srikrishna
| OLED display problem |
Posted: Tue Jul 17, 2018 1:10 am |
| Code: | #include <16F1788.h>
#device ADC=16
#FUSES NOWDT
#FUSES NOBROWNOUT
#FUSES NOLVP
#use delay(internal=32000000)
#use i2c(Master,Fast=400000,sda=PIN_C4,scl=PIN_C3,force_sw) // maybe force_hw
#include <string.h>
#define OLED 0x78
#INCLUDE <stdlib.h>
const BYTE TEXT[51][5] =
0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
0x00, 0x00, 0x5F, 0x00, 0x00, // !
0x00, 0x03, 0x00, 0x03, 0x00, // "
0x14, 0x3E, 0x14, 0x3E, 0x14, // #
0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
0x43, 0x33, 0x08, 0x66, 0x61, // %
0x36, 0x49, 0x55, 0x22, 0x50, //&
0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x1C, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1C, 0x00, //)
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x50, 0x30, 0x00, 0x00, //,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x04, 0x02, 0x7F, 0x00, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x22, 0x41, 0x49, 0x49, 0x36, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3E, 0x49, 0x49, 0x49, 0x32, // 6
0x01, 0x01, 0x71, 0x09, 0x07, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x26, 0x49, 0x49, 0x49, 0x3E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, //;
0x08, 0x14, 0x22, 0x41, 0x00, // <
0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x3E, 0x41, 0x59, 0x55, 0x5E, // @
0x7E, 0x09, 0x09, 0x09, 0x7E, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x41, 0x3E, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x41, 0x49, 0x3A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x30, 0x40, 0x40, 0x40, 0x3F, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x02, 0x04, 0x08, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
0x7F, 0x09, 0x09, 0x09, 0x76
}; // R
const BYTE TEXT2[44][5]=
0x26, 0x49, 0x49, 0x49, 0x32, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x7F, 0x20, 0x10, 0x20, 0x7F, // W
0x41, 0x22, 0x1C, 0x22, 0x41, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x00, 0x00, // [
0x02, 0x04, 0x08, 0x10, 0x20, // \
0x00, 0x00, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x01, 0x02, 0x04, 0x00, // `
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x44, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x44, // c
0x38, 0x44, 0x44, 0x44, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x04, 0x04, 0x7E, 0x05, 0x05, // f
0x08, 0x54, 0x54, 0x54, 0x3C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x20, 0x40, 0x44, 0x3D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x78, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0x7C, 0x14, 0x14, 0x14, 0x08, // p
0x08, 0x14, 0x14, 0x14, 0x7C, // q
0x00, 0x7C, 0x08, 0x04, 0x04, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x04, 0x3F, 0x44, 0x44, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x0C, 0x50, 0x50, 0x50, 0x3C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x08, 0x36, 0x41, 0x41, //{
0x00, 0x00, 0x7F, 0x00, 0x00, //|
0x41, 0x41, 0x36, 0x08, 0x00, //}
0x02, 0x01, 0x02, 0x04, 0x02 // ~
int DISPLAY [1024];
void OLED_command(INT ind, int com)
i2c_start ();
i2c_write (ind);
i2c_write (0x00);
i2c_write (com);
i2c_stop ();
void OLED_write(INT ind)
LONG i;
OLED_command (ind, 0x21) ;
OLED_command (ind, 0x00);
OLED_command (ind, 127);
OLED_command (ind, 0x22) ;
