a display. A function which draws a       ////
////   single pixel must be defined before calling the functions in  ////
////   this file. Call it glcd_pixel(x, y, color) where x is the     ////
////   horizontal coordinate, y is the vertical coordinate, and      ////
////   color is 1 bit to turn the pixel on or off.                   ////
////   * Note: (0, 0) is treated as the upper left corner            ////
////  glcd_line(x1, y1, x2, y2, color)                               ////
////     * Draws a line from the first point to the second point     ////
////       with the given color                                      ////
////       - color can be ON or OFF                                  ////
////  glcd_rect(x1, y1, x2, y2, fill, color)                         ////
////     * Draws a rectangle with one corner at point (x1,y1) and    ////
////       the other corner at point (x2,y2)                         ////
////       - fill can be YES or NO                                   ////
////  glcd_bar(x1, y1, x2, y2, width, color)                         ////
////     * Draws a bar (wide line) from the first point to the       ////
////       second point                                              ////
////       - width is the number of pixels wide                      ////
////       - color is ON or OFF                                      ////
////  glcd_circle(x, y, radius, fill, color)                         ////
////     * Draws a circle with center at (x,y)                       ////
////  glcd_text57(x, y, textptr, size, color)                        ////
////     * Write the null terminated text pointed to by textptr with ////
////       the upper left coordinate of the first character at (x,y) ////
////       Characters are 5 pixels wide and 7 pixels tall            ////
////       - size is an integer that scales the size of the text     ////
////     * Note - This function wraps characters to the next line    ////
////              use #define GLCD_WIDTH to specify a display width  ////
////        (C) Copyright 1996, 2010 Custom Computer Services        ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#ifndef GRAPHICS_DRAWING_FUNCTIONS
#define GRAPHICS_DRAWING_FUNCTIONS
#ifndef ON
#define ON  1
#ifndef OFF
#define OFF 0
#ifndef YES
#define YES 1
#ifndef NO
#define NO  0
//// Defines a 5x7 font
const unsigned int8 FONT[51][5] ={0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
                         0x00, 0x00, 0x5F, 0x00, 0x00, // !
                         0x00, 0x03, 0x00, 0x03, 0x00, // "
                         0x14, 0x3E, 0x14, 0x3E, 0x14, // #
                         0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
                         0x43, 0x33, 0x08, 0x66, 0x61, // %
                         0x36, 0x49, 0x55, 0x22, 0x50, // &
                         0x00, 0x05, 0x03, 0x00, 0x00, // '
                         0x00, 0x1C, 0x22, 0x41, 0x00, // (
                         0x00, 0x41, 0x22, 0x1C, 0x00, // )
                         0x14, 0x08, 0x3E, 0x08, 0x14, // *
                         0x08, 0x08, 0x3E, 0x08, 0x08, // +
                         0x00, 0x50, 0x30, 0x00, 0x00, // ,
                         0x08, 0x08, 0x08, 0x08, 0x08, // -
                         0x00, 0x60, 0x60, 0x00, 0x00, // .
                         0x20, 0x10, 0x08, 0x04, 0x02, // /
                         0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
                         0x00, 0x04, 0x02, 0x7F, 0x00, // 1
                         0x42, 0x61, 0x51, 0x49, 0x46, // 2
                         0x22, 0x41, 0x49, 0x49, 0x36, // 3
                         0x18, 0x14, 0x12, 0x7F, 0x10, // 4
                         0x27, 0x45, 0x45, 0x45, 0x39, // 5
                         0x3E, 0x49, 0x49, 0x49, 0x32, // 6
                         0x01, 0x01, 0x71, 0x09, 0x07, // 7
                         0x36, 0x49, 0x49, 0x49, 0x36, // 8
                         0x26, 0x49, 0x49, 0x49, 0x3E, // 9
                         0x00, 0x36, 0x36, 0x00, 0x00, // :
                         0x00, 0x56, 0x36, 0x00, 0x00, // ;
                         0x08, 0x14, 0x22, 0x41, 0x00, // <
                         0x14, 0x14, 0x14, 0x14, 0x14, // =
                         0x00, 0x41, 0x22, 0x14, 0x08, // >
                         0x02, 0x01, 0x51, 0x09, 0x06, // ?
