16f1823 adc constant value
sebalitter
PostPosted: Mon Mar 18, 2019 4:22 pm     Reply with quote
Hi There!
I'm using 16F1823 with flex_lcd420. PICKIT4 , CCS v5.081 , MPLAB X 5.15 , win 7
Don't know what wrong in my project.
The ADC is always showing 130 in the lcd despite of the potentiometer regulation in PIN A4 (AN3)
some advice?
Thank you
#include <16F1823.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                     //Master Clear pin enabled
#use delay(clock=1M)                    // Configuracion reloj interno
#include <flex_lcd420.c>
int8 segundos=0;
void mostrar_lcd(void){
   lcd_putc("\f");  // borramos la palabra para entrar a otra instruccion
   delay_us(10);  // (0-1023)
   int16 value = read_adc();
   // entree=0-1023;
   //lcd_gotoxy (1,1);
   //Orden -> columna , fila
   //printf(lcd_putc, " VOLTAJE "); // manifestamos la palabra en nuestro lcd
   lcd_gotoxy (1,2); //Ubicamos la palabra en la segunda fila y la primera columna
  printf(lcd_putc, "ADC Value %ld ",value);
  lcd_gotoxy (1,3);
  printf(lcd_putc, "RELOJ  %02u", segundos );
#INT_TIMER1
void oscilacion(void)
   segundos++;
   mostrar_lcd();
   set_timer1(0x85EE);
void ini_pic(void)
    set_tris_c(0b000000);      // Configuramos salidas y entradas
    set_tris_a(0b111111);
    lcd_init();
    //CONFIG ADC
   setup_vref(VREF_ON|VREF_ADC_4v096);
   setup_adc_ports(sAN3|VSS_VDD); // ADC entre Vdd et Vss
   //CONFIG TIMER
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); // Configuración timer1
   setup_oscillator(OSC_1MHZ);
   enable_interrupts(GLOBAL);   // habilitar interrupciones
   enable_interrupts(INT_TIMER1);   // habilitar interrupcion timer 1
   //1 s = 4/1000000Hz * 8 * (2^16 - TMR1) -> TMR1 = 34286 ( 0x85EE )
   set_timer1(0x85EE);   // tiempo desborde 1seg
   ini_pic();
PostPosted: Mon Mar 18, 2019 4:37 pm     Reply with quote
You need to select the adc channel before you read it. Example:
set_adc_channel(3);
delay_us(5);  // 16F1823 data sheet says Tacq = 4.42 usec
Put this at the end of your Config ADC section.
Also the 16F1823 datasheet recommends that you use
setup_adc(ADC_CLOCK_DIV_2);
with a 1 MHz oscillator, instead of what you have in your code:
sebalitter
float in lcd
PostPosted: Wed Mar 20, 2019 9:01 pm     Reply with quote
Thank you PCM programmer .
one more please...
the compiler is throwing error to compile this...
3_phase_Volt.X\3_phase_Volt.c:132:2: Error#71 Out of ROM, A segment or the program is too large oscilacion
some problem to show float numbers
char value_string[5] = "";
float value_adc = 5.54f;
    sprintf(value_string, "%5.2f", value_adc);
    lcd_gotoxy (1,1);
    printf(lcd_putc, "%s   ",value_string);
 lcd_gotoxy (1,2);
    printf(lcd_putc, "%f   ",value_adc);
thank you
Re: float in lcd
PostPosted: Thu Mar 21, 2019 4:18 am     Reply with quote
sebalitter wrote:
The compiler is throwing error to compile this...
Some problem to show float numbers.
The 16F1823 has only one 2K segment for program memory. So your
program compiles to more than 2K. It won't fit in your PIC. You have
to cut part of it, or get a larger PIC. I suggest get rid of the floating point.
I made a test program:
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT
#use delay(clock=4M)
float a, b, c;
a = b * c;
a = b / c;
a = b + c;
a = b - c;
while(TRUE);
This program compiles to 763 words (out of 2048 total for the PIC).
If I comment out the five floating point lines above, it compiles to 16 words.
So floating point can easily take up 1/3 of your PIC. Try to find a way
to avoid using it.
PostPosted: Thu Mar 21, 2019 6:46 am     Reply with quote
He should look at scaled int32's using %5.2lw instead. Depends on what
arithmetic he is actually doing (which isn't shown), but likely he can save
a lot of time, and significant space.
sebalitter
PostPosted: Sat Mar 30, 2019 10:10 am     Reply with quote
I'm displaying read_adc() values from AC voltmeter, which should be between 0 - 1023, but never goes beyond 227. You know why ?
At the oscilloscope i see values from 1 to 4 volts (after resistor divider).
#define SAMPLES 1000
void main (void)
   int16 i;
   int16 adc1, acum=0, valorMax=0;
   lcd_init();
   setup_adc_ports(sAN2|VSS_FVR);
   setup_vref(VREF_ADC_4v096);
   while(TRUE){
      for(i=0;i<SAMPLES;i++){
         set_adc_channel(2);
         delay_us(10);
         adc1=read_adc();
         acum=adc1;
         if(acum>valorMax)
           valorMax=acum;
      lcd_gotoxy(1,1);
      printf(lcd_putc,"\fVr: %.2f V ",valorMax*0.707);
      lcd_gotoxy(1,2);
      printf(lcd_putc,"%lu",adc1);
      valorMax=0;
      acum=0;
PostPosted: Sat Mar 30, 2019 12:18 pm     Reply with quote
Loook at read_adc() in the CCS manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
They have a nice little color chart. If you have a PIC
with a 10-bit ADC and you want read_adc() to give you
the full 0 to 3FF output, what #device ADC=?? line should
you place after your #include statement ?
#device ADC=??
PostPosted: Sat Mar 30, 2019 1:20 pm     Reply with quote
Also as a long term comment, ADC_CLOCK_INTERNAL is not recommended
for operation above 1MHz, unless you sleep the processor during the
conversion. The data sheet will list the recommended clock divisor
to use from the Fosc. Use this.
Then your max 0.707, will drink ROM.
Instead use integer. Multiplying a maximum value of 1023, by 0.707
gives 723.26. Now with just 10bits, only four digits here actually contain
real data. So displaying with two decimals is pointless.
So to give the equivalent using integer, and one decimal, use:
    int32 temp;
    temp=valorflex*905;
    temp/=128;
    printf(lcd_putc,"\fVr: %.1lw V ",temp);
This will give you 723.2 displayed for 1023, and be smaller and
faster.
905/128 = 7.07, giving you an integer value 10* the float result,
which *w displays as a decimal value.