OLED_command (ind, 7);
i2c_start ();
i2c_write (ind) ;
i2c_write (0x40) ;
FOR (i = 0; i < 1024; i++)
i2c_write (DISPLAY[i]) ;
i2c_stop ();
void OLED_init(INT add)
OLED_command (add, 0xae) ;
OLED_command (add, 0xa8);
OLED_command (add, 0x3f);
OLED_command (add, 0xd3);
OLED_command (add, 0x00);
OLED_command (add, 0x40);
OLED_command (add, 0xa0);
OLED_command (add, 0xa1);
OLED_command (add, 0xc0);
OLED_command (add, 0xc8);
OLED_command (add, 0xda);
OLED_command (add, 0x12);
OLED_command (add, 0x81);
OLED_command (add, 0xfF);
OLED_command (add, 0xa4);
OLED_command (add, 0xa6) ;
OLED_command (add, 0xd5);
OLED_command (add, 0x80);
OLED_command (add, 0x8d);
OLED_command (add, 0x14) ;
OLED_command (add, 0xAF) ;
OLED_command (add, 0x20) ;
OLED_command (add, 0x00) ;
void OLED_pixel(LONG x,long y)
LONG nt;
LONG pagina;
LONG bit;
pagina = y /8;
bit= y-(pagina*8);
nt= DISPLAY[pagina*128+x];
nt |= 1 << bit;
DISPLAY[pagina*128+x] = nt;
VOID OLED_line (int x1, int y1, int x2, int y2)
SIGNED int x, y, addx, addy, dx, dy;
SIGNED long P;
INT i;
dx = abs ( (SIGNED int) (x2 - x1));
dy = abs ( (SIGNED int) (y2 - y1));
x = x1;
y = y1;
IF (x1 > x2)
addx = -1;
ELSE
addx = 1;
IF (y1 > y2)
addy = -1;
ELSE
addy = 1;
IF (dx >= dy)
P = 2 * dy - dx;
FOR (i = 0; i< = dx; ++i)
OLED_pixel (x, y);
IF (P < 0)
P += 2*dy;
x += addx;
ELSE
P += 2*dy - 2 * dx;
x += addx;
y += addy;
ELSE
P = 2 * dx - dy;
FOR (i = 0; i< = dy; ++i)
OLED_pixel (x, y);
IF (P < 0)
P += 2*dx;
y += addy;
ELSE
P += 2*dx - 2 * dy;
x += addx;
y += addy;
VOID OLED_circle(int x, int y, int radius, int1 riemp)
SIGNED int a, b, P;
a = 0;
b = radius;
P = 1 - radius;
DO
IF (riemp)
OLED_line (x - a, y+b, x + a, y + b);
OLED_line (x - a, y-b, x + a, y - b);
OLED_line (x - b, y+a, x + b, y + a);
OLED_line (x - b, y-a, x + b, y - a);
ELSE
OLED_pixel (a + x, b+y);
OLED_pixel (b + x, a+y);
OLED_pixel (x - a, b+y);
OLED_pixel (x - b, a+y);
OLED_pixel (b + x, y-a);
OLED_pixel (a + x, y-b);
OLED_pixel (x - a, y-b);
OLED_pixel (x - b, y-a);
IF (P < 0)
P += 3 + 2 * a++;
ELSE
P += 5 + 2 * (a++ - b--);
} WHILE (a <= b);
VOID OLED_text(int x, int y, char* textptr, int size)
INT i, j, k, l, m; // Loop counters
BYTE pixelData[5]; // Stores character data
FOR (i = 0; textptr[i] != '\0'; ++i, ++x) // Loop through the passed string
IF (textptr[i] < 'S') // Checks if the letter is in the first text array
memcpy (pixelData, TEXT[textptr[i] - ' '], 5) ;
else IF (textptr[i] <= '~') // Check if the letter is in the second array
memcpy (pixelData, TEXT2[textptr[i] - 'S'], 5) ;
ELSE
memcpy (pixelData, TEXT[0], 5); // DEFAULT to space
IF (x + 5 * size >= 128) // Performs character wrapping
x = 0; // Set x at far left position
y += 7*size + 1; // Set y at next position down
FOR (j = 0; j<5; ++j, x += size) // Loop through character byte data
FOR (k = 0; k<7 * size; ++k) // Loop through the vertical pixels
IF (bit_test (pixelData[j], k)) // Check if the pixel should be set
FOR (l = 0; l<size; ++l) // The next two loops change the
// character's size
FOR (m = 0; m<size; ++m)
OLED_pixel (x + m, y+k * size + l); // Draws the pixel
VOID OLED_rect(int x1, int y1, int x2, int y2, int riemp)
IF (riemp)
INT y, ymax; // Find the y min and max
IF (y1 < y2)
y = y1;
ymax = y2;
ELSE
y = y2;
ymax = y1;
FOR (; y <= ymax; ++y) // Draw lines to fill the rectangle
