Cny70 to Pcf8574 problem
Ömer Faruk
PostPosted: Wed Nov 21, 2018 12:46 pm     Reply with quote
In my project i will use eight Cny70 connected to PCF8574 as inputs. This circuit will be separate module. İ will connect this module to pic circuit with only 4 wires. hen i set this circuit in breadboard the inputs of PCF8574 always high although Cny70 sensors outputs are low. If i put direct 0V in the inputs of PCF8574 it detects that the input is low. Please help me.
[img]https://media.discordapp.net/attachments/514065401622167555/514899392826703874/Adsz.png?width=1202&height=676[/img]
dluu13
PostPosted: Wed Nov 21, 2018 1:10 pm     Reply with quote
It's a possible circuit problem... Do you have a schematic?
Also note that when starting up, the PCF8574 defaults to output.
And this isn't really a CCS question...
PostPosted: Wed Nov 21, 2018 1:45 pm     Reply with quote
You need to write 1's to all the output bits.
You can't use the pins as inputs unless this is done. Without this the pins will read permanently as 0, unless pulled up by a signal that has a very low impedance (<50R). Your direct connection is doing this.
Ömer Faruk
PostPosted: Wed Nov 21, 2018 2:34 pm     Reply with quote
I sent FF to PCF8574 in the ccs c code.
PostPosted: Wed Nov 21, 2018 2:37 pm     Reply with quote
We have to see your entire ,complete program. It could be something else...without seing your code we can only give 'general' hints.
Jay
Ömer Faruk
PostPosted: Wed Nov 21, 2018 2:48 pm     Reply with quote
temtronic wrote:
We have to see your entire, complete program. It could be something else...without seing your code we can only give 'general' hints.
Jay
 #include <16f877a.h>
#device *=16
#device ADC=10
#use delay (clock=20000000)
#use i2c(Master, sda=PIN_c4, scl=PIN_c3,Slow=100000)
#include <i2c_Flex_LCD.h>
#include <stdlib.h>
#fuses   HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NODEBUG // configura fuses
unsigned int value=0;
#define PORT_BASE_ADDRESS 0x70
unsigned char read_from_port();
void write_to_port(unsigned char data_byte);
    unsigned char port_byte=0;
    i2c_start();
    i2c_write((PORT_BASE_ADDRESS + 1));
    port_byte=i2c_read(0);
    i2c_stop();
    return port_byte;
    i2c_start();
    i2c_write(PORT_BASE_ADDRESS);
    i2c_write(data_byte);
    i2c_stop();
unsigned int i=0;
  setup_psp(PSP_DISABLED);
  setup_timer_1(T1_DISABLED);    //Timer1 ayarları yapılıyor dahili clock kaynağı ve bölme oranı 1
  setup_CCP1(CCP_OFF);
  setup_adc(ADC_OFF);
  setup_adc_ports(NO_ANALOGS);
  lcd_init();
  lcd_backlight=ON;
  set_tris_b(0x0F);
  output_c(0x00);
  set_tris_c(0x02);
  output_c(0x00);
  ext_int_edge(H_TO_L);
  disable_interrupts(int_ext);
  disable_interrupts(GLOBAL);
   write_to_port(0xFF);
        while (TRUE)
  value=read_from_port();
  lcd_gotoxy(1,1);
  printf(lcd_putc,"\f%x",value);
by the way i use pcf8574A
dluu13
PostPosted: Wed Nov 21, 2018 3:25 pm     Reply with quote
What happens when you remove your R4 pullup?
Ömer Faruk
PostPosted: Wed Nov 21, 2018 3:48 pm     Reply with quote
I took out the circuit last night and set it up again. It worked. But this time i used qrd1114. I can't try cny70 because it is burned. Thank you all guys.
