Driver kbd doesn't work [Solved]
michaeltolini
PostPosted: Sun Mar 31, 2019 10:19 am     Reply with quote
I have found the following driver on this forum but it doesn't work.
Does anybody have any idea where is the problem ?
Note, with the same keypad and the official kbd driver it works but i need 16 keys keypad.
//Keypad connection:
#define row0 PIN_B4
#define row1 PIN_B5
#define row2 PIN_B6
#define row3 PIN_B7
#define col0 PIN_B0
#define col1 PIN_B1
#define col2 PIN_B2
#define col3 PIN_B3
// Keypad layout:
char const KEYS[4][4] =
{{'1','2','3','A'},
 {'4','5','6','B'},
 {'7','8','9','C'},
 {'*','0','#','D'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
void kbd_init()
//set_tris_b(0xF0);
//output_b(0xF0);
port_b_pullups(true);
short int ALL_ROWS (void)
if(input (row0) & input (row1) & input (row2) & input (row3))
   return (0);
   return (1);
char kbd_getc()
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR)
   switch (col)
      case 0:
        output_low(col0);
        output_high(col1);
        output_high(col2);
        output_high(col3);
      case 1:
        output_high(col0);
        output_low(col1);
        output_high(col2);
        output_high(col3);
      case 2:
        output_high(col0);
        output_high(col1);
        output_low(col2);
        output_high(col3);
      case 3:
        output_high(col0);
        output_high(col1);
        output_high(col2);
        output_low(col3);
   if(kbd_down)
      if(!ALL_ROWS())
         kbd_down=false;
         kchar=last_key;
         last_key='\0';
      if(ALL_ROWS())
         if(!input (row0))
            row=0;
         else if(!input (row1))
            row=1;
         else if(!input (row2))
            row=2;
         else if(!input (row3))
            row=3;
         last_key =KEYS[row][col];
         kbd_down = true;
         ++col;
         if(col==4)
            col=0;
   kbd_call_count=0;
return(kchar);
PostPosted: Sun Mar 31, 2019 10:29 am     Reply with quote
Post a test program that uses this keypad driver.
Post the full test program, with:
#include for the PIC
#fuses
#use delay
#include for the keypad driver
main()
etc.
michaeltolini
PostPosted: Sun Mar 31, 2019 12:42 pm     Reply with quote
#include <16F887.h>
#FUSES NOPUT                    //No Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES BORV40                   //Brownout reset at 4.0V
#use delay(internal=8000000)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1)
#ZERO_RAM
#include <flex_full_lcd.c>
#include <kbd_16_keys.c>
char k;
///////////////////////////////MAIN MENU///////////////////////////////////////
   kbd_init();
   port_b_pullups(1);
   lcd_putc("\f TOOL LIFETIME");
   lcd_putc("\n<#=ENTER *=SKIP>");
   while(true)
      k=kbd_getc();
      if(k!=0)
        if(k=='*')
          lcd_putc("\f ");
        lcd_putc(k);
michaeltolini
PostPosted: Sun Mar 31, 2019 12:44 pm     Reply with quote
Thanks for noticing me Smile
PostPosted: Sun Mar 31, 2019 12:46 pm     Reply with quote
and one critical thing. What processor.
The line that leaps out as possibly giving problems, is:
Some chips require every pullup bit set separately, so would need
port_b_pullups(0b11110000;
rather than the simple 'true' value. This would stop the keypad from working.
PostPosted: Sun Mar 31, 2019 2:48 pm     Reply with quote
hmm..you got me confused... are you saying..
1) the CCS supplied driver works fine with a 12 key kpd.
2) the 'found' driver works fine with a 12 key kpd.
3) the 'found' driver does NOT work with 16 key kpd?
if #3, it might be wiring...
Jay
michaeltolini
PostPosted: Sun Mar 31, 2019 3:51 pm     Reply with quote
I mean the keypad works with kbc.c but doesn't with the driver i found here
PostPosted: Sun Mar 31, 2019 4:30 pm     Reply with quote
The easy way would be to take the working kbd.c that CCS supplies, copy it, then using the CCS version, modify the copy to accept the 4th column. From a hardware aspect you're only adding one I/O line and maybe a resistor. Software is just the additional 4th column code.
If I had a 4x4 kpd, I'd do it but I only have 4x3 kpds here...
Jay
PostPosted: Sun Mar 31, 2019 5:23 pm     Reply with quote
Did you modify the following line, like Ttelmah said:
Change this line in your program from this:
port_b_pullups(1);
To this:
port_b_pullups(0xF0);
PostPosted: Mon Apr 01, 2019 8:05 am     Reply with quote
curious.. I looked at the datasheet and that PIC has INDIVIDUAL pullups, so 'TRUE' will not work, you need to Mr. T's 0xF0 format.
Jay
michaeltolini
PostPosted: Mon Apr 01, 2019 3:27 pm     Reply with quote
Finally i modified the original kbd.c and added the 4th column
Thanks for your help Smile
PostPosted: Tue Apr 02, 2019 4:56 am     Reply with quote
I hope you really modified a COPY and not the original code... Smile
There's nothing worse than taking good, working code...making 'one little' change' and then having to spend an entire weekend trying to get back to the original..... Sad
Yeah , BTDT.....
I even make copies of copies now.....
Every project has it's own folder, copy of the device header and my library files,like kbd, LCD,etc. There can be 50-60-100 versions to the program, ALL are in the folder. HDs have LOTS of space and I have little time.
Jay