                         0x3E, 0x41, 0x59, 0x55, 0x5E, // @
                         0x7E, 0x09, 0x09, 0x09, 0x7E, // A
                         0x7F, 0x49, 0x49, 0x49, 0x36, // B
                         0x3E, 0x41, 0x41, 0x41, 0x22, // C
                         0x7F, 0x41, 0x41, 0x41, 0x3E, // D
                         0x7F, 0x49, 0x49, 0x49, 0x41, // E
                         0x7F, 0x09, 0x09, 0x09, 0x01, // F
                         0x3E, 0x41, 0x41, 0x49, 0x3A, // G
                         0x7F, 0x08, 0x08, 0x08, 0x7F, // H
                         0x00, 0x41, 0x7F, 0x41, 0x00, // I
                         0x30, 0x40, 0x40, 0x40, 0x3F, // J
                         0x7F, 0x08, 0x14, 0x22, 0x41, // K
                         0x7F, 0x40, 0x40, 0x40, 0x40, // L
                         0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
                         0x7F, 0x02, 0x04, 0x08, 0x7F, // N
                         0x3E, 0x41, 0x41, 0x41, 0x3E, // O
                         0x7F, 0x09, 0x09, 0x09, 0x06, // P
                         0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
                         0x7F, 0x09, 0x09, 0x09, 0x76};// R
const unsigned int8 FONT2[44][5]={0x26, 0x49, 0x49, 0x49, 0x32, // S
                         0x01, 0x01, 0x7F, 0x01, 0x01, // T
                         0x3F, 0x40, 0x40, 0x40, 0x3F, // U
                         0x1F, 0x20, 0x40, 0x20, 0x1F, // V
                         0x7F, 0x20, 0x10, 0x20, 0x7F, // W
                         0x41, 0x22, 0x1C, 0x22, 0x41, // X
                         0x07, 0x08, 0x70, 0x08, 0x07, // Y
                         0x61, 0x51, 0x49, 0x45, 0x43, // Z
                         0x00, 0x7F, 0x41, 0x00, 0x00, // [
                         0x02, 0x04, 0x08, 0x10, 0x20, // \
                         0x00, 0x00, 0x41, 0x7F, 0x00, // ]
                         0x04, 0x02, 0x01, 0x02, 0x04, // ^
                         0x40, 0x40, 0x40, 0x40, 0x40, // _
                         0x00, 0x01, 0x02, 0x04, 0x00, // `
                         0x20, 0x54, 0x54, 0x54, 0x78, // a
                         0x7F, 0x44, 0x44, 0x44, 0x38, // b
                         0x38, 0x44, 0x44, 0x44, 0x44, // c
                         0x38, 0x44, 0x44, 0x44, 0x7F, // d
                         0x38, 0x54, 0x54, 0x54, 0x18, // e
                         0x04, 0x04, 0x7E, 0x05, 0x05, // f
                         0x08, 0x54, 0x54, 0x54, 0x3C, // g
                         0x7F, 0x08, 0x04, 0x04, 0x78, // h
                         0x00, 0x44, 0x7D, 0x40, 0x00, // i
                         0x20, 0x40, 0x44, 0x3D, 0x00, // j
                         0x7F, 0x10, 0x28, 0x44, 0x00, // k
                         0x00, 0x41, 0x7F, 0x40, 0x00, // l
                         0x7C, 0x04, 0x78, 0x04, 0x78, // m
                         0x7C, 0x08, 0x04, 0x04, 0x78, // n
                         0x38, 0x44, 0x44, 0x44, 0x38, // o
                         0x7C, 0x14, 0x14, 0x14, 0x08, // p
                         0x08, 0x14, 0x14, 0x14, 0x7C, // q
                         0x00, 0x7C, 0x08, 0x04, 0x04, // r
                         0x48, 0x54, 0x54, 0x54, 0x20, // s
                         0x04, 0x04, 0x3F, 0x44, 0x44, // t
                         0x3C, 0x40, 0x40, 0x20, 0x7C, // u
                         0x1C, 0x20, 0x40, 0x20, 0x1C, // v
                         0x3C, 0x40, 0x30, 0x40, 0x3C, // w
                         0x44, 0x28, 0x10, 0x28, 0x44, // x
                         0x0C, 0x50, 0x50, 0x50, 0x3C, // y
                         0x44, 0x64, 0x54, 0x4C, 0x44, // z
                         0x00, 0x08, 0x36, 0x41, 0x41, // {
                         0x00, 0x00, 0x7F, 0x00, 0x00, // |
                         0x41, 0x41, 0x36, 0x08, 0x00, // }
