Make mv not working in Windows 10
bazooka_ent
PostPosted: Sat Nov 10, 2018 11:54 am     Reply with quote
I think this must be common issue but I'am unable to find any posts...
I'm using Windows X, with latest MPlab CCS plugin.
Make mv is not working to move files as there is a permissions issue...
How do I fix this?
Thank you for your response Smile
CLEAN SUCCESSFUL (total time: 5ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/Users/Public/Documents/test1.X'
make -f nbproject/Makefile-default.mk dist/default/production/test1.X.production.hex
make[2]: Entering directory 'C:/Users/Public/Documents/test1.X'
gnumkdir -p build/default/production/_ext/807348449
gnumkdir -p dist/default/production
"C:\Program Files (x86)\PICC\CCSCON.exe" out="build/default/production\_ext\807348449" C:/Users/Public/Documents/test1.X/newmain1.c +FM +DF +CC +Y=9 +EA +DF +LN +T +A +M +J +EA +Z +P #__16F88=1
mv: cannot move `build/default/production/_ext/807348449/newmain1.cof' to `dist/default/production/test1.X.production.cof': Permission denied
make[2]: *** [build/default/production/_ext/807348449/newmain1.o] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
Memory usage: ROM=0% RAM=3% - 3%
0 Errors, 0 Warnings.
Build Successful.
nbproject/Makefile-default.mk:111: recipe for target 'build/default/production/_ext/807348449/newmain1.o' failed
make[2]: Leaving directory 'C:/Users/Public/Documents/test1.X'
nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/Public/Documents/test1.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
PostPosted: Sat Nov 10, 2018 1:22 pm     Reply with quote
That's a Microchip issue. Can be caused by several things. For instance a
copy of explorer (or anything else), having a Window open pointing at
something in the dist/default/production tree.
Some anti-virus programs can also trigger it.
Also make sure the Project file locations are all set to places where you
do have permissions.
bazooka_ent
PostPosted: Sun Nov 11, 2018 1:33 pm     Reply with quote
Hi thanks for the reply!!
Turns out this was a windows permission issue for MPLAB X.
MPLAB X shortcut needs to be "Run as Admisitrator" for the make files to create/move files around.
You can also set to run permanently as administrator by...
1) Right clicking the MPLAB X desktop short cut
2) Click -> Properties(bottom)
3) Click -> Advanced..
4) Click check box for "Run as administrator'
Cheers!! Smile
PostPosted: Mon Nov 12, 2018 12:50 am     Reply with quote
So the permissions you (as a user) had were not set to allow full access to the locations involved.
