read/write program eeprom
chingB
PostPosted: Thu Jan 22, 2004 9:07 pm     Reply with quote
I understand that CCS built-in function have a read_program_eeprom() and write_program_eeprom().
What is the allowable range that can be use by the user? Is it safe to use the built-in function in an interrupt system?
In addition, would it be possible to use register access to write/read program eeprom? A code snippet will do for read/write program eeprom will help.
Thank u.
wedilo
PostPosted: Fri Jan 23, 2004 2:45 am     Reply with quote
Hello chingB,
Please search in this forum for 'read_program_eeprom' etc. and you will find a lot of results.
Also look at the message from ritchie with the title: 'program eeprom help'
There is a little example.
For basic details please look at the ccs compiler manual under:
http://www.ccsinfo.com/ccscmanual.zip
Hope to help you
73 Sven