                         0x02, 0x01, 0x02, 0x04, 0x02};// ~
// Purpose:       Draw a line on a graphic LCD using Bresenham's
//                line drawing algorithm
// Inputs:        (x1, y1) - the start coordinate
//                (x2, y2) - the end coordinate
//                color - ON or OFF
// Dependencies:  glcd_pixel()
#ifdef LARGE_LCD
void glcd_line(unsigned int16 x1, unsigned int16 y1, unsigned int16 x2, unsigned int16 y2, int1 color)
#else
void glcd_line(unsigned int8 x1, unsigned int8 y1, unsigned int8 x2, unsigned int8 y2, int1 color)
   unsigned int16        dy, dx;
   signed int8  addx=1, addy=1;
   signed int16 P, diff;
   #ifdef LARGE_LCD
   unsigned int16 i=0;
   dx = abs((signed int16)(x2 - x1));
   dy = abs((signed int16)(y2 - y1));
   #else
   unsigned int8 i=0;
   dx = abs((signed int8)(x2 - x1));
   dy = abs((signed int8)(y2 - y1));
   if(x1 > x2)
      addx = -1;
   if(y1 > y2)
      addy = -1;
   if(dx >= dy)
      dy *= 2;
      P = dy - dx;
      diff = P - dx;
      for(; i<=dx; ++i)
         glcd_pixel(x1, y1, color);
         if(P < 0)
            P  += dy;
            x1 += addx;
            P  += diff;
            x1 += addx;
            y1 += addy;
      dx *= 2;
      P = dx - dy;
      diff = P - dy;
      for(; i<=dy; ++i)
         if(P < 0)
            P  += dx;
            y1 += addy;
            P  += diff;
            x1 += addx;
            y1 += addy;
// Purpose:       Draw a rectangle on a graphic LCD
//                fill  - YES or NO
// Dependencies:  glcd_pixel(), glcd_line()
#ifdef LARGE_LCD
void glcd_rect(unsigned int16 x1, unsigned int16 y1, unsigned int16 x2, unsigned int16 y2, int1 fill, int1 color)
#else
void glcd_rect(unsigned int8 x1, unsigned int8 y1, unsigned int8 x2, unsigned int8 y2, int1 fill, int1 color)
   if(fill)
      #ifdef LARGE_LCD
      unsigned int16 i, xmin, xmax, ymin, ymax;
      #else
      unsigned int8  i, xmin, xmax, ymin, ymax;
      if(x1 < x2)                            //  Find x min and max
         xmin = x1;
         xmax = x2;
         xmin = x2;
         xmax = x1;
      if(y1 < y2)                            // Find the y min and max
         ymin = y1;
         ymax = y2;
         ymin = y2;
         ymax = y1;
      for(; xmin <= xmax; ++xmin)
         for(i=ymin; i<=ymax; ++i)
            glcd_pixel(xmin, i, color);
      glcd_line(x1, y1, x2, y1, color);      // Draw the 4 sides
      glcd_line(x1, y2, x2, y2, color);
      glcd_line(x1, y1, x1, y2, color);
      glcd_line(x2, y1, x2, y2, color);
// Purpose:       Draw a bar (wide line) on a graphic LCD
//                width  - The number of pixels wide
#ifdef LARGE_LCD
void glcd_bar(unsigned int16 x1, unsigned int16 y1, unsigned int16 x2, unsigned int16 y2, unsigned int8 width, int1 color)
#else
void glcd_bar(unsigned int8 x1, unsigned int8 y1, unsigned int8 x2, unsigned int8 y2, unsigned int8 width, int1 color)
   unsigned int8         half_width;
   signed int8  addx=1, addy=1, j;
   signed int16 P, diff, c1, c2;
   #ifdef LARGE_LCD
   unsigned int16 i=0;
   #else
   unsigned int8 i=0;
   half_width = width/2;
   c1 = -(dx*x1 + dy*y1);
   c2 = -(dx*x2 + dy*y2);
   if(x1 > x2)
      signed int16 temp;
      temp = c1;
      c1 = c2;
      c2 = temp;
      addx = -1;
   if(y1 > y2)
      signed int16 temp;
      temp = c1;
      c1 = c2;
      c2 = temp;
      addy = -1;
   if(dx >= dy)
      P = 2*dy - dx;
      diff = P - dx;
      for(i=0; i<=dx; ++i)
         for(j=-half_width; j<half_width+width%2; ++j)
               glcd_pixel(x1, y1+j, color);
         if(P < 0)
            P  += 2*dy;
            x1 += addx;
            P  += diff;
            x1 += addx;
            y1 += addy;
      P = 2*dx - dy;
      diff = P - dy;
      for(i=0; i<=dy; ++i)
         if(P < 0)
