Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Basic co-operative scheduler - v: 1.0.4
Post new topic   Reply to topic    CCS Forum Index -> Code Library
PICoHolic
PostPosted: Fri Mar 22, 2019 11:01 am     Reply with quote
This is a basic scheduler (not yet an RTOS).
Features:
- Runtime task creation
- Runtime task deletion
- Runtime task suspending/resuming
- Runtime task's execution rate change
- Task's messaging capability
- Scheduler and task statistics
- Semaphore
Cheers!
Filename: target_port.h
#ifndef _TARGET_PORT_H_
#define _TARGET_PORT_H_
//Specify target compiler
#if (defined (__PCH__) || defined (__PCD__))   //CCS C compiler?
   //types:
   typedef    int1         bool;
   typedef      unsigned int8   uint8;
   typedef      signed int8      sint8;
   typedef    unsigned int16   uint16;
   typedef    signed int16   sint16;
   typedef      unsigned int32   uint32;
   typedef      signed int32   sint32;
   //misc
   //#define   _USE_32_BIT_
   #include <stdlibm.h>
#elif defined (__NIOS2__)   //Nios2
   //types:
   #include "alt_types.h"
   typedef    alt_u8     bool;
   typedef      alt_u8     uint8;
   typedef      alt_8        sint8;
   typedef    alt_u16      uint16;
   typedef    alt_16     sint16;
   typedef      alt_u32      uint32;
   typedef      alt_32     sint32;
   //#define   rom   ?
   //misc
   //#define make8(Val, B)   (uint8)...   //extract byte B from Val
   //#define make16(H, L)   (uint16)...   //combine two bytes in 1 word
   #include <string.h>
   #include <malloc.h>
   #include <sys/alt_alarm.h>
#elif defined (__ATOLLIC__)   //special ID that represents the compiler
   //types:
   typedef    ?     bool;
   typedef      ?     uint8;
   typedef      ?     sint8;
   typedef    ?   uint16;
   typedef    ?     sint16;
   typedef      ?   uint32;
   typedef      ?     sint32;
   #define   rom   ?
   //misc
Filename: scheduler.h
#ifndef   _SCHEDULER_H_
#define   _SCHEDULER_H_
#include "target_port.h"
//Comment if no LED is available
//#define   _BUSY_LED_
#ifdef _BUSY_LED_
#define   BLEDON()   LED3On()
#define   BLEDOFF()   LED3Off()
typedef struct _stask
   uint16 sTaskID;             //sTask ID
   uint8 Active;               //sTask status
#ifdef _USE_32_BIT_
   uint32 sTicks;              //sTask periodic ticks
   uint32 nTicks;              //sTask current tick count
   uint32 eTicks;            //Elapsed ticks
#else
   uint16 sTicks;              //sTask periodic ticks
   uint16 nTicks;              //sTask current tick count
   uint16 eTicks;            //Elapsed ticks
   uint16 MsgBytesCount;       //sTask message size in bytes
   void *MsgData;              //sTask data message
   void *sTaskPtr;             //sTask function's pointer
   struct _stask *Next;        //Pointer to next sTask
   struct _stask *Previous;    //Pointer to previous sTask
}sTask;
typedef void (*_fptr)(sTask *);
typedef struct _schedulerinfo
   sTask *sTaskHead;           //sTasks linked list's head
   sTask *sTaskTail;           //sTasks linked list's tail
   uint16 sTasksCount;       //sTasks total count
}SchedulerInfo;
typedef struct _schedulerstats
   uint16 sTasksCount;         //Total number of tasks
   uint8 sTasksCPUUsage;      //CPU usage
}SchedulerStats;
typedef struct _ssemaphore
   uint8 Sem;               //Semaphore variable
   uint8 sTasksCount;         //Nb of concurrent tasks using this semaphore
   //type   //TBD
}sSemaphore;
 * Function to create a scheduled task
 * @author m_richa (03/21/19)
 * @param Active sTask initial state
 * @param sTicks Periodic ticks
 * @param sTaskPtr Pointer to task's function
 * @return 0: fail, sTaskID: success
#ifdef _USE_32_BIT_
uint16 sTaskCreate(uint8 Active, uint32 sTicks, _fptr sTaskPtr);
#else
uint16 sTaskCreate(uint8 Active, uint16 sTicks, _fptr sTaskPtr);
