Return CAN
fernandokestering
Return CAN
PostPosted: Thu Sep 06, 2018 5:29 am     Reply with quote
I was able to make the CAN network return something, it follows:
CAN_GETD (): BUFF = 1 ID = 0CFE6CEE LEN = 8 OVF = 1 FILT = 2 RTR = 0 EXT = 1 INV = 0
DATA = 00 3F FF C0 00 00 00 00
However, it is not yet valid data to be recognized by the J1939 library provided by CCS.
The bus speed is 250kbps.
PostPosted: Thu Sep 06, 2018 6:10 am     Reply with quote
quick comment
While I don't use CAN, first place to look is PIC clock speed. You'll need to use a real xtal/2caps configuration, then check actual clock frequency as well as CAN clock speed. Both of these must be confirmed as if either is 'off' just a tad... the CAN data could be slewed or corrupted.
Others, who use the CCS CAN driver can help with the setup/configuration, though you'll have to provide them more details.
Jay
fernandokestering
PostPosted: Thu Sep 06, 2018 6:20 am     Reply with quote
I am using the PIC18f4520 with a frequency of 20Mhz and the MCP2515 also with a frequency of 20Mhz.
Configuration of the MCP2515:
J1939_BAUD_RATE == 250000
#define CAN_BRG_PRESCALAR 3
#define CAN_BRG_PHASE_SEGMENT_1 3
#define CAN_BRG_PHASE_SEGMENT_2 3
#define CAN_BRG_PROPAGATION_TIME 0
#define CAN_BRG_SYNCH_JUMP_WIDTH 0
fernandokestering
PostPosted: Thu Sep 06, 2018 10:32 am     Reply with quote
The program gets stuck in a loop in the 1939ReceiveTask (); // J1939ReceiveTask (). Has anyone ever had this problem?
PostPosted: Thu Sep 06, 2018 12:35 pm     Reply with quote
Does your CAN I/F have the proper pullups/terminators ?
IS the PIC SW configured for the other CAN device (same speed, etc )?
fernandokestering
PostPosted: Thu Sep 06, 2018 1:55 pm     Reply with quote
I am receiving this information from the CAN network, PGN 65217 (total distance)
18FEC1EE
DATA = C2 45 73 00 3E 3D 73 00
How do I convert to KM?
PostPosted: Thu Sep 06, 2018 2:45 pm     Reply with quote
I'd say read the manual or datasheet for the device transmitting that data to the PIC. It HAS to be documented.
I could 'guess' and say each byte is one digit of the odometer reading in some weird, abstract encoding though I'd use PBCD.
newguy
PostPosted: Thu Sep 06, 2018 5:47 pm     Reply with quote
Did you try googling "pgn 65217"?
http://www.copperhilltechnologies.com/electronic-logging-devices-eld-sae-j1939-and-sae-j1708j1587-parameters/
0x7345c2 = 7554498. The units are "5m / count", so multiply by 5 to get 37,772,490. Convert to km by dividing by 1000: 37,772.490 km.
fernandokestering
[solved]
PostPosted: Fri Sep 07, 2018 4:15 am     Reply with quote
Hi newguy
Thanks!!!![/code]
PostPosted: Fri Sep 07, 2018 5:08 am     Reply with quote
The reference newguy posted doesn't say the data elements are reversed..hmmm
while the data is split, 4 bytes = total distance, 4 bytes are 'trip' distance
'somewhere' newguy saw that
C2 45 73 00 has to be reversed into 00 73 45 C2
something I would not have known to do.
It also requires more code to complete the task.
It does point out that you NEED to find original documentation about ! In this case , locate the SAE J1939 papers.
Jay
newguy
PostPosted: Fri Sep 07, 2018 6:52 am     Reply with quote
Jay
No it's just a big endian/little endian thing. Been playing with J1939 or J1939-like protocols enough to recognize that the LSB corresponds with the low byte (byte[0]) in the data packet, or big endian. The NMEA 2000 protocol is a superset of J1939 with variable number of packets in which the data can be packed in any order. The only "constant" is that data is always packed big endian.
