32-bit integer division inside and outside an interrupt
Michael Thompson
PostPosted: Tue Mar 11, 2003 5:51 pm     Reply with quote
How does one perform 32-bit integer division inside and outside of an interrupt since they use the same internal compiler divide function?
Is there 32-bit compiler division code available to make a duplicate function for use within an interrupt?
Regards,
Mike
___________________________
Original Post ID: 12550
Re: 32-bit integer division inside and outside an interrupt
PostPosted: Tue Mar 11, 2003 6:41 pm     Reply with quote
<font face="Courier New" size=-1>:=How does one perform 32-bit integer division inside and outside of an interrupt since they use the same internal compiler divide function?
:=Is there 32-bit compiler division code available to make a duplicate function for use within an interrupt?
To answer the 2nd question, here's a code generator
that will create ASM code for 32-bit division.
But, it requires that the divisor be a constant.
For example, suppose you want to make code to divide by 5.
You would set it for 32 bits, and to multiply by .2 (same
thing as divide by 5). Also, if you reduce the "maximum error"
to 0.1\% (for example), it will increase the size of the
generated code.
<a href="http://www.piclist.com/cgi-bin/constdivmul.exe" TARGET="_blank">http://www.piclist.com/cgi-bin/constdivmul.exe</a>
--</font>
Original Post ID: 12552
Al
PostPosted: Fri Jan 30, 2004 10:03 am     Reply with quote
The following code handles 32-bit integer division both inside and outside of the interrupt. Try it yourself. If this does not solve your problem, post a snippet of your code so that I can see exactly what you are doing.
#include <16f877A.h>
#fuses HS,NOLVP,NOWDT,PUT
#use delay (clock=20000000)
#use rs232(baud=4800, parity=N, bits=8, xmit=PIN_C6, rcv=PIN_C7)
char status;
char ch;
int32 a,b;
float k,l;
// This ISR is called every time a character arrives on the RS232 buffer
#int_rda
void serial_isr() {
disable_interrupts(GLOBAL);
ch=getc();
//32-bit integer division inside interrupt
k = a/b;
putc(ch);
delay_ms(200);
void main() {
BYTE start;
a = 10;
b = 5;
k = 0; l = 0;
//32-bit integer division outside interrupt
l = a/b;
ch = (char)(65);
ch = 'N';
enable_interrupts(INT_RDA);
do {
if(ch=='c')
printf("\r\n inside interrupt = %f\r\n
outside interrupt = %f\r\n", k, l);
} while (TRUE);
Alan Murray
