Delay and timer1 problem pic16f877a
ufkyldrm
PostPosted: Mon May 21, 2018 1:07 pm     Reply with quote
Hi guys i'm 15 years old, and I decide to learn pic, So i respect to all of u Smile
I started with pic16f877a . But some problems are exist.
My pic do not notice delay function and timer interrupts.
In my program i try to count pulses with timer1 interrupt and control variables with lcd display.
Everything is ok on Proteus 8 but on board only outputs which I can only see.
I don't know what is problem, I use 20MHZ crystal with 22pf cap, in datasheet of 16f877a these items are used.
my code is
#include<16f877A.h> //picin özelliklerini al
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD //BAZİ özellikleri iptal ediyoruz.
#use delay(clock=20M)   // osilatör hızı
#include<lcd.c>
#include<modbus.c>
#include<stdio.h>
#use fast_io(b)
#use fast_io(c)
//int toplamadres=0;  // programınGt en sonunda eklenecek epron
//int pulseadres=5;    // programın en sonunda eklenecek epron
#include <stdlib.h>
float pulse=1.123f;
float toplam=0.0001f;
int sayici=0;
float modbusno=10.0;
int editsayici=0;
int kontrol2=7;
int kontrol3=7;
int kontrol4=7;
int kontrol5=7;
int editimlec=0;
Boolean secildi2=false;
void Write_Float_Eeprom(address, float data) //epron write float
   int8 i;
   for(i = 0; i < 16; ++i){
     write_eeprom(address + i, *((int8 *)(&data) + i));
float Read_Float_Eeprom( address)    //epron read float
   int8 i;
   float data;
     *((int8 *)(&data) + i) = read_eeprom(address + i);
   return data;
//Write_Float_Eeprom(toplamadres, toplam); // programın en sonunda eklenecek epron
//char buffer[17];
int i=0; // Tamsayı tipinde değişken tanımlanıyor
//****************** Timer1 Kesmesi *****************************
#int_timer1 // Timer1 kesmesi
void timer1_kesme () // Kesme fonksiyonu ismi
 set_timer1(65533); // TMR1 değeri belirleniyor
 i++; // i değeri 1 arttırılıyor
 if (i==1) // i değeri 1'ye eşit olursa RB0 lojik-1 olsun
 output_high(pin_b0);
int f=21;
  char buf[8];
  printf(lcd_putc,"%u",f);
toplam=toplam+pulse;
//  Write_Float_Eeprom(toplamadres, toplam);
 if (i==2) // i değeri 100'e eşit olursa RB0 lojik-0 ve i=0 olsun
 output_low(pin_b0);
 i=0;
secildi2=true;
 setup_psp(PSP_DISABLED); // PSP birimi devre dışı
 setup_timer_2(T2_DISABLED,0,1); // T2 zamanlayıcısı devre dışı
 setup_adc_ports(NO_ANALOGS); // ANALOG giriş yok
 setup_adc(ADC_OFF); // ADC birimi devre dışı
 setup_CCP1(CCP_OFF); // CCP1 birimi devre dışıetup_CCP2(CCP_OFF); // CCP2 birimi devre dışı
 set_tris_b(0b00111100); // B portu komple çıkış b1 dışında
  set_tris_a(0b00000000); // B portu komple çıkış b1 dışında
 output_b(10000010); // B portu çıkışı ilk anda sıfırlanıyor
 output_a(00000000); // B portu çıkışı ilk anda sıfırlanıyor
 output_high(pin_b1);
 output_high(pin_b7);
  output_low(pin_b6);
 setup_timer_1(T1_EXTERNAL | T1_DIV_BY_1); // Timer1 ayarları yapılıyor
 enable_interrupts(INT_timer0); // int_timer0 kesmesini aktif yapar
 enable_interrupts(INT_timer1); // int_timer0 kesmesini aktif yapar
 enable_interrupts(GLOBAL); // Aktif edilen kesmelere izin ver
  output_high(pin_b6);
  delay_ms(2000);
  output_low(pin_b6);
  delay_ms(2000);
////////-------------- korumalı menü bölümü
if(sayici==1)
if(secildi2)
  lcd_putc("\f----:PULSE:----\n");
  printf(lcd_putc,"%.4f",pulse);
   secildi2=false;
   lcd_cursor_on(FALSE);
else if(sayici==0)
if(secildi2)
  lcd_putc("\f----:TOPLAM:----\n");
  printf(lcd_putc,"%.4f",toplam);
   secildi2=false;
else if(sayici==2)
if(secildi2)
