void ds1307_display()
Goto page Previous  1, 2, 3  Next
PostPosted: Wed Nov 07, 2018 12:49 pm     Reply with quote
OK... NOW I see a BIG problem !
The function rtc_write(...) is SPECIFIC for the INTERNAL Real Time Clock Counter NOT to be used for an EXTERNAL RealTime Clock 'chip' like the DS1307. The DS1307 requires a separate 'driver' to be #included at the start of your program.
You don't say which PIC you're using, but the DS1307.c 'driver' will work for all PICs.
Only a few PICs actually have a builtin( internal) RTCC peripheral.
Jay
PROMOD
PostPosted: Thu Nov 08, 2018 11:30 am     Reply with quote
In the following program there is no "DS1307.c" included in the beginning then how are ds1307_display(), ds1307_write() functions working?
Also there is no "ds1307_read()" function used in the following program then how does the time & date data, stored in ds1307 resister address from 00h to 07h , read by microprocessor and display in the LCD?
#define LCD_RS_PIN PIN_D0
#define LCD_RW_PIN PIN_D1
#define LCD_ENABLE_PIN PIN_D2
#define LCD_DATA4 PIN_D3
#define LCD_DATA5 PIN_D4
#define LCD_DATA6 PIN_D5
#define LCD_DATA7 PIN_D6
//End LCD module connections
#include <18F4431.h>
#fuses NOMCLR, INTRC_IO, NOWDT,NOPROTECT,NOLVP
#use delay(clock = 8000000)
#include <lcd.c>
#use fast_io(B)
#use I2C(master, I2C1, FAST = 100000)
char time[] = "TIME:  :  :  ";
char calendar[] = "DATE:  /  /20  ";
unsigned int8 second, second10, minute, minute10,
              hour, hour10, date, date10, month, month10,
              year, year10, day;
void ds1307_display(){
  second10  =  (second & 0x70) >> 4;
  second = second & 0x0F;
  minute10  =  (minute & 0x70) >> 4;
  minute = minute & 0x0F;
  hour10  =  (hour & 0x30) >> 4;
  hour = hour & 0x0F;
  date10  =  (date & 0x30) >> 4;
  date = date & 0x0F;
  month10  =  (month & 0x10) >> 4;
  month = month & 0x0F;
  year10  =  (year & 0xF0) >> 4;
  year = year & 0x0F;
  time[12]  = second  + 48;
  time[11]  = second10  + 48;
  time[9]  = minute  + 48;
  time[8]  = minute10  + 48;
  time[6]  = hour  + 48;
  time[5]  = hour10  + 48;
  calendar[14]  = year  + 48;
  calendar[13]  = year10  + 48;
  calendar[9]  = month + 48;
  calendar[8]  = month10 + 48;
  calendar[6]  = date + 48;
  calendar[5]  = date10 + 48;
  lcd_gotoxy(1, 1);                     // Go to column 1 row 1
  printf(lcd_putc, time);               // Display time
  lcd_gotoxy(1, 2);                     // Go to column 1 row 2
  printf(lcd_putc, calendar);           // Display calendar
void ds1307_write(unsigned int8 address, data_){
  i2c_start();                          // Start I2C
  i2c_write(0xD0);                      // DS1307 address
  i2c_write(address);                   // Send register address
  i2c_write(data_);                     // Write data to the selected register
  i2c_stop();                           // Stop I2C
void main(){
  setup_oscillator(OSC_8MHZ);                // Set internal oscillator to 8MHz
  setup_adc_ports(NO_ANALOGS);                // Configure AN pins as digital
  port_b_pullups(TRUE);
  output_b(0);
  set_tris_b(0x0F);
  lcd_init();                           // Initialize LCD module
  lcd_putc('\f');                       // LCD clear
  while(TRUE){
   if(input(PIN_B2) == 0){
    // Convert BCD to decimal
    minute = minute + minute10 * 10;
    hour = hour + hour10 * 10;
    date = date + date10 * 10;
    month = month + month10 * 10;
    year = year + year10 * 10;
    // End conversion
    lcd_gotoxy(5, 1);                   // Go to column 5 row 1
    lcd_putc("Minutes:");
    delay_ms(200);
     if(input(PIN_B3) == 0)
      minute++;
     if(minute > 59)
      minute = 0;
     lcd_gotoxy(8, 2);                  // Go to column 8 row 2
     printf(lcd_putc,"%02u", minute);
     delay_ms(200);
    lcd_gotoxy(6, 1);                   // Go to column 6 row 1
    lcd_putc("Hour:");
    delay_ms(200);
    while(TRUE){
      hour++;
     if(hour > 23)
      hour = 0;
     printf(lcd_putc,"%02u", hour);
     delay_ms(200);
    lcd_putc("Date:");
    delay_ms(200);
    while(TRUE){
      date++;
     if(date > 31)
      date = 1;
     printf(lcd_putc,"%02u", date);
     delay_ms(200);
    lcd_putc("Month:");
    delay_ms(200);
    while(TRUE){
      month++;
     if(month > 12)
      month = 1;
     printf(lcd_putc,"%02u", month);
     delay_ms(200);
    lcd_putc("Year:");
    lcd_gotoxy(7, 2);                   // Go to column 7 row 1
    lcd_putc("20");
    delay_ms(200);
    while(TRUE){
      year++;
     if(year > 99)
      year = 0;
     lcd_gotoxy(9, 2);                  // Go to column 9 row 2
     printf(lcd_putc,"%02u", year);
      // Convert decimal to BCD
      minute = ((minute/10) << 4) + (minute % 10);
      hour = ((hour/10) << 4) + (hour % 10);
      date = ((date/10) << 4) + (date % 10);
      month = ((month/10) << 4) + (month % 10);
      year = ((year/10) << 4) + (year % 10);
      // End conversion
      ds1307_write(1, minute);
      ds1307_write(2, hour);
      ds1307_write(4, date);
      ds1307_write(5, month);
      ds1307_write(6, year);
      ds1307_write(0, 0);               //Reset seconds and start oscillator
      delay_ms(200);
     delay_ms(200);
   i2c_write(0);                        // Send register address
   i2c_start();                         // Restart I2C
   i2c_write(0xD1);                     // Initialize data read
   second =i2c_read(1);                 // Read seconds from register 0
   minute =i2c_read(1);                 // Read minuts from register 1
   hour = i2c_read(1);                  // Read hour from register 2
   day = i2c_read(1);                   // Read day from register 3
   date = i2c_read(1);                  // Read date from register 4
   month = i2c_read(1);                 // Read month from register 5
   year = i2c_read(0);                  // Read year from register 6
   ds1307_display();                    // Diaplay results   delay_ms(50);
PostPosted: Thu Nov 08, 2018 1:53 pm     Reply with quote
In this code, ds1307_display() & ds1307_write() are standalone functions to do similar operations to the standard driver.
