RLScott
| CCS MPLAB X Plug-in [Solved] |
Posted: Mon Apr 29, 2019 9:53 pm |
I want to switch from MPLAB 8 to MPLAB X. I have installed MPLAB X and the CCS Mplab-x plug-in. But when I try to import a MPLAB-8 project that was working fine with MPLAB 8, the CCS toolchain does not appear as an option. Is there something else I need to do to use the CCS compiler from within MPLAB X? (I have the latest MPLAB X, 5.15)
Edit: Never mind. I found the Tools menu where I could install the CCS plugin into MPLAB X. _________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting |
