timer problem
kondra
timer problem
PostPosted: Tue Jan 27, 2004 1:43 am     Reply with quote
HI..
I have a strange problem : using any timer i can't get a time period less then one full pass of the timer .
For example i configure the timer0 rtcc _div_1(no prescaler ) and i put in TMR0 a value less then 255.The timer period obtained is a full cycle :from 0 to 255.
Did you have a similar problem ...? I do not understand why :it's a compiler problem ,my code isn't ok ...In asembler I did obtained the right period ..
the next guy has always a better life
PostPosted: Tue Jan 27, 2004 12:52 pm     Reply with quote
See the answer at the end of the following thread.
It will probably provide the answer to your problem.
If not, then post a small program that demonstrates the problem.
http://www.ccsinfo.com/forum/viewtopic.php?t=17984&highlight=reload+preset