            P  += 2*dx;
            y1 += addy;
            P  += diff;
            x1 += addx;
            y1 += addy;
               glcd_pixel(x1+j, y1, color);
// Purpose:       Draw a circle on a graphic LCD
// Inputs:        (x,y) - the center of the circle
//                radius - the radius of the circle
//                fill - YES or NO
#ifdef LARGE_LCD
void glcd_circle(unsigned int16 x, unsigned int16 y, unsigned int16 radius, int1 fill, int1 color)
#else
void glcd_circle(unsigned int8 x, unsigned int8 y, unsigned int8 radius, int1 fill, int1 color)
   #ifdef LARGE_LCD
   signed int16 a, b, P;
   #else
   signed int8  a, b, P;
   a = 0;
   b = radius;
   P = 1 - radius;
   do
      if(fill)
         glcd_line(x-a, y+b, x+a, y+b, color);
         glcd_line(x-a, y-b, x+a, y-b, color);
         glcd_line(x-b, y+a, x+b, y+a, color);
         glcd_line(x-b, y-a, x+b, y-a, color);
         glcd_pixel(a+x, b+y, color);
         glcd_pixel(b+x, a+y, color);
         glcd_pixel(x-a, b+y, color);
         glcd_pixel(x-b, a+y, color);
         glcd_pixel(b+x, y-a, color);
         glcd_pixel(a+x, y-b, color);
         glcd_pixel(x-a, y-b, color);
         glcd_pixel(x-b, y-a, color);
      if(P < 0)
         P += 3 + 2 * a++;
         P += 5 + 2 * (a++ - b--);
    } while(a <= b);
// Purpose:       Write text on a graphic LCD
// Inputs:        (x,y) - The upper left coordinate of the first letter
//                textptr - A pointer to an array of text to display
//                size - The size of the text: 1 = 5x7, 2 = 10x14, ...
#ifdef LARGE_LCD
void glcd_text57(unsigned int16 x, unsigned int16 y, char* textptr, unsigned int8 size, int1 color)
#else
void glcd_text57(unsigned int8 x, unsigned int8 y, char* textptr, unsigned int8 size, int1 color)
   unsigned int8 j, k, l, m;                       // Loop counters
   unsigned int1 inv=~color;
   unsigned int8 pixelData[5];                     // Stores character data
   //if(color==1)inv=0;
   //else inv=1;
   for(; *textptr != '\0'; ++textptr, ++x)// Loop through the passed string
      if(*textptr < 'S') // Checks if the letter is in the first font array
         memcpy(pixelData, FONT[*textptr - ' '], 5);
      else if(*textptr <= '~') // Check if the letter is in the second font array
         memcpy(pixelData, FONT2[*textptr - 'S'], 5);
         memcpy(pixelData, FONT[0], 5);   // Default to space
      // Handles newline and carriage returns
      switch(*textptr)
         case '\n':
            y += 7*size + 1;
            continue;
         case '\r':
            x = 0;
            continue;
      if(x+5*size >= GLCD_WIDTH)          // Performs character wrapping
         x = 0;                           // Set x at far left position
         y += 7*size + 1;                 // Set y at next position down
      for(j=0; j<5; ++j, x+=size)         // Loop through character byte data
         for(k=0; k < 7; ++k)             // Loop through the vertical pixels
            if(bit_test(pixelData[j], k)) // Check if the pixel should be set
               for(l=0; l < size; ++l)    // These two loops change the
               {                          // character's size
                  for(m=0; m < size; ++m)
                     glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
                     glcd_pixel(x+m, y+k*size+l, inv); // Draws the pixel
MarkchchPIC
PostPosted: Tue May 21, 2019 3:28 pm     Reply with quote
Thanks for the example, Really helpful.
Cheers
Mark
alfredoBH
Re: Driver for a 128x64 graphic lcd with the ST7920 chip
PostPosted: Sun Aug 11, 2019 3:30 pm     Reply with quote
That's really great job.
Can you post the macro definition codes you used in the example you posted?
Thanks!!!
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