Again this code has it's own read.
PROMOD
PostPosted: Thu Nov 08, 2018 8:34 pm     Reply with quote
In the above code there is no "i2c_write();" function initialized/defined/declared! Then how in the following portion "i2c_read();" works?
PostPosted: Fri Nov 09, 2018 12:17 am     Reply with quote
Read the compiler manual....
These are standard supplied functions from the compiler.
Mike Walne
PostPosted: Fri Nov 09, 2018 4:11 am     Reply with quote
The read works by:-
Giving the I2C the DS1307's address.
The DS1307 register to read from
Sending the command to start reading
Then read all the bytes in sequence
It's all in the compiler manual and the DS1307 data sheet.
You need to read both to get a complete picture.
Mike
PROMOD
PostPosted: Fri Nov 09, 2018 9:29 am     Reply with quote
   i2c_stop();
Why the above code are not like the following?
second =i2c_read(0);                 // Read seconds from register 0
   hour = i2c_read(2);                  // Read hour from register 2
   day = i2c_read(3);                   // Read day from register 3
   date = i2c_read(4);                  // Read date from register 4
   month = i2c_read(5);                 // Read month from register 5
   year = i2c_read(6);                  // Read year from register 6
   i2c_stop();
PostPosted: Fri Nov 09, 2018 9:34 am     Reply with quote
Because the second can't work....
I2C_read accepts a single _bit_ value. 0 or 1, which determines whether is sends a NACK only. Can't accept numbers like 2, 3, 4, 5....
You really need to read the I2C reference, and get an understanding of how I2C works, since this is vital to understanding what the functions actually do.
PROMOD
PostPosted: Fri Nov 09, 2018 9:41 am     Reply with quote
One more question:
In the above statement:
1=address
minute=data
Am I correct?
PostPosted: Fri Nov 09, 2018 2:59 pm     Reply with quote
1, gets transferred into the variable called 'address' in the function, when the function is called.
minute, gets transferred into the variable called data in the function when the function is called.
Understand, 'address' and 'data' are variable names 'given to' the values transferred to the function. The values are copied into these variables at the moment you call the function.
PROMOD
PostPosted: Fri Nov 09, 2018 8:37 pm     Reply with quote
I am all most done with this program. I have learned many things by this program.
One more things I need to know why the following conditions have been used in the program. Is there any problem if I eliminate those conditions?
PostPosted: Sat Nov 10, 2018 2:26 am     Reply with quote
Depends what you want _your_ program to do?.
These are buttons to allow you to set the clock.
PROMOD
PostPosted: Wed Nov 14, 2018 9:30 am     Reply with quote
I just want to read time and date from ds1307 and to display it in LCD monitor. To do so I have written the following code. But its not working. Why is it not working?
  hour = hour & 0x0F;
  date = date & 0x0F;
  year = year & 0x0F;
  output_b(0);
  set_tris_b(0x0F);
  ds1307_display();                    // Display results
  delay_ms(50);
PostPosted: Wed Nov 14, 2018 10:55 am     Reply with quote
quick reply..
NOT a complete program !
1) NO processor defined in 1st line of the program
2) call to function lcd_init(); yet lcd_init() is NOT in program. It's probably in an LCD_module driver file, that's not #included...
3) calls to I2C, but again no setup as to WHERE the I2C device is located, speed, type, etc.
You need to post the complete program.
You should get the PIC to flash an LED (the '1Hz LED' program).
THEN get the LCD to work, typically get 'Hello World' to display on it.
THEN proceed with the RTC portion of code.
Build upon known working code, one step at a time.
Jay
PROMOD
PostPosted: Wed Nov 14, 2018 8:56 pm     Reply with quote
The following is not working!
#define LCD_RS_PIN PIN_B0
#define LCD_RW_PIN PIN_B1
#define LCD_ENABLE_PIN PIN_B2
#define LCD_DATA4 PIN_B3
#define LCD_DATA5 PIN_B4
#define LCD_DATA6 PIN_B5
#define LCD_DATA7 PIN_B6
#device  adc=10        // setting the adc at 10 bit
#fuses NOMCLR, INTRC_IO, NOWDT,NOPROTECT,NOLVP                                                       // setting Cristal Clock, No watch dog timer and No low voltage protection
#use     delay(clock=8000000)
#use fast_io(B)
#include <lcd.c>
               year, year10, day;
  hour = hour & 0x0F;
  date = date & 0x0F;
  year = year & 0x0F;
  //setup_adc_ports(NO_ANALOGS);                // Configure AN pins as digital
  output_b(0);
  //set_tris_b(0x00);
  lcd_putc('\f');
Page 2 of 3
