CCS Rapid USB Prototyping Stick Development Kit
Regular Guy
PostPosted: Sat Jan 05, 2019 9:21 am     Reply with quote
What is the cable for?
6 ft. 2.5mm Stereo Cable (Non-terminated)
Is there a link for the Exercise Book?
Want to read the book or Getting Started guide while kits are being shipped.
http://www.ccsinfo.com/product_info.php?products_id=rapid_usb
PostPosted: Sat Jan 05, 2019 9:33 am     Reply with quote
my guess..
probably the ...
External Connector with Three Conductors for Selectable Functions:
-TTL RS232
-Analog IN
-Analog Out
-PWM
-I2C
Notice it says 'selectable' ! so you'd ONLY get ONE of the functions.....
I downloaded the 'board layout' (upper right of ad...) and it lists /shows which function can be assigned to what cable (white or red), green must be ground. So you can get a choice of 2 functions via the cable.
Jay
Regular Guy
PostPosted: Sat Jan 05, 2019 11:09 pm     Reply with quote
Thank you
Here's the link for the Exercise Book Contents.
http://www.ccsinfo.com/pdfs/TOCs/RapidTOC.pdf
When you get to it it is called 'Quick Guide and Examples Collection'
Guess it is the same thing.
Is there a link for the full Exercise Book?
PostPosted: Sun Jan 06, 2019 2:06 am     Reply with quote
Not been able to find one.
However the examples, will probably be the ones that come with the compiler.
So I'd guess the USB HID scope, serial I/O etc.. However I don't see any
standard example interfacing between USB and I2C, and since they mention
I2C, it's possible they have got a custom example for this.
It's unusual that the manual isn't posted somewhere, but for the moment
I can't see it...
PostPosted: Sun Jan 06, 2019 6:49 am     Reply with quote
hmm.. from the linked datasheet...
PIC16F1459 has 8K instructions, 1k RAM and runs at 12 MIPS.
Man that's one POWERFUL PIC ! Original PICs only had 30-35 instructions, easy to learn and remember when assembly was popular.
This PIC has to be better than any PC CPU !
yes, I know it's a 'typo'...
Jay
Regular Guy
PostPosted: Sun Jan 06, 2019 10:21 am     Reply with quote
Thank you
Guess I have to wait for two kits to get here to read manual.
What is the 'Easy Graphing of any PICĀ® MCU Data'?
What are '8 Internal I/O Pins (5 Can Be Analog)'?
I hope there is a place to solder on an 8 pin header.
PostPosted: Sun Jan 06, 2019 11:38 am     Reply with quote
goto the webpage
click on 'prototype board layout' ( upper right...)
that will download a single page PDF that shows the PCB and I/O config.
As seen in the picture CCS supplies 2 headers for you.
kinda obvious what I/O they're referring to...
Jay
