Guest Guest
| Wierd port C behavior |
Posted: Fri Jan 30, 2004 4:08 am |
Something funny is happening with my portc on a 16f876.
Using output_c(0xff) all the pins go high.
When I use output_high(PIN_C0) C0 goes high as expected.
When I use output_high(PIN_C0) followed by output_high(C1) only c1 goes high.
Any ideas? Nothing else exists in the program, just those lines mentioned above in main. I tried turning off ccp1, ccp2, and timer1 but result is the same. |
Posted: Fri Jan 30, 2004 4:35 am |
Hello
I had this problem on a PIC12F675. I disabled the comparator module completely, and everything worked fine. I don't remember if the 876 has comparators. I it hasn't, there is maybe another hardware module at this pin.
mfg
Felix |
Guest Guest
Posted: Fri Jan 30, 2004 4:42 am |
Felix,
Good guess but that isn't the problem. The analog stuff on a 876 is on portA. The only thing on c0 and c1 is timer1 and ccp2 respectively, of which I have already tried manually disabling.
I have a feeling port c may need some special sort of initalizing when not using the TRIS command. I did some quick and dirty assembly as suggested by someone..
processor 16f876
#include <p16f876.inc>
__config _HS_OSC & _WDT_OFF & _PWRTE_ON
movlw B'00000000'
tris PORTA
tris PORTB
tris PORTC
main:
bsf PORTC, 0
bsf PORTC, 1
bsf PORTC, 2
bsf PORTC, 3
bsf PORTC, 4
bsf PORTC, 5
bsf PORTC, 6
bsf PORTC, 7
goto main
END
And I was able to see c0 and c1 on simultaniously. |
| Re: Wierd port C behavior |
Posted: Fri Jan 30, 2004 5:49 am |
| Guest wrote: | Something funny is happening with my portc on a 16f876.
If your two lines are immediately after one another, this may be the 'read modify write' problem.
Basically, when you do a 'output_high(bit)' function, the chip reads the current pin values, and sets the requested bit. Now if you perform 'output_high(PIN_C1)', if there is a reasonable load, and especially significant capacitance on the pin, it may take a few uSec, to actually go 'high'. So if the very next instruction, is another bit 'output', the port is read, and at this point, pin_c1, is not yet high. So the bit is read as a '0', and gets output as a 0...
Hence:
output_high(PIN_C1);
delay_us(1);
output_high(PIN_C0);
with the delay dependant on the capacitance present on the pin, may be necessary to perform this operation.
There is significant documentation about this behaviour on the MicroChip site.
Posted: Fri Jan 30, 2004 5:41 pm |
I tested the following program with PCM vs. 3.184, and it
works OK. Both pins C0 and C1 are set high, as observed
with an oscilloscope.
#include "16F877.h"
#use delay(clock = 4000000)
main()
Posted: Fri Jan 30, 2004 6:58 pm |
Thanks for letting me know about the read-modify-write issue.
Although, I don't think timing was my issue as observed by the following code that didn't work:
Only C0 remained lit (I had small leds directly connected to each pin). I rememberd the mention of current draw in the microchip website, so I added limiting resistors in series with each led (even though I know the leds weren't drawing more then the rated current per pin), and the above code worked even without the delay (@20mhz).
So I guess drawing too much current (or too fast) from any port pin, even if the others are stable, will lead to issues. Well, you learn something new every day. |
Charlie U
Joined: 09 Sep 2003 Posts: 183 Location: Somewhere under water in the Great Lakes
| Predictable Port C Behavior |
Posted: Fri Jan 30, 2004 9:59 pm |
| Now that we know "the rest of the story" it is fairly easy to surmise that, indeed you _are_ seeing a "read-modify-write" problem. The "small" LEDs that you had on the port pins, without current limiting resistors, were limiting the output voltage to somewhere between 2 and 3 volts, because they are diodes. The inputs to port C are Schmitt triggers and require 0.8 x VDD to be high, which is 4 VDC in a 5 volt system. Therefor, even though you have set the outputs to a high state, the output drivers can not pull the outputs above the diode operating voltage of 3 volts max (estimated), which is below the input threshold of 4 volts, the pins will be read as a 0 during the read modify write action of the bit set, and driven back as a 0. |
