12f1822 delay_ms is wrong
Goto page Previous  1, 2
PostPosted: Fri Mar 01, 2019 12:17 pm     Reply with quote
good idea but...restore only goes back 1 day !!! unlike the XP version which I believe is/was daily. Thing is I've installed/upgraded stuff like antivirus and browser so you'd think Windoze would trigger on those 'events' and create 'restore points'.
oh well...
MPLAB seems to be OK, it's CCS that may be the fiddle here. Doing stuff inside MPLAB, like read/burn PICs is OK..no errors/crashes/viloations....
It'd be nice to just copy/paste the XP PICC into W7 seeing how I can't locate the flashdrive with CCS on it...or the old HD it 's on.
gremlins....
at least the XP system confirms I can program the 12f1822.
PostPosted: Fri Mar 01, 2019 1:24 pm     Reply with quote
As I have already said, try building with CCS without involving MPLAB.
PostPosted: Fri Mar 01, 2019 5:41 pm     Reply with quote
Finally some good news. I can program PICs again ! Well I can blink an LED on a 12F683. I 'think' W7 somehow trashed CCS compiler 'stuff', cause MPLAB was OKish...I totally removed one way or the other EVERY file that was CCS related (10,136 not that I counted...). Cleaned out the trash bin, registry had a lot of 'weird' stuff, cleaned up the HD somewhat, found the 'update.exe' on a 40G HD in the basement, installed and now it works. I have no idea what went wrong BUT right now I had to login here and THAT hasn't been necessary for years, maybe a couple gremlins are still lurking. At least I have copies of all recent program sources on 2HD and 2 FDs. So nearly 4 days lost......all cause I wanted to 'play' with a new 8 pin PIC !
I should've stayed with my 46K22 !
Thanks for the support.
Update: still no joy but I can program the 1822. PCM is 4.114, newest version I can find though I have 4-6 more HDs to look at. Using the internal 4MHz clock, clkout (pin3) IS 1us, which it should be, so PIC is running at correct speed. Scope shows 40us high, 40us low when it should be 500ms, 500ms. Changing delay value does change pulses. ALL output pins do the same. So..... I'm back where I was a week ago. I'll dump the listing and 'play computer' and count the 'delay_ms(500)' cycles. It looks like a simple loop in a loop + trim chunk of code. The 683 works fine BTW.
Yeesh I haven't does ASM since V2.534.....
Jay
PostPosted: Sat Mar 02, 2019 7:20 am     Reply with quote
0000:  MOVLP  00
0001:  GOTO   018
0002:  NOP
.................... //12F1822 version
.................... //12F683 version works 100%
.................... #include <12F1822.h>
.................... //////// Standard Header file for the PIC12F1822 device ////////////////
.................... #device PIC12F1822
.................... #list
.................... #fuses INTRC_IO,NOWDT,NOPUT,NOPROTECT,MCLR,put
.................... #fuses CLKOUT,NOLVP               //clkout is 1us
.................... #use delay(clock=4Mhz)                  //1us per instruction
0003:  MOVLW  06
0004:  MOVWF  04
0005:  MOVF   00,W
0006:  BTFSC  03.2
0007:  GOTO   016
0008:  MOVLW  01
0009:  MOVWF  21
000A:  CLRF   20
000B:  DECFSZ 20,F
000C:  GOTO   00B
000D:  DECFSZ 21,F
000E:  GOTO   00A
000F:  MOVLW  4A
0010:  MOVWF  20
0011:  DECFSZ 20,F
0012:  GOTO   011
0013:  GOTO   014
0014:  DECFSZ 00,F
0015:  GOTO   008
0016:  MOVLP  00
0017:  GOTO   032 (RETURN)
.................... // user define PIN I/O
.................... #define   led2      PIN_A2               //test LED
.................... //main program loop
.................... main() {
0018:  CLRF   04
0019:  MOVLW  1F
001A:  ANDWF  03,F
001B:  MOVLW  6C
001C:  MOVLB  01
001D:  MOVWF  19
001E:  MOVLB  03
001F:  CLRF   0C
0020:  MOVLB  02
0021:  CLRF   12
0022:  CLRF   11
....................    setup_comparator(NC_NC);            //no comparators
0023:  CLRF   12
0024:  CLRF   11
....................    setup_adc_ports(no_analogs);         //no analogs
0025:  MOVLB  01
0026:  BCF    1E.0
0027:  BCF    1E.1
0028:  MOVLW  00
0029:  MOVLB  03
002A:  MOVWF  0C
002B:  MOVWF  0E
....................    while(TRUE) {                     //forever loop
....................    delay_ms(500);                     // 1/2 second delay is really 40us !!!
