cvargcal
| Control RDA |
Posted: Mon Apr 01, 2019 9:19 am |
Hi, I need help logic for can capture this string
Example AT Commad
AT CMD Response
AT{0D} {0D}{0A}OK{0D}{0A}
AT+CGSN{0D} {0D}{0A}861445030295583 {0D}{0A}{0D}{0A}OK{0D}{0A}
AT+CPIN?{0D} {0D}{0A}+CPIN: READY {0D}{0A}{0D}{0A}OK{0D}{0A}
AT+CSQ{0D} {0D}{0A}+CSQ: 26,0 {0D}{0A}{0D}{0A}OK{0D}{0A}
AT+CREG?{0D} {0D}{0A}+CREG: 0,1 {0D}{0A}{0D}{0A}OK{0D}{0A}
AT+CIFSR{0D} {0D}{0A}10.140.148.116 {0D}{0A}
AT+CBC{0D} {0D}{0A}+CBC: 0,100,4202 {0D}{0A}{0D}{0A}OK {0D}{0A}
start {0D}{0A}
end {0D}{0A}
I am working with sim800L module 2G, I want use the RDA for capture the response.
The problem is repeat the 0D many times.
| Code: | #int_rda
void rda_isr(){
bufferByte = getchar(MODEM);
// See what we got
if (bufferByte == 0x0D){
moduleResonseBuffer[moduleBufferIndex] = 0x00; // Add Null terminator
messageReady=1; // Message Ready
moduleBufferIndex = 0; // Prepare index for next message
else if ( (bufferByte == 0x00) || (bufferByte == 0x0A) )
// Do nothing
moduleResonseBuffer[moduleBufferIndex++] = bufferByte; // Add Byte to Buffer
someone idea please? |
Posted: Mon Apr 01, 2019 10:22 am |
You need to look for the OK sequence, not the 0xD. 0xD is the end of line
marker, and it'll send this at several points in the reply. OK marks
the end of the actual response. |
dluu13
Posted: Mon Apr 01, 2019 11:56 am |
There might be a better way, but I used the esp8266, which also uses the AT codes.
My RDA interrupt puts things into a circular buffer. In my main loop, and whenever there's stuff in the buffer, I take it out of there and put it into my own buffer until I encounter a '\n'. My own buffer signals that at that point that it "has a complete message". At that point, I do use the strstr function in string.h to find the "OK" or whatever other string I am searching for inside the string in my buffer. |
PrinceNai
Posted: Mon Apr 01, 2019 2:07 pm |
Inside RDA interrupt:
tmp=getc(); // get received char and thus also clear interrupt flag
// Process reception through state machine
//Possible data from GSM module that will be handled is:
// OK + CR +LF
switch (gsm_state) {
//get initial character 'O'
case 0:{
else if(tmp == 'o' || tmp == 'O'){ //we have "O", could be "OK"
gsm_state = 3; //expecting 'K'
else {
gsm_state = 0;
//********WE HAVE RECIEVED 'O' AS A FIRST CHARACTER***************************
case 3:{
if(tmp == 'K') //we have 'OK'
gsm_state = 31; //expecting CR + LF
gsm_state = 0;
case 31:{
if(tmp == 13) //we have OK + CR (binary 13)
gsm_state = 32; //expecting LF (binary 10)
gsm_state = 0;
case 32:{
if(tmp == 10){ //we have OK + CR +LF, OK response is complete
Got_OK = 1; // HERE YOU HAVE AN INDICATION THAT YOU GOT AN OK FROM THE MODULE
gsm_state = 0; //reset state machine
//we don't have anything good, ERROR
default:{
gsm_state = 0;
} // switch brace
You issue a command to GSM module and right after that you can call this function that waits for a response you want, in this case "OK"
// ********************* Wait_OK_Response *************************************
// uses Got_OK flag set in the receive routine
void Wait_OK_Response(){
Got_OK = 0;
OK_Response = 0; // init
int i = 0;
delay_cycles(1);
while (i < 80){ // two ways to exit this loop
i++; // either find "OK" in four seconds
if(Got_OK){
Got_OK = 0;
OK_Response = 1; // OK received
else{
delay_ms(50); // or timeout
if(i > 80){
OK_Response = 0; // OK not received in 4 seconds
PrinceNai
Posted: Mon Apr 01, 2019 2:13 pm |
| Delete the first else in case 0:, I cut this from a larger function that also parses other responses from GSM and didn't notice it. |
PrinceNai
Posted: Mon Apr 01, 2019 2:35 pm |
And drop this, it is wrong because i can only go up to 80 and is also redundant, since OK_Response is already preset to 0.
if(i > 80){
cvargcal
Posted: Mon Apr 01, 2019 4:06 pm |
Thank you so much, I work on your idea. |
