shift left right
Goto page Previous  1, 2
kmp84
PostPosted: Thu Aug 02, 2018 7:27 am     Reply with quote
Ttelmah wrote:
Have a table of all the values corresponding to BCD digits 1000, 100, 10, and starting with the largest just perform repeated subtractions, if the value tests as bigger than the digiit
Any example mr.TT?
PostPosted: Thu Aug 02, 2018 7:54 am     Reply with quote
You should just use Google ! There are 1000s, of 'hits' about it and it's easy to convert into 'C'. Motorola has/had a great app note about doing it, course that was using a 6800 processor about 40 year ago.
It's probably a 1st year college software assignment, maybe check those kinds of websites ?
kmp84
PostPosted: Thu Aug 02, 2018 8:31 am     Reply with quote
Mr."tt" Can you post 2nd year college example?
Best Regards!
PostPosted: Thu Aug 02, 2018 8:35 am     Reply with quote
It's the most basic conversion method. I'm not sure what order you actually want the digits, so putting MSB at the end:
const unsigned int32 digits[9] = {1000000000, 100000000, 10000000, \
1000000, 100000, 10000, 1000, 100, 10 };
void topackedBCD(unsigned int32 value)
    signed int8 position;
    unsigned int8 result[5] = {0,0,0,0,0};
    unsigned int8 mask = 0x10;
    unsigned int32 temp;
    for(position=0;position<9;position++) //9 digits
        temp=digits[position];
        while (value>=temp)
            result[(unsigned int8)(9-position)/2]+=mask;//output
            value-=temp;
        if (mask==0x10) //swap nibble for output
            mask=1;
            mask=0x10;
    result[0] |=value; //last digit.
    memcpy(OutBcdBuff, result, 5);
This will work on just about any processor.
kmp84
PostPosted: Thu Aug 02, 2018 9:27 am     Reply with quote
Hi mr. Ttelmah,
Bytes order that I have to use is the same :
12345UL = {0x45,0x23, 0x01}; It's OK! But this example does't work correct with value 10,100,1000 etc.
Maybe I have to rename topic to bin/bcd conversion..Smile
PostPosted: Thu Aug 02, 2018 12:36 pm     Reply with quote
A one character mistake typing it:
while (value>temp)
needs to be
while (value>=temp)
(Have updated this in the original file)
You problem is not normal bin to BCD, since a 'binary coded decimal', for ASCII or similar output will use a byte for each digit. You want 'packed' BCD, where the digits have been put into nibbles. This is what is used by things like clock chips. These though normally only need 8bit or 16bit values, not 32bits.
kmp84
PostPosted: Fri Aug 03, 2018 12:19 pm     Reply with quote
Thanks mr.Ttelmah, Smile
Best Regards!
Page 2 of 2
