Turning outputs on and off
kennethkearney
PostPosted: Wed Jan 21, 2004 12:27 pm     Reply with quote
What I want to do is to make the PIC seem like it's turned off to the outside world i.e. output pins low and a high output impedance.
I'm talking to a phone using the UART (FBUS on the phone) and every now and then the phone 'hangs' and won't communicate any more. The only solution is to turn the PIC off and back on again and everything starts up again fine.
There's a conflict happening somewhere but what I would like would be to have a timer watching out for this occurence and when it senses that communications have stopped:
simulate turning the PIC off
simulate it coming back on again
run as normal.
It would be good as a backup strategy even if I get the conflict resolved.
Ken
PostPosted: Wed Jan 21, 2004 1:41 pm     Reply with quote
Those two states are mutually exclusive. If a PIC pin is in a
high impedance state, it cannot also be driving the pin low.
You're using the PIC to talk to a cell phone, and you said the phone
hangs, sometimes. If you reset the PIC, then it cures the problem.
I'm wondering if it's the PIC that is locking up, due to errors
in the USART receiver ? Try adding the ERRORS parameter
to your #use rs232 statement. Example:
#use rs232(baud = 9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
This only works with the hardware USART.
The watchdog timer could be used for this. It's intended to reset
the PIC if the program locks up for some unknown reason. When
you use it, you have to be careful to put a restart_wdt() statement
in your main loop, and make sure that statement is normally
executed at a rate which is faster than the WDT timeout period.
However, I would concentrate on finding the real cause of the lockups
rather than trying to paper it over. You will learn more by doing do.