 * Function to locate and return sTask's entry pointer
 * @author m_richa (03/22/19)
 * @param sTaskPtr sTask's function name
 * @return Pointer to sTask entry
//sTask *sTaskLocate(_fptr sTaskPtr);
 * Function to suspend a given sTask
 * @param sT sTask's entry pointer
void sTaskSuspend_me(sTask *sT);
uint8 sTaskSuspend(_fptr sTaskPtr);
 * Function to resume a given sTask
void sTaskResume_me(sTask *sT);
uint8 sTaskResume(_fptr sTaskPtr);
 * Function to get number of periodic ticks of a given sTask
 * @return Number of ticks
#ifdef _USE_32_BIT_
uint32 sTaskGetPeriodicTicks(sTask *sT);
#else
uint16 sTaskGetPeriodicTicks(sTask *sT);
 * Function to set number of periodic ticks of a given sTask
 * @param sTicks Number of ticks
 * @param Run 0: Reset sTask's nTick count 1: Run sTask on next tick
#ifdef _USE_32_BIT_
void sTaskSetPeriodicTicks(sTask *sT, uint32 sTicks, uint8 Run);
#else
void sTaskSetPeriodicTicks(sTask *sT, uint16 sTicks, uint8 Run);
 * Function to send data bytes to a given sTask
 * @param MsgBytes Data pointer to be sent
 * @param BytesCount Data size
uint8 sTaskWriteMsgBytes(_fptr sTaskPtr, void *MsgBytes, uint16 BytesCount);
 * Function to get sTask's message size if any
 * @return Read data size. 0: no data available
uint16 sTaskGetMsgBytesCount(sTask *sT);
 * Function to read data bytes of a given sTask
 * @param MsgBytes Data pointer to be received
uint16 sTaskReadMsgBytes(sTask *sT, void *MsgBytes);
 * Function to delete a given sTask
void sTaskDelete_me(sTask *sT);
uint8 sTaskDelete(_fptr sTaskPtr);
 * Function to initialize scheduler and create idle sTask
 * @author m_richa (04/07/19)
 * @return uint16
uint16 InitScheduler(void);
 * Function to get scheduler statistics
 * @author m_richa (04/10/19)
 * @param SS Pointer to statistics structure
void GetSchedulerStats(SchedulerStats *SS);
 * Function to initialize semaphore
 * @author m_richa (04/15/19)
 * @param sema Pointer to semaphore structure
 * @param csTasks Number of allowed concurrent tasks
void InitSemaphore(sSemaphore *sema, uint8 csTasks);
 * Function to release and make semaphore available
void SemaphoreRelease(sSemaphore *sema);
 * Function to hold semaphore
 * @return 0: fail  1: success
bool SemaphoreHold(sSemaphore *sema);
 * Function to check if a semaphore is available
 * @return 0: not available  1: available
bool SemaphoreAvailable(sSemaphore *sema);
 * Function to dispatch sTasks sequentially
 * @author m_richa (03/25/19)
void Scheduler(void);
Filename: scheduler.c
 * Filename:            scheduler.c
 * Description:         Contains co-operative scheduler API
 * Target Processor:    PIC
 * Target Compiler:     CCS PIC C Compiler, Nios2
 * Compiler Revision:   5.084, 15.1
 * Revision History:
 * Author           Date (mm/dd/yy)         Comment
 * m_richa          03/22/19                Alpha release
 *                                          (CCS 5.083)
 * m_richa          03/24/19                Beta
 *                                          sTask parameter changed as
 *                                          per jeremiah's suggestion
 *                                          (CCS 5.083)
 * m_richa          03/25/19                1.0.0
 *                                          Jerson's comment taken into
 *                                          consideration, implemented
 *                                          differently
 *                                          (CCS 5.083)
 * m_richa          03/28/19                1.0.1
 *                                          Functions modified:
 *                                          - sTaskCreate(..)
 *                                          - sTaskResume(..)
 *                                          - sTaskSetPeriodicTicks(..)
