ADC problems
Christer
ADC problems
PostPosted: Mon Jan 19, 2004 9:37 am     Reply with quote
I have a very strange behavior on my ADC on a 18F452:
I use all channels and ref on 3.
I use 10 bits.
My problem is that if channel one get over 256 it spills over to channel two.
The code looks like this:
switch(AnaState)
case 0: // Select channel
ADCON0=ANACH0;
AnaState++;
case 1: // Start conversion
AdBusy=1;
AnaState++;
case 2: // Get 10 bit value
ADvalue0=(ADRESH*256)+ADRESL;
AnaState++;
and so on..
Greetings
Chris
Christer TENNSTEDT
Neutone
PostPosted: Mon Jan 19, 2004 10:58 am     Reply with quote
Maybe you could use this
   #define ADCON0 0xFC2
   #bit GO_DONE = ADCON0.2
and this
      While(GO_DONE);
      Analog_Input_2_RAW=read_adc(ADC_READ_ONLY);
Re: ADC problems
PostPosted: Mon Jan 19, 2004 11:12 am     Reply with quote
I use 10 bits.
switch(AnaState)
ADCON0=ANACH0;
AnaState++;
AdBusy=1;
AnaState++;
AnaState++;
and so on..
Greetings
Chris
How fast are you looping?.
It is possible/probable, that if the time is not long enough between the 'select', and the 'read' operation, there may be significant interraction between the channels. Also you do not test if the ADC, has finished it's conversion, when reading, so depending on the 'loop' rate, and the ADC clock, the conversion may not have finished.
You don't actually 'need' to code this yourself, the compiler has the functions to do the required operations seperately.
So:
switch(AnaState) {
          set_adc_channel(ANACH0);
          AnaState++;
          read_adc(ADC_START_ONLY);
          AnaState++;
          ADvalue0=read_adc(ADC_READ_ONLY);
                           AnaState++;
//You need to ensure that the loop time here, is long enough to allow the
//input to charge to the incoming voltage (typically in the order of
//perhaps 10uSec), and is also long enough for a conversion to complete.
Christer
PostPosted: Tue Jan 20, 2004 4:30 am     Reply with quote
Thanks a lot for your answers. Very Happy
I was a bit too rapid in my case changing.
Now it works fine. The metod witt the builtin funktions does not work at all. I have tried that earlier. Strange!!
Christer TENNSTEDT
