wiper motor control with encoder
Goto page Previous  1, 2
ertansuluagac
PostPosted: Sun Apr 21, 2019 2:05 pm     Reply with quote
I understand. Does ex_encoder.c work? Also as circuit connection;
after I give a voltage, I will enter the A and B pins into my processor. You don't have another pin already. So I will now determine the position based on the number of pulses from A and B. There's nothing else I can do. I just want a sample code for this kind of engine. Is there no other example than ex_encoder.c ? Ttelmah wrote, I will write code with values for A, B. how can I write code ?
Es
PostPosted: Sun Apr 21, 2019 2:25 pm     Reply with quote
EX_ENCOD.c does work, did almost 20 years ago...
There are 1,000s of PIC based 'encoder' programs on the internet but why not just use what CCS freely supplies ? We can help as we all have that program.
With simple AB encoders, you normally powerup, drive the motor one way to a 'home' position, There a switch tells the PIC 'I'm home', shuts off the motor, resets the encoder position pulse counter variable to 0. After that you tell the motor to run and count pulses. How long to run and how many pulses can be determined on the bench. That 'R&D' is out of our control, you'll have to test.
Jay
ertansuluagac
PostPosted: Mon Apr 22, 2019 12:50 am     Reply with quote
I understand, but I'm already using CCS C licensed software. I have version 5.085. I'm already trying to do with CCS C.
Es
PostPosted: Mon Apr 22, 2019 1:40 am     Reply with quote
The point is if you have the compiler, you already have a program example
of how to read an encoder. It's with the compiler.....
In the examples directory.
ertansuluagac
PostPosted: Mon Apr 22, 2019 2:40 am     Reply with quote
I was understand. There are 4 examples.
1- ex_encry.c
2- ex_encod.c
3- ex_sk_rotary_encoder_isr
4- ex_sk_rotary_encoder.c
I think, ex_encod.c of them, seems to benefit me. or do you have any other suggestions?
Es
PostPosted: Mon Apr 22, 2019 4:57 am     Reply with quote
#1 I think is for encryption..
#2 is what I suggest.. I know it works, simple to use.
#3, #4 I don't have, as I have a very old compiler version.
Jay
ertansuluagac
PostPosted: Mon Apr 22, 2019 6:20 am     Reply with quote
I understand. I'll try ex_encod.c. I will write the result. Thanks everyone.
Es
Page 2 of 2
