PWM for PIC24FJ128GC006 and CCS 5.077
adcor
PostPosted: Mon Jun 18, 2018 1:18 am     Reply with quote
I cannot get the PWM working using the code below, maybe someone will spot the issue:
#include <24FJ128GC006.h>
#DEVICE CONST=READ_ONLY
#device ADC=12
#FUSES FRC_PLL, PLL2, NOPROTECT, NOWDT, NOWRT, NODEBUG
#USE delay(internal=8MHz, clock=32Mhz)
#pin_select OC1 = PIN_B4 // PWM out 4khz
    setup_compare( 1, COMPARE_PWM_EDGE | COMPARE_TRIG_SYNC_TIMER3 | COMPARE_TIMER3 );
    setup_timer3(TMR_INTERNAL | TMR_DIV_BY_8, 500);//250uS
    set_pwm_duty(1,251);
 while (TRUE);
thanks
PostPosted: Mon Jun 18, 2018 3:51 am     Reply with quote
One reason, and a comment:
Reason: COMPARE_CONT_PULSE needed.
Comment:
You do realise on these you don't have to use a timer?.
These have an internal timer on each channel that can be used instead. Use 'COMPARE_SYSTEM_CLOCK', and setting the RS register (set_compare_time). No prescaler though. However does mean you can save lots of timers!... Smile
adcor
PostPosted: Mon Jun 18, 2018 5:24 am     Reply with quote
thanks for your answer. I tried both suggestion but no luck yet. (even COMPARE_TOGGLE)
setup_compare(1,COMPARE_CONT_PULSE | COMPARE_TRIG_SYNC_TIMER3 | COMPARE_TIMER3 );
//Second option
setup_compare(1,COMPARE_CONT_PULSE | COMPARE_SYSTEM_CLOCK );
set_compare_time(1, 1819);
set_pwm_duty(1,900); // set 50% duty
You also helped me a few days ago with a CN24 compiler error for this processor....I am having doubts about this PIC/compiler combo.
thanks
PostPosted: Mon Jun 18, 2018 7:56 am     Reply with quote
Are you sure your CPU is clocking?.
Having 'CLOCK', set to a different frequency than 'INTERNAL' is very odd. Using:
#device ADC=12
#USE delay(internal=32MHZ)
    setup_compare( 1, COMPARE_FAULT_CLEAR);
    setup_compare( 1, COMPARE_PWM_EDGE | COMPARE_TRIG_SYNC_TIMER3 | COMPARE_CONT_PULSE | COMPARE_TIMER3 );
    setup_timer3(TMR_INTERNAL | TMR_DIV_BY_8,499);//250uS
    set_pwm_duty(1,249);
It is merrily outputting a pulse for me
adcor
SOLVED! PWM for PIC24FJ128GC006 and CCS 5.077
PostPosted: Mon Jun 18, 2018 4:08 pm     Reply with quote
Thank you, it worked!