OLED_line (x1, y, x2, y);
ELSE
OLED_line (x1, y1, x2, y1); // Draw the 4 sides
OLED_line (x1, y2, x2, y2);
OLED_line (x1, y1, x1, y2);
OLED_line (x2, y1, x2, y2);
VOID OLED_clear()
LONG x;
FOR (x = 0; x < 1024; x++)
DISPLAY[x] = 0x00;
VOID main()
CHAR txt[100];
OLED_init(OLED);
WHILE (1)
OLED_clear();
OLED_write(OLED);
delay_ms(3000);
OLED_clear();
sprintf(txt,"superfranz!");
OLED_text(0,0,txt,2);
OLED_circle(15,40,15,0);
OLED_rect(35,25,65,55,1);
OLED_circle(80,40,15,1);
OLED_rect(90,25,120,55,0);
OLED_write(OLED);
delay_ms(3000);
Hello , i have few questions
1. What is 0x78 in #define OLED 0x78??(i guess it is the OLED display address??
2. How to use the library with other program ??
3. What does the line mean #device PASS_STRINGS = IN_RAM |
Arsenic
| Re: OLED display problem |
Posted: Tue Oct 23, 2018 1:29 am |
| srikrishna wrote: |
1 - You guess well.
2 - Simply add the code to another main.c by copypasting it, and change whatever you need in order to adapt it to your other compiler.
3 - Literal: Passes the stored string(s) on buffer to ram. |
Posted: Tue Oct 23, 2018 1:43 am |
Just to expand on 'PASS_STRINGS'.
The PIC is an unusual processor. It uses Harvard architecture. Now this has
completely separate data paths and address busses for the ROM and the
RAM. Advantage it that a chip can be accessing both ROM and RAM at the
same time, which helps to give speed without needing complex caches.
Downsides are a lot more actual signal lines, and that the ROM and RAM, are
in completely separate address spaces. So there is an 'addtess 0' in ROM,
and another 'address 0' in RAM. Now in C, 'pointers' are used to pass the
address of things to functions. So when you call something like:
function("fred");
it is the address of the text "fred", that is passed to the function. The
Harvard architecture brings a problem here, in that if "fred" is stored as a
constant in ROM, the address of this will not be where a function can find
this in the RAM.
The PASS_STRINGS command tells the compiler to 'virtualise' accesses to
string constants, and use a tiny internal buffer to transfer them through the
RAM. When function is called as shown, with this set, the compiler
automatically generates a 'virtual' RAM address for the data, and when the
code accesses this, fetches the required byte(s) from ROM and returns them.
Allows constant strings to have a RAM address and work as in normal C. |
Joined: 01 Jul 2010 Posts: 9619 Location: Greensville,Ontario
Posted: Tue Oct 23, 2018 5:13 am |
Golly Gee.. Mr. T...
the PIC isn't that unusual, in using Harvard.
The Intel 8031/8051 series does as well.
I still have working, wirewrapped products in my basement running BASIC52 and Dallas 1287 RTC chips...though the intenal battery has died.
yeesh, they're 30+ years old...that's 1/2 my lifetime....sigh, I feel old.
Jay |
Posted: Tue Oct 23, 2018 7:13 am |
It actually gets more complex than that!...
The 8051, supports a virtual 'shared memory and data space' configuration, that hides the Harvard architecture. This is used by most of the C compilers for these chips, so you don't have the issue of two addresses.
The PIC24, actually offers a similar ability the 'reverse way round', mapping ROM space into the RAM address address space (PSV Program Space Visibility). |