  lcd_putc("\f---:MODBUS NO:---\n");
  printf(lcd_putc,"%f",modbusno);
   secildi2=false;
////////-------------- korumalı edit menü bölümü
  if(!(input(pin_b2))&&kontrol2==7)
sayici++;
if(sayici==3)
sayici=0;
kontrol2=1;
secildi2=true;
kontrol2=7;
  if(!(input(pin_b3))&&kontrol3==7)
if(editsayici==0)
lcd_cursor_on(true);
 output_low(pin_b1);
   lcd_putc("\f--:PULSE:EDIT---\n");
kontrol3=1;
editsayici++;
else if(editsayici==1)
 output_low(pin_b1);
   lcd_putc("\f:MODBUS NO:EDIT-\n");
kontrol3=1;
editsayici++;
if(editsayici==2)
editsayici=0;
kontrol3=7;
int sayac=0;
  if(!(input(pin_b4))&&kontrol4==7)
sayac++;
editimlec++;
  lcd_gotoxy(editimlec,2);
lcd_cursor_on(TRUE);
if(editsayici==1)
 if(editimlec==6)
 editimlec=0;
if(editsayici==0)
 if(editimlec==2)
 editimlec=0;
kontrol4=1;
else if((input(pin_b4))&&kontrol4==1)
kontrol4=7;
  if(!(input(pin_b5))&&kontrol5==7)
char a=lcd_getc(editimlec, 2);
a++;
if(a==58)
a=48;
if(a==33)
a=32;
if(a==47)
a=46;
if(!(a==32&&a==46))
 lcd_putc(a);
   lcd_gotoxy(1,2);
//pulse=printf(lcd_getc,"%.4f",pulse);
char ch_lcd[15];
int cnt=0;
for(cnt=1; cnt<6; cnt++)
    ch_lcd[cnt-1]= lcd_getc(cnt,2);
if(editsayici==1)
pulse = atof(ch_lcd);
if(editsayici==0)
modbusno = atof(ch_lcd);
    output_high(pin_a0);
kontrol5=1;
else if((input(pin_b5))&&kontrol5==1)
kontrol5=7;
 //output_high(pin_b1);
//toplam=Read_Float_Eeprom(toplamadres); // programın en sonunda eklenecek epron
//pulse=Read_Float_Eeprom(pulseadres);  // programın en sonunda eklenecek epron
 // Sonsuz döngü
My Proteus pic
https://ibb.co/mRAdY8
please help me :(
PostPosted: Mon May 21, 2018 1:57 pm     Reply with quote
For a 20 MHz crystal, the HS fuse is required. XT is only good up to 4 MHz.
ufkyldrm
PostPosted: Mon May 21, 2018 2:11 pm     Reply with quote
thank u for your interest
i deleted #fuses XT and i set #fuses HS nothing change. :(
i delete enable interrupts ( global ) and delay function work good. I guess i should not use timers with delay. Now timer1 dont work ::((( whuuuyy
ufkyldrm
PostPosted: Mon May 21, 2018 4:03 pm     Reply with quote
i delete enable interrupts ( global ) and delay function work good. I guess i should not use timers with delay. now timer1 dont work ::((( whuuuyy
PostPosted: Mon May 21, 2018 4:28 pm     Reply with quote
just a comment...
The general rule for using interrupts is to make the code small and fast inside the ISR ( Interrupt Service Routine )
You should ONLY set a few flags, maybe change a register or two.
You should NOT use delays or prints inside the ISR.
Jay
PostPosted: Mon May 21, 2018 4:44 pm     Reply with quote
set_timer1(65533);
The timer rolls over to 0 in the next clock after it counts up to 65535.
It causes an interrupt when the timer rolls over. You are setting it to
65533. This will not work. You can't make it interrupt that often.
With a load value of 65533, you will get a new interrupt when you have
not finished the #int_timer1 code for the previous one.
Also don't do any lcd operations inside the Timer1 interrupt.
They are too slow. Do them in the main() code. Remove lcd_init()
from the Timer1 interrupt routine.
Also, don't write to eeprom inside the #int_timer1 routine. Eeprom
write operations take too long to do. (up to 5 ms each byte. There are
4 bytes for each float).
Also, you are enabling interrupts for #int_timer0, but you don't have an
interrupt routine for Timer0. Don't do that. Remove the line in bold.
ufkyldrm
PostPosted: Sun May 27, 2018 1:37 pm     Reply with quote
problem is solved than uuuu!!
