cbarberis
Joined: 01 Oct 2003 Posts: 172 Location: Punta Gorda, Florida USA
| Question on using CCS FAT.C |
Posted: Mon Feb 11, 2019 3:59 pm |
I am trying for the first time to integrate the capability to allow me to log captured data onto an SD card. I already have the correct hardware interface on my board to support the SD card. I am using a dsPIC33EV256GM106, but the problem I am facing is that I have never used the FAT file lib support and the correct way to use it. I have FAT.c and MMCSD.c. I take it one works with the other where FAT.C handles file management and MMCSD.c handles the actual interface to the SD card.
My SPI is setup as follows to talk to the SD card:
spi(MASTER, SPI1, MODE=0,MSB_FIRST, BITS=8, baud=400000,stream=mmcsd_spi)
I believe that to write to the SD card I need to open a file and then append the data to it
So what I need to figure out is the usage the function below:
fatopen(char *name, char *mode, FILE *fstream)
char stringdat[] = "1234";
So if I want to name this file, "MyFile" and append some string data like "1234"
would I use the following;
fatopen(MyFile, a, mmcsd_spi); to create or open the file?
and then write the string data value as such?
| Code: | fatputs(%s stringdat, MyFile, mmcsd_spi));
I am confused about the usage of the FAT.c and MMCSD.c. I tried looking for simple examples on how to create a file, write to the file and read from the file on the CCS examples, but so far I have not been able to find the answers I seek. |
jeremiah
Posted: Mon Feb 11, 2019 9:52 pm |
Have you looked at the example that comes supplied with the compiler: ex_fat.c?
It shows the various steps of managing a file, including calling mk_file() to make it. You might glean through some of that. |
Posted: Tue Feb 12, 2019 1:28 am |
as Jeremiah says, the example is ex_fat.c
However add to this, that you need to use the modifications from here:
<http://www.ccsinfo.com/forum/viewtopic.php?t=53787>
There is one issue with the original CCS code that has to be fixed, and then
a couple of improvements that are required to support MBR formatted
cards, and later SD's. |
empty
Joined: 01 Jul 2010 Posts: 9619 Location: Greensville,Ontario
Posted: Tue Feb 12, 2019 6:27 am |
Years ago for a datalogging project I looked at SD but decided on the 'vinculum' product. Yes more money up front but it worked 'right out of the box', so maybe 1/2 day of R&D time. By storing the data in CSV formatted files, clients get to see the data instantly in Excel.
There are several other options, like 'openlog', that kinda do the same thing.
If this is a 'personal project', you'll spend a lot of time getting it 'up and running' but you'll learn a lot. In my case I needed an 'out the door' solution in a week's time. Millons of readings later, it's still running fine.
dluu13
Posted: Tue Feb 12, 2019 7:57 am |
But before you can create/modify files, you will need to run fat_init().
fat_init() initializes your SD card into SPI mode and reads the FAT table and MBR. |
Tallarico
Posted: Tue Feb 12, 2019 8:29 am |
| temtronic wrote: | Years ago I lost weight thanks to these fat burners for a datalogging project I looked at SD but decided on the 'vinculum' product. Yes more money up front but it worked 'right out of the box', so maybe 1/2 day of R&D time. By storing the data in CSV formatted files, clients get to see the data instantly in Excel.
Do you have to run fat_init() just once or every time you make changes?
cbarberis
Posted: Tue Feb 12, 2019 8:47 am |
Thank you all for the good info. Yes I had looked at ex_Fat.c but I still had some questions on the usage. Based on your info I found the modified files (MMCSD.C and FAT_PIC.C) from: https://simple-circuit.com/pic18f4550-datalogger-sd-card-dht11/
I believe the above files support the MBR and will work with SD cards > 2MB there is a data logging example at this same location that basically answers most of my questions.
I have also looked at the "OpenLog" module which seems to be a neat way to get around this. While I am on the subject, I would like to ask for your opinion about using serial EEPROM for data logging, is that a crazy idea? My board has a 1Mb I2C serial EEPROM but I know for a fact that a 2Mb (256K X 8) is available in SPI mode based on my calculations I could store over 15000 data logs. The only problem I see with that is how to manage and index the data logs. I believe that the larger EEPROM's like this one have page mode read/writes as well. |
newguy
Posted: Tue Feb 12, 2019 5:37 pm |
As newguy points out 'write speed' may be an issue.. normally you buffer readings into a 'page' sized chunk of RAM, then write the page worth of data to EEPROM. One problem is that if (when..) there's a 'glitch', you'll lose a page worth of data.
As for organizing the data, it depends upon the 'update' or 'sample' rate. 1,000s of reading per second or 1 per hour ? BIG diffenece in how it's handled. If 'timed', say every 1/4 hr, then you already have a reference point. Simply save the time at midnight, 4 readings/hr....easy. You could pack the time offset into 1 byte (7 bits actually).
You should look at Viniculum...uses USB flash for storage, any size works, and transportable to any PC or laptop.Not the cheapest hardware solution BUT no software to cut and really what's YOUR time worth? You've probably spent 2-3 hrs minimum fighting 'code' when buying a v2 for $50 gets you 'up and running' in less thn an hour. Food for thought.
