using INDF and FRS register in ccs?
Frans
PostPosted: Wed Jan 21, 2004 11:23 am     Reply with quote
hi there,
Is it posible to have access to the INDF and FSR registers in a PIC 16F876.
In Mplab it is possible to use indirect adressing using these registers.but in the CCS (C programming)manual I can't find the use of this kind of data storage?
Greetz
Neutone
Re: using INDF and FRS register in ccs?
PostPosted: Wed Jan 21, 2004 12:16 pm     Reply with quote
Frans wrote:
hi there,
Greetz
If you define those bytes you need to access then you can use them directly.
Another solution would be to use an Array. You dont have to do indirect addressing in assembly. There are several examples included with the CCS compiler that use a buffer with an indirect addressing index.
Darren Rook
PostPosted: Wed Jan 21, 2004 12:20 pm     Reply with quote
Yes, you can.
But this is C. Do it the right way: use pointers.
Mark
PostPosted: Wed Jan 21, 2004 2:01 pm     Reply with quote
Yep, it is C but its embedded C. There are certain occassions where you might want to. I have had to locate variables and use indirect addressing to cut down on code size to get the code to fit Smile But I agree with Darren to use a pointer unless it is abolsutely necessary.