 *                                          - Scheduler()
 *                                          Optimized scheduling procedure
 *                                          Better timing management
 *                                          (CCS 5.083)
 * m_richa          04/04/19                1.0.2
 *                                          Added support to NIOS2 (15.1)
 * m_richa          04/10/19                1.0.3
 *                                          InitScheduler function added
 *                                          _sTask_idle sTask added to
 *                                          GetSchedulerStats function
 *                                          Busy LED option added
 *                                          (5.084)
 * m_richa          04/15/19                1.0.4
 *                                          eTicks added to sTask node to
 *                                          count elapsed ticks
 *                                          Semaphore handling added
 *                                          (5.084)
#include "scheduler.h"
#define  TICKSPERSECOND   1000    //change accordingly
SchedulerInfo _SI;
uint8 _cpu_usage_p = 0;
bool _sysTick;
#ifdef _USE_32_BIT_
uint32 _sysTickCounter = 0; //tick counter
#else
uint16 _sysTickCounter = 0; //tick counter
//Timing for _sysTick = 1ms
#define  TMR1Reload      1500      //change accordingly
 * ISR for TIMER1 in order to generate a 1ms _sysTick
#int_TIMER1   HIGH   //high priority interrupt
void TIMER1_isr(void)
    set_timer1(get_timer1() - TMR1Reload);
    _sysTickCounter++;
    _sysTick = TRUE;
#define GetSystemTicks()    _sysTickCounter
#define GetSystemTicks()   alt_nticks()
#ifdef _USE_32_BIT_
#else
    static uint16 sTaskID = 0;    //task ID
    sTask *New_sTask = malloc(sizeof(sTask));
    if (New_sTask != NULL)
        //Assign values:
        New_sTask->sTaskID = ++sTaskID;
        New_sTask->Active = Active;
        New_sTask->sTicks = sTicks;
        New_sTask->nTicks = GetSystemTicks();
        New_sTask->MsgBytesCount = 0;
        New_sTask->MsgData = NULL;
        New_sTask->sTaskPtr = sTaskPtr;
        New_sTask->Next = NULL;
        New_sTask->Previous = NULL;
        _SI.sTasksCount++;  //Increment count
        if (_SI.sTaskHead != NULL)   //nth sTask?
            New_sTask->Previous = _SI.sTaskTail;
            _SI.sTaskTail->Next = New_sTask;
            _SI.sTaskTail = New_sTask;  //Point tail
        } else    //1st sTask?
            _SI.sTaskHead = New_sTask;  //Point head
        return sTaskID;   //Success
    return 0;   //Fail, no available RAM
sTask* sTaskLocate(_fptr sTaskPtr)
    sTask *p = _SI.sTaskHead;
    if (_SI.sTasksCount == 0) return NULL;
    while (p != NULL)
        if (p->sTaskPtr == sTaskPtr) return p;
        else p = p->Next;
    return NULL;
    sT->Active = 0; //disable
    sTask *p = sTaskLocate(sTaskPtr);
    if (p != NULL)
        sTaskSuspend_me(p);    //suspend sTask
        return 1;   //success
    return 0;   //Fail
    sT->Active = 1; //enable
    sT->nTicks = GetSystemTicks() - sT->sTicks;  //load ticks
    if (p != NULL)
        sTaskResume_me(p); //resume sTask
        return 1;   //success
    return 0;   //Fail
#ifdef _USE_32_BIT_
#else
    return sT->sTicks;
#ifdef _USE_32_BIT_
#else
    sT->sTicks = sTicks;
    if (Run)    //should run on next tick?
        sT->nTicks = GetSystemTicks() - sTicks;  //load ticks
    else sT->nTicks = GetSystemTicks();   //load ticks
    if (p != NULL)
        if (p->MsgBytesCount == 0)  //no pending msgs?
            p->MsgBytesCount = BytesCount;
            p->MsgData = malloc(BytesCount);
            if (p->MsgData != NULL)
                memcpy(p->MsgData, MsgBytes, BytesCount);
                return 1;   //success
            return 0;   //Fail
        return 0;   //Fail
    return 0;   //Fail
    return sT->MsgBytesCount;
    uint16 BytesCount = sT->MsgBytesCount;
    if (BytesCount > 0)  //data available?
        //Copy and free:
        memcpy(MsgBytes, sT->MsgData, sT->MsgBytesCount);
        free(sT->MsgData);
        sT->MsgData = NULL;
        sT->MsgBytesCount = 0;  //reset
    return BytesCount;
    if (sT == _SI.sTaskHead) //on head?
        if (_SI.sTasksCount == 1)   //Head = Tail?
            //Reset all:
            _SI.sTaskHead = NULL;
            _SI.sTaskTail = NULL;
        } else
            _SI.sTaskHead = _SI.sTaskHead->Next;
            _SI.sTaskHead->Previous = NULL;
    } else if (sT == _SI.sTaskTail)    //on tail?