002C:  MOVLW  02
002D:  MOVLB  00
002E:  MOVWF  25
002F:  MOVLW  FA
0030:  MOVWF  26
0031:  GOTO   003
0032:  DECFSZ 25,F
0033:  GOTO   02F
....................    output_toggle(led2);               //test led
0034:  MOVLB  01
0035:  BCF    0C.2
0036:  MOVLW  04
0037:  MOVLB  02
0038:  XORWF  0C,F
0039:  MOVLB  03
003A:  GOTO   02C
.................... } //end of new main
003B:  SLEEP
Configuration Fuses:
   Word  1: 37C4   INTRC_IO NOWDT PUT MCLR NOPROTECT NOCPD BROWNOUT CLKOUT IESO FCMEN
   Word  2: 1EFF   NOWRT PLL_SW STVREN BORV19 NODEBUG NOLVP
here's the listing..
goto 003 is where the PIC should kill 500ms but insted only 40us !
time to get paper and pencil out..
it'd be interesting to see someone else's listing to see if it's the same...
PostPosted: Sat Mar 02, 2019 7:46 am     Reply with quote
No, The goto 003, is only one main delay loop.
The code loads a count into register 25, and then loops back to goto 003
again if this is not zero.
Now looking at the code, what leaps out is that your main delay loop
is only using a 8 bit value.
Using my version of the same compiler, it gives:
0003:  MOVLW  20
0004:  MOVWF  05
0005:  MOVLW  06
0006:  MOVWF  04 //Note here two values loaded
0007:  MOVF   00,W
0008:  BTFSC  03.2
0009:  GOTO   018
000A:  MOVLW  01
000B:  MOVWF  21
000C:  CLRF   20
000D:  DECFSZ 20,F
000E:  GOTO   00D
000F:  DECFSZ 21,F
0010:  GOTO   00C
0011:  MOVLW  4A
0012:  MOVWF  20
0013:  DECFSZ 20,F
0014:  GOTO   013
0015:  GOTO   016
0016:  DECFSZ 00,F
0017:  GOTO   00A
0018:  MOVLP  00
0019:  GOTO   03E (RETURN)
Note your code only loads one byte not two.
4.114, was close to the point where the compiler first started
accepting 16bit values for the delay counts. The manual at this point
says:
Note: Previous compiler versions ignored the upper byte of an int16, now the upper byte affects the time.
Your code is behaving as if the compiler is not accepting the high
byte....
PostPosted: Sat Mar 02, 2019 8:10 am     Reply with quote
See this thread:
PIC12LF1822 and PIC16LF1823 clock problems -
http://www.ccsinfo.com/forum/viewtopic.php?t=44326
Basic answer: Don't use 9-year old compiler.
PostPosted: Sat Mar 02, 2019 8:44 am     Reply with quote
Well remembered/found PCM... Smile
PostPosted: Sat Mar 02, 2019 11:07 am     Reply with quote
Well I'm even more confused (if that's possible), as the same program for a 12F683 compiles and runs and the only difference in the '#use delay(..)' code
is MOVLW 26 for the 683, MOVLW 06 for the 1822. The rest of the 20 lines of code are identical so I assumed that is the problem as I couldn't see why the 'delay' routine would be different for different PICs even though the clocks are the same, and same delay values. Meanwhile I've confirmed my XP machine setup does the same ..even though I swear it was fine the other day...
sigh
PostPosted: Sun Mar 03, 2019 9:16 am     Reply with quote
Finally I'm back to where I was a week ago...
Located a newer version (never ever toss out old HDs !) and LED blinks
of course. Last night the PK3 died, bought another 1hr ago (part of the picdem pic18 explorer kit, rest I'll never use)... so I'm up and running.
note : PICkit3 is now 'obsolete'...sigh, now I'm really feeling old.
Jay
dluu13
PostPosted: Sun Mar 03, 2019 9:25 am     Reply with quote
Funny thing is that although PK3 is "obsolete", PK4 shows up with a yellow light in MPLABX, meaning that it's not fully tested.
Nevertheless, I've gotten myself a PK4 and it works with the micro I use so it's fine. The firmware of PK4 is also not fully developed yet. There's a button on there for programmer to go, but it's disabled for now and it'll get added with a future update of MPLAB.
Page 2 of 2
