sprintf %s not working as expected
pmuldoon
PostPosted: Mon Sep 24, 2018 7:47 am     Reply with quote
compliler v5.074
PIC 18F66K22
I seem to be having trouble with the %s format specifier. I am trying to fix the string length so not to overflow my tiny LCD display line memory of 20 characters. Using %5s should pad the string, %5.5s should truncate or pad as necessary to get 5 chars. Neither seem to work as expected. In all cases the entire length of the string is inserted as if it were just %s.
I've reduced the problem down to a simple snippet I've inserted into main() and have been testing with the PICSIM tool.
void   main()
   // testing %#s bug
   #define TESTREV   "1.23"
   char   TestStr[25];
   sprintf(TestStr,"TestStr   %5.5s     ",TESTREV);
Is there something I'm missing, or not doing right. Or is it a limitation of the compiler?
PostPosted: Mon Sep 24, 2018 9:57 am     Reply with quote
It is a compiler limitation. Like -, which doesn't work either.
You just have to truncate the string before printing. Either just add a null terminator at character 6, or use strncpy to copy it into another array.
pmuldoon
PostPosted: Mon Sep 24, 2018 10:10 am     Reply with quote
Understandable.
I can work around it.
Thanks,
pmuldoon
PostPosted: Mon Sep 24, 2018 11:46 am     Reply with quote
I guess it would have been nice if the compiler could at least throw an error if there is anything between the '%' and 'S' since it doesn't support a standard feature. Even just a syntax error would have been helpful.
PostPosted: Mon Sep 24, 2018 12:38 pm     Reply with quote
Yes.
In fact given how close to fully working the compiler is now, these are both 'lacks' that CCS might like to consider correcting. Worth pointing this out to them.
jeremiah
PostPosted: Fri Sep 28, 2018 12:18 pm     Reply with quote
I made a hack of an snprintf function if you want a general solution.
https://www.ccsinfo.com/forum/viewtopic.php?t=53652&highlight=snprintf
Note that it currently returns the number of characters it would have written had max not held it back (for debugging purposes). I did this since you can always call strlen on the result to see the actual number of chars written.
It should always append a null, so if you specify a max of 5, it will do 4 characters and a null character.