        _SI.sTaskTail = _SI.sTaskTail->Previous;
        _SI.sTaskTail->Next = NULL;
    } else    //somewhere in the middle
        sT->Previous->Next = sT->Next;
        sT->Next->Previous = sT->Previous;
    if (sT->MsgBytesCount)
        free(sT->MsgData);  //Free msg data if any
    free(sT);           //Free sTask
    _SI.sTasksCount--;  //decrement sTasks count
    if (p != NULL)
        sTaskDelete_me(p); //delete sTask entry
        return 1;   //Success
    return 0;   //Fail
 * The idle sTask, used to calculate CPU usage
 * @param me
void _sTask_idle(sTask *me)
#ifdef _USE_32_BIT_
    static uint32 initTicks = 0, idleTicks = 0;
#else
    static uint16 initTicks = 0, idleTicks = 0;
    if ((GetSystemTicks() - initTicks) >= TICKSPERSECOND)   //1 s elapsed?
        //Calculate CPU usage:
        _cpu_usage_p = (uint8)(100 - (((float)idleTicks / (float)TICKSPERSECOND) * 100.0));
        // Other alternative: Add eTicks of all sTaks and divide by TICKSPERSECOND
        initTicks = GetSystemTicks();   //reload
        idleTicks = 0;  //reset idle ticks
    } else idleTicks++;
 * @return uint16
    _SI.sTasksCount = 0;
    return sTaskCreate(1, 1, _sTask_idle); //create idle sTask
    SS->sTasksCount = _SI.sTasksCount;
    SS->sTasksCPUUsage =  _cpu_usage_p;
#if 0
    sTask *CsTask = _SI.sTaskHead;
    _fptr f;
    while (CsTask)
        if (CsTask->Active)  //is it active?
            if (CsTask->sTaskPtr != NULL)    //task's function exists?
                if (++(CsTask->nTicks) == CsTask->sTicks)    //should run?
                    CsTask->nTicks = 0;     //reset ticks
                    f = CsTask->sTaskPtr;   //cast it to _fptr
                    f(CsTask);              //run task
        CsTask = CsTask->Next;
    sema->Sem = csTasks;
    sema->sTasksCount = csTasks;
    if (sema->Sem < sema->sTasksCount)
        sema->Sem++; //increment
    if (sema->Sem)
        sema->Sem--; //decrement
        return 1;
    return 0;   //fail
    return (sema->Sem)?1:0;
    _fptr f;
#ifdef _USE_32_BIT_
    uint32 CsysTickCounter;
    uint32 TicksDiff;
#else
    uint16 CsysTickCounter;
    uint16 TicksDiff;
    while (CsTask)
                CsysTickCounter = GetSystemTicks();  //ticksounter snapshot just to
                                                     //make sure value does not change
                                                     //during this process
                TicksDiff = CsysTickCounter - CsTask->nTicks;   //get diff
                if (TicksDiff >= CsTask->sTicks)    //should run?
                    CsTask->nTicks = CsysTickCounter;   //reload
#ifdef _BUSY_LED_
                    BLEDON();
                    //prepare call:
                    CsTask->eTicks = CsysTickCounter;   //Save snapshot
                    CsTask->eTicks = GetSystemTicks() - CsTask->eTicks; //calculate elapsed ticks
#ifdef _BUSY_LED_
                    BLEDOFF();
Usage example:
int1 _sysTick;
void sTask1(sTask *);
void sTask2(sTask *);
void sTask3(sTask *);
void sTask1(sTask *me)
    unsigned int16 MsgSize;
    unsigned int8 *MyMsg;
    //TODO: user code
    //sTask body
    //Check for pending message:
    MsgSize = sTaskGetMsgBytesCount(me); //Msg size
    if (MsgSize)    //Msg pending?
        MyMsg = malloc(MsgSize);        //allocate RAM
        sTaskReadMsgBytes(me, MyMsg);   //Read msg
        //TODO with incoming msg:
        free(MyMsg);    //deallocate RAM
void sTask2(sTask *me)
    unsigned int8 sTaskMsg[4] = {1, 2, 3, 4};   //some data to send
    //TODO: user code
    //sTask body
    //Send msg ex:
    sTaskWriteMsgBytes(sTask1, sTaskMsg, sizeof(sTaskMsg));    //send msg to sTask1
    //ex to delete myself
    sTaskDelete_me(me);    //this will remove the current sTask
void sTask3(sTask *me)
    SchedulerStats Stats;
    //TODO: user code
    //sTask body
    //ex to suspend sTask2:
    sTaskSuspend(sTask2);
    //ex to suspend myself:
    sTaskSuspend_me(me);
    //ex to change my execution rate and execute on next sysTick:
    sTaskSetPeriodicTicks(me, 500, 1);
    //ex to resume myself:
    sTaskResume_me(me);
    //Get statistics
    GetSchedulerStats(&Stats);
void _main(void)
    //TODO: some user code goes here
    InitScheduler();    //Initialize scheduler
    sTaskCreate(1, 10, sTask1);      //Fastest sTask, every 10 sysTicks
    sTaskCreate(1, 100, sTask2);    //sTask2 runs every 100 sysTicks
    sTaskCreate(1, 1000, sTask3);   //Slowest sTask3, runs every 1000 sysTicks
    //Add more tasks....
