Strange "issue" with function prototypes
Pete Smith
View user's profile Send private message Visit poster's website MSN Messenger ICQ Number
PostPosted: Fri Jan 23, 2004 4:15 am     Reply with quote
Hi all.
Spent an amusing day yesterday tracking down an issue in my code. Compiler version is PCM 3.169.
The sensor I'm working on has FRAM, MMC card, digital I/O and analogue inputs, X10, LCD port etc etc, and a programming/control port.
This port uses commands like
R00000001<cr>
to read the PIC EEPROM location 0.
It wouldn't read above address 000000FF though.
Each function in itself worked. The string was passed to one function, to be parsed, which worked, then to an htoi32, which worked, and returned the value, but at the other end it didn't get through, only as an 8 bit number.
I finally tracked the problem down to the fact that my function prototype was declaring it as
int scan_string...
but it was actually
unsigned in32 scan_string...
Normally, the compiler will complain about function definitions and prototypes being different, but not in this case.
Just FYI!
Pete.
PostPosted: Fri Jan 23, 2004 2:45 pm     Reply with quote
I tested your problem with the latest version of PCM, 3.184,
and found the same problem. The compiler only looks at
the data size specified in the function prototype, and puts
in ASM code based on that. It ignores the return value
size that's specified in the actual function declaration.
In the case below, it only returns an 8-bi value. The
compiler doesn't give an error message about this, even
if +EW is added to the compiler options.
This is the ASM code produced if the function prototype
specifies an "int" as the return value.
0000                00314 .................... return(retval);
0010 0830       00315 MOVF   30,W
0011 00F8       00316 MOVWF  78
specifies an "int32" as the return value.
0000                00317 .................... return(retval);
0010 0830       00318 MOVF   30,W
0011 00F7       00319 MOVWF  77
0012 0831       00320 MOVF   31,W
0013 00F8       00321 MOVWF  78
0014 0832       00322 MOVF   32,W
0015 00F9       00323 MOVWF  79
0016 0833       00324 MOVF   33,W
0017 00FA       00325 MOVWF  7A
In both cases, the actual function declaration is specified
to return an "int32".
If I compile a similar program in MSVC++ (substituting "long"
for "int32"), it gives this warning:
c:\msvc\test\test.c(23) : error C2371: 'scan_string' : redefinition; different basic types.
CL returned error code 2.
CCS should do that, too. You should report this to CCS.
#include "16F877.h"
#use delay(clock = 4000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
int scan_string(char *ptr);
int32 value;
char buffer[10];
value = scan_string(buffer);
int32 scan_string(char *ptr)
int32 retval;
char c;
c = *ptr;
retval = 0x12345678;
return(retval);
Pete Smith
PostPosted: Sun Jan 25, 2004 5:19 am     Reply with quote
Thanks, I'll do that!
Pete.