    while (TRUE)
        if (_sysTick)       //sysTick is a periodic flag (could be generated by a timer)
                            //a typical value of a periodic tick is 1ms
                            //Note: one should make sure periodic sysTick is slow enough
                            //      to handle the worst case delay of the fastest sTask
                            //      especially when the fastest sTask is set to 1 sysTick
            _sysTick = 0;   //reset flag
            Scheduler();    //call scheduler
jeremiah
PostPosted: Sat Mar 23, 2019 6:34 am     Reply with quote
This looks pretty neat. I'll have to try it out sometime!. Curiousity: Why the indirection of the _fptr's function parameter to void *? It seems like all your uses of it cast it to sTask * anyways.
PICoHolic
PostPosted: Sat Mar 23, 2019 3:27 pm     Reply with quote
Well, surprisingly, the compiler did not allow me to use sTask *. So I had to put void * instead and then cast it Confused
jeremiah
PostPosted: Sun Mar 24, 2019 11:02 am     Reply with quote
I thought there was a way to forward declare, but it might be ansi C only. I'd have to mess with it to be sure. If I can make a suggestion then:
Assuming the idea is for the user to supply the function, you might consider changing the sTask structure to internally use void * for sTaskPtr:
   unsigned int16 sTaskID;         //sTask ID
   unsigned int8 Active;           //sTask status
   unsigned int16 sTicks;          //sTask periodic ticks
   unsigned int16 nTicks;          //sTask current tick count
   unsigned int16 MsgBytesCount;   //sTask message size in bytes
}sTask;
Then you can move the typedef for _fptr below the struct and add
the task pointer:
After that, you should only have to change one part of the Scheduler() function:
    _fptr f;
    while (CsTask)
or you can play with just casting it to _fptr when you call it.
The reason I suggest this is that it (in the general case) takes out the need for the user to handle casting to the right type or the me variable in your task examples. You'd want to test it out of course.
PICoHolic
PostPosted: Sun Mar 24, 2019 1:23 pm     Reply with quote
You have a point, will have to try it
Jerson
PostPosted: Sun Mar 24, 2019 10:21 pm     Reply with quote
Please permit me to make a critical observation on your code.
The round-robin co-operative scheduler that you've implemented makes an assumption that the tasks will always run to completion faster than the SysTick. If this is not the case, the tasks will run behind time and be grossly inaccurate
I would re-write this part
like this
 if (gloSysTick - CsTask->nTicks >= TaskPeriod )    //should run?
                    CsTask->nTicks = gloSysTick+TaskPeriod;     //reset ticks to new match value
where gloSysTick is a global variable that just increments every mS in the background and TaskPeriod is the rate at which you want the task to run.
Regards
Jerson Fernandes
PICoHolic
PostPosted: Mon Mar 25, 2019 1:13 am     Reply with quote
Thank you.
Yes I know, actually I have added a comment about that.
It's just the initial release, I was planning to adjust it sometime later on.
PICoHolic
PostPosted: Thu Mar 28, 2019 1:55 pm     Reply with quote
Updated to v: 1.0.1
Jerson
PostPosted: Thu Mar 28, 2019 10:19 pm     Reply with quote
Now that you've got the scheduler working off the systick counter, the _sysTick variable seems redundant. You could let the main run scheduler at natural speed dependent on the task times like this
    while (TRUE)
The individual tasks will continue to run at the specified interval.
One caveat that should be mentioned is that all tasks should run-to-completion. Also, no delay_ms type blocking functions should be used within a task to maintain co-operative task sanity.
Regards
Jerson Fernandes
PICoHolic
PostPosted: Wed Apr 17, 2019 12:37 am     Reply with quote
Updated to v: 1.0.4
Note: not all features have been thoroughly tested.
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
